Old May 19, 2012, 12:50 AM
ozgus is offline
Find More Posts by ozgus
Joined May 2012
OS 46 VX-M Dry Run
Hi guys,
newbie, nonetheless have come into possession of an OS 46 VX-M.
am in the process of setting up a dry dock (with water supply) to get the engine going. I am trying to think of the best solution to provide load to the engine as i don't want to run it without. just a regular airplane prop? will the recommended prop for an aircraft engine of the same size be suitable loading for a marine? should i look into a weighted flywheel? Can i tune the engine properly in this circumstance?
surely plenty of people have been through this before.
thanks in advance,
gus.
ozgus is offline Find More Posts by ozgus
Old May 21, 2012, 12:27 AM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
ozgus
Welcome to RCG, it would be difficult to mount an airplane prop on that engine since the exhaust is facing toward the back and the OS 46 VX-M do requires a tuned pipe to run. ABC or ABN engines do not requires breaking in like a ringed or lapped engine,running them too cold or too rich will destroy the piston/sleeve fit in no time and its almost impossible to get spares for OS engines. The best way to run a marine engine is in a boat!
You will get more expertise in the IC racing forum:
http://www.rcgroups.com/racing-boats...combustion-58/
coriolan is online now Find More Posts by coriolan
Old May 21, 2012, 11:14 AM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Looking at the thread title, I was wondering how one could put a boat through a "dry run"---.
der kapitan is offline Find More Posts by der kapitan
Old May 21, 2012, 12:07 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
We used to run airplane props on them to break them in.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old May 21, 2012, 12:56 PM
coriolan's Avatar
Canada
Joined Sep 2006
It is not easy to mount an airplane prop on an OS 46 VX-M as it is set up to use a flywheel+collet without a prop driver unless ones have the missing parts!
http://manuals.hobbico.com/osm/46vx-m-manual.pdf
http://www3.towerhobbies.com/cgi-bin...?&I=LXCL42&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXCT71&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXCT54&P=Z
Old May 25, 2012, 06:06 AM
ozgus is offline
Joined May 2012
Ok, thanks. I guess it all helps. I have watched several vids of marine engines running dry and without load and was just thinking there must be better way.
To the drawing board...
Sold Great Running OS 46 FX TGKconnectors Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 17, 2012 11:12 AM
Sold OS MAX 46 VX-M New no box ebourlet Boats (FS/W) 0 Nov 01, 2010 12:03 AM
Sold Nib Os 46 Vx-df mavdriver Aircraft - Fuel - Jets (FS/W) 2 Sep 01, 2009 06:08 PM
Discussion EDF to replace Turbax 48 and OS 46 VX-DF or K&B 48 bryadelm Electric Ducted Fan Jet Talk 8 Oct 21, 2008 06:06 PM
Question Using a OS .46 VX DF engine with propeller instead of a ducted fan..... inazuma Engines 1 Feb 06, 2007 07:10 PM
