Old Sep 19, 2012, 11:26 AM
fishboy77 is offline
Find More Posts by fishboy77
In search of RC nirvana
fishboy77's Avatar
USA, MO, St Louis
Joined Jun 2007
Originally Posted by sebbe View Post
biskit, man she looks nice,,,, Just to bad the shipping costs to Sweden is HUGE ,,,, I guess SUSA is the only one selling these planes ?
It sounded like SUSA is MAKING the planes, so I doubt anyone else is selling them.
fishboy77 is offline Find More Posts by fishboy77
Old Sep 19, 2012, 02:39 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Forgive me if this has been posted, but can we get some pics and or measuremenats of the battery compartment?
I took a fews word for it with my Viper and I don't want to get screwed again. I want a fuse that will easily hold a 5s 2200mah and I would love to know a specific 5s or 6s pack that is bigger that will also fit.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Sep 23, 2012, 06:29 PM
Jaguar22 is offline
Find More Posts by Jaguar22
Never Stop Learning
Jaguar22's Avatar
United States, GA, Atlanta
Joined Mar 2005
A ThunderPower 2650 45C 6S pack is the largest pack I can fit into the wing opening. The pack is a very tight fit with no room to spare in every dimension. The pack barely fits in the wing opening and will slide forward maybe 15mm but not backwards past the wing opening. Pack dimensions are 128mm long x 43 mm high x 38 mm wide. You can shop battery dimensions to suit your setup needs. I do not run ThunderPower packs but I have one here and offer this up for size comparisons.
Good luck
Jaguar22 is offline Find More Posts by Jaguar22
Old Sep 23, 2012, 07:36 PM
You down with EPP?
Houston, Tx
Joined May 2009
Good luck
Ok, so it looks like a TP 5S 2700mah 65C might work. (127x39x36mm)
Old Oct 05, 2012, 11:20 PM
seng30904 is offline
Find More Posts by seng30904
seng30904's Avatar
United States, SC, North Augusta
Joined May 2007
New Jolt
Hey fella's, I hope you can stand another Jolt owner. Mine showed up at the front door two days ago. I havn't even had the time to unbox it. I ordered the Green version with flaps. I not an expert by any means, but I do have a couple of Hotliners and pylon planes in my stable. I dont know what to do with the Bi-ailerons though. From the pictures I've seen, there are only one servo bay per side, but two movable surfaces. What gives? I also purchased (from SUSA) a TP 2250 4s. I own a couple of other similar size 4 cells, but they are not of the TP's higher "C" rating. I plan on using a Kontronic 480/33, with a 4.2:1 box. Motor calc states around 175/170 speed-thrust with a 10/23 GM folder.
seng30904 is offline Find More Posts by seng30904
Old Oct 06, 2012, 12:25 AM
biskit is offline
Find More Posts by biskit
United States, AL
Joined Apr 2007
Check the build thread!
biskit is offline Find More Posts by biskit
Old Oct 06, 2012, 12:12 PM
seng30904's Avatar
Joined May 2007
How do you find the build thread? Is there a link to it?
Old Oct 06, 2012, 05:11 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Here you go http://www.rcgroups.com/forums/showthread.php?t=1736013 and the Giga flap is slaved off the ailerons,they bleed any dirty air from the ail deflection out to the wingtip that is already reducing it's own dirty air.I just used tape (as that is what most do) for mine,No servo needed.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Oct 07, 2012, 09:03 PM
seng30904's Avatar
Joined May 2007
Found it. Thanks VooDoo
Old Oct 08, 2012, 12:59 AM
mewert is offline
Find More Posts by mewert
Team Armattan
mewert's Avatar
College Place, WA.
Joined Apr 2004
I would like to see some vids of these Jolts flying.
mewert is offline Find More Posts by mewert
Old Oct 08, 2012, 05:29 PM
You down with EPP?
Houston, Tx
Joined May 2009
No Jolt vids
Gary from SUSA says he has had his over 200mph. I am assuming that is on 5S (2s and 3s in series)
Old Oct 08, 2012, 05:33 PM
Joined Aug 2010
Vid right here,but this was one of the proto,i will try to find the newer vids with the production model...Only difference,stronger wing.
Jolt F5D Pylon (2 min 33 sec)
Old Oct 08, 2012, 05:36 PM
Joined Aug 2010
Here is another
Jolt F5D (2 min 45 sec)
Old Oct 08, 2012, 05:40 PM
Joined Aug 2010
If you want to know what it is like to be the Jolt,here you go
Pylon Racer On Board Video (3 min 17 sec)
Old Oct 09, 2012, 12:45 AM
mewert is offline
Team Armattan
mewert's Avatar
College Place, WA.
Joined Apr 2004
Pink is pretty hard to see, but I get the idea of how quick they are. Geez, what a nasty place to land. Makes me feel real lucky to have a 700 ft. grass runway with wide open sky. Better get mine ordered.
Thanks for posting.
Discussion What are y'alls shipping times? Ordered on monday still hasn't shipped? elcid79 HobbyPartz.com 4 Jul 25, 2012 11:26 AM
Rave Heads Up RC: so fast: ordered Saturday, it arrived Monday morning! john-doe Vendor Talk 14 May 22, 2012 10:38 AM
Discussion Need RED EPIC OR X company for Job on Monday wac Aerial Photography 5 Nov 03, 2011 05:53 PM
Discussion Need RED EPIC OR X company for Job on Monday wac Aerial Photography 0 Nov 02, 2011 09:54 PM
Discussion Will Home Depot special order pink FFF? jkarnacki Foamies (Scratchbuilt) 4 Oct 27, 2010 04:54 PM
