Old May 18, 2012, 01:16 PM
sityofcin is offline
Find More Posts by sityofcin
cincinnati
Joined May 2010
Still no update for ESC calibration thru HFP?
When can I expect to be able to calibrate ESC's without doing each ESC one at a time? I have a Y6 and Octo that I really dont want to go through one at a time...
sityofcin is offline Find More Posts by sityofcin
Old May 18, 2012, 02:02 PM
unfaix is offline
Find More Posts by unfaix
I'm New
unfaix's Avatar
United States, TX, Arlington
Joined Mar 2012
I thought you could already do that?
I have been doing it with my v4
unfaix is offline Find More Posts by unfaix
Old May 18, 2012, 02:28 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i would not... they said a while back that there was something wrong with the throttle calibration through the FC.
i just made a 6 Y servo connector.... takes me like 20secs to calibrate. And you only have to do it once....
I will be a nice feature when it works, but not really necessary (IMO)
Adidas4275 is offline Find More Posts by Adidas4275
Old May 18, 2012, 09:01 PM
JZSlenker is offline
Find More Posts by JZSlenker
JZSlenker's Avatar
United States, PA, Harrisburg
Joined Aug 2011
The new betas have this issue fixed.
JZSlenker is offline Find More Posts by JZSlenker
Old May 18, 2012, 09:18 PM
unfaix is offline
I'm New
unfaix's Avatar
Joined Mar 2012
Is that why when I am hovering. It slowly drift aft ward?
Old May 18, 2012, 09:27 PM
Adidas4275's Avatar
Joined Mar 2011
Are you flying with Auto level or in manual ?
Old May 18, 2012, 09:30 PM
unfaix is offline
I'm New
unfaix's Avatar
Joined Mar 2012
I am flying manually. My trims are centered as well.
Old May 18, 2012, 11:52 PM
Adidas4275's Avatar
Joined Mar 2011
Did you calibrate for temp on the gyros?
Old May 19, 2012, 02:59 AM
unfaix is offline
I'm New
unfaix's Avatar
Joined Mar 2012
Totally forgot to do that.
Old May 19, 2012, 03:20 AM
Adidas4275's Avatar
Joined Mar 2011
That might be it
Old May 19, 2012, 03:23 AM
unfaix is offline
I'm New
unfaix's Avatar
Joined Mar 2012
Also is there an easier way of calibrating the gyro?
Pointing the board in all directions while mounted is hard, and hard to hold it still.
Old May 19, 2012, 03:33 AM
Adidas4275's Avatar
Joined Mar 2011
Those are the accelerometers and will only help when in auto level mode or the gyro calibration is the temperature one.
You need to unplug the FC and then run the temp calibration.
The HF guys have said that they will have a better way to calibrate acc soon
Discussion flashing rctimer esc for the hfp windfou Hoverfly Technologies 14 Dec 12, 2011 03:25 PM
Discussion HFP Passes all tests. No beeps from the motors. Webheadfred Hoverfly Technologies 2 Dec 08, 2011 11:05 PM
Help! HFP will not power up after firmware update wayneabonga Hoverfly Technologies 1 Nov 08, 2011 11:15 AM
Help! HFP board will not power up after firmware update wayneabonga Hoverfly Technologies 5 Nov 06, 2011 08:07 PM
Help! No GPS or Calibration menu on monitor asael Eagle Tree Systems 3 Sep 27, 2011 02:26 PM
