Old May 18, 2012, 08:22 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Mini-Review
Exceed RC Rocket Series 2205-1500 (30g, ~1510Kv)
Daniel Miller kindly lent me a couple of motors to test for him. The second is the Exceed Rocket Series 86MA50 2205-1500 (~1560Kv). This motor weighed in at 32g with its built-in prop saver and attached X-mount.
Using my usual bag of tricks for bench testing (Zurich Power Supply; Thrust Stand with Ohaus CS2000 digital scale; Eagle Tree v4 with Power Panel display, RPM and Temperature probes; Medusa Power Analyzer Plus; Hobbico Digital Tach; Gobrushless Servo Tester instead of a Tx; and for this test a Motrolfly 10A ESC) I ran no-loads at 7v, 8v, 10v, then a series of prop tests with props ranging from 6x3 GWS HD up to 9x5 GWS HD.
Using data from the no-load and prop tests, DriveCalc computed a Kv of ~1510Kv, and an Rm of 0.463Ω. Maximum efficiency was 76.7% @ 3A, and 60% at the computed maximum of 8.7A. [The Exceed specs suggested 12A/90W maximum]. The motor ran very smoothly throughout the testing, and heating only became an issue when the larger props were tested. The basic “rule of thumb” of 3W/g for power handling ability suggests that 90W would be a prudent maximum. For 3s use only the 6x3 GWS HD and 7x3.5 GWS HD can be considered suitable, since anything larger (8x4 GWS HD and 8x4.3 GWS RS) generated worryingly high temperatures. “RPM as a % of Kv x V” is a telling parameter… ideally around 70% is the acceptable minimum… and for this motor, all the larger props fell way short. The 8x4 GWS HD might just be suitable for 2s use (68%), but not for 3s use, since 60% and elevated temperature indicate over-loading. “RPM as a % of Kv x V” of 63% on 2s and 54% on 3s (allied with a temperature of 68°C after the series of bursts to WOT) indicates that an 8x4.3 GWS RS is too much for it. Neither of the 9” props tried at 2s voltages produced acceptable RPM numbers.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 03, 2014, 01:04 AM
Gonzo 1971 is offline
Find More Posts by Gonzo 1971
This is BAT country!
Gonzo 1971's Avatar
United States, MI, Ovid
Joined Nov 2003
I just tried the 2205-1400kv version. I have to say it is a turd. I bought it to replace a Turnigy "Donkey" 2204-1550 (came on a used foamy) as it was weak also. Zero improvement and will not spin a prop like a blue wonder. Smooth running nice motor, just wrong for a 3d foamy.
Gonzo 1971 is offline Find More Posts by Gonzo 1971
Sold Exceed RC Rocket 2215-1500KV Blasturbator Aircraft - Electric - Power Systems (FS/W) 2 Mar 23, 2012 05:31 PM
For Sale New Exceed RC Rocket 3020-600KV Brushless Motor for RC Plane Bonestockz06 Aircraft - Electric - Power Systems (FS/W) 2 Dec 04, 2011 04:01 AM
Discussion prop mounting on exceed rc rocket motors jmdhuse Multirotor Talk 1 Nov 14, 2011 06:29 PM
Help! Exceed RC Rocket 2215-920KV Brushless Motor - NOT for Quadrocopters mrwolf HobbyPartz.com 0 Oct 24, 2011 08:58 PM
Help! Shaft - Exceed RC Optima Series Brushless 2700KV r0beert0 Power Systems 10 Oct 24, 2011 12:26 PM
