Old May 18, 2012, 11:51 AM
STANG KILLA SS's Avatar
Killeen TX
Joined Dec 2006
Reversing shaft on ERC .40 size motor
Just purchased my first Hobby Lobby ERC .40 size motor. It is setup to mount behind the firewall. Shaft and X brace on same end of motor. If I want to mount the motor in front of the firewall the shaft needs to reverse. The only problem is there is no groove in the shaft for the E clip to go back into. As I see it, with no E clip the motor is going to pull apart from the thrust. Any thoughts?
Lee Mitchell
STANG KILLA SS is offline Find More Posts by STANG KILLA SS
Old May 18, 2012, 12:23 PM
Beaumont, TX
Joined Feb 2007
Cut a new groove.
http://www.rcgroups.com/forums/showt...ew+motor+shaft
Pete Miller is offline Find More Posts by Pete Miller
Old May 18, 2012, 01:40 PM
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
That's a great "How to" by Jack Erbes
rick.benjamin is offline Find More Posts by rick.benjamin
Old May 18, 2012, 01:46 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Also cut a flat for the grub screw that holds the shaft in the magnet housing if there is not one.
A lot of the newer motor are supplied with collar that slides up against the e-clip and is also locked with a grub screw. That is insurance again losing the E-clip. You can make a collar from a DuBro axle wheel collar if you get one that is undersized and drill it out to fit the shaft.
Jack
jackerbes is offline Find More Posts by jackerbes
Discussion replacing shaft on park 180 motor phil alvirez Power Systems 7 Mar 07, 2012 02:43 AM
Found 8,9,+10 tooth pinions that will fit on park 370 size inrunner motor shaft ddrummer508 Aircraft - Electric - Helis (FS/W) 5 Feb 15, 2011 05:16 AM
Discussion Hex size on 2205 motor shaft set screw? kdahlhaus GWS (Grand Wing Servo) 1 Jun 26, 2007 09:14 PM
Discussion Odd shaft size on bl 370 motor robmoll Electric Motor Design and Construction 3 Nov 03, 2006 09:39 PM
Shaft size on 600 brushed motor Milton Power Systems 3 Dec 08, 2005 01:10 PM
