Espritmodel.com Heli Air
Old May 17, 2012, 08:30 PM
Joined Jun 2011
kk black board won't arm
so what do i have to do to get my kk black board setup so that my quad will fly? cause I can't get the board to arm when I move the rudder stick? do I have to calibrate the board to arm some how or what's the deal with this thing?
Iceman320 is offline Find More Posts by Iceman320
Old May 17, 2012, 10:34 PM
Joined Apr 2012
There are a number of things you can try.
1). Make sure your throttle and rudder channels don't need to be reversed.
2). Try adding a little bit of down trim.
3). Set your throttle endpoints to 100% and sub-trims to 0%
4). Calibrate your ESCs.
I had trouble getting my v5.5 board to calibrate and arm, then I reset my endpoints and sub-trims, and suddenly it worked great.
Good luck!
If you still have trouble, please post more details and hopefully someone can help.
a2j812 is offline Find More Posts by a2j812
Old May 17, 2012, 10:42 PM
Joined Jun 2011
ok I got the kk board to arm and everything is working like it should but when I give forward input the quat wants to tile back and when i give back input it wants to tile forward. what do i need to do to make it right. do I need to reverse some things or what? i'm using an airtronics rds 8000 radio and have it set to areo and i have the delta seting set to act.
Old May 17, 2012, 10:51 PM
Joined Dec 2010
Sounds like now you need to reverse the pitch direction on your transmitter. Dadde's guide is teh best summary of this info; it goes through all the checks necessary for setting up the KK board.
rogue277 is offline Find More Posts by rogue277
Old May 17, 2012, 10:59 PM
Joined Jun 2011
ok thanks for the help I will try reversing the pitch. also I have the kk board mounted to the quad so that the arrow is pointing forward between the front arms would that be a problem?
Old May 18, 2012, 12:50 AM
TheKnightFerrin's Avatar
Oregon
Joined Jan 2011
That depends whether you have a x or + quad frame.
Here is a link to the aforementioned guide http://www.rcexplorer.se/Educational...e/kkguide.html
TheKnightFerrin is offline Find More Posts by TheKnightFerrin
Old May 18, 2012, 01:28 PM
Joined Jun 2011
Ok thanks for the help, i will mess with it a little bit more then.
Old May 18, 2012, 08:58 PM
Joined Jun 2011
is there any way that I can get my quad copter to tilt left and right when I move the aileron stick instead of when I move the rudder?
Old May 18, 2012, 09:03 PM
Joined Dec 2010
Check the connections from the Rx to the KK board. It sounds like you have your rudder going where aileron should go
Old May 18, 2012, 10:07 PM
Joined Apr 2012
Make sure you know what version of the firmware your board is flashed with. It will be either X or +.
Also make sure your ESCs are in the right locations and rotation direction.
Old May 19, 2012, 12:02 AM
Joined Jun 2011
mine is the v5.5 board with the v2.1 programming. I also keep having trouble with it not wanting to arm unless I play with the motors and then they will arm.
Help! X-525 Kit, KK Controller 5.5 Won't Arm *SOLVED* coh998 Multirotor Talk 9 Nov 10, 2012 01:33 PM
Discussion KK 5.5 Board won't arm? iCrap Multirotor Talk 54 Jun 19, 2012 03:20 AM
Help! KK Board won't arm - Tried everything! flyandi Multirotor Talk 30 May 05, 2012 04:15 PM
Discussion KK board vs MCW MultiWii vs Flycam Black Board ishaan65 Multirotor Talk 10 Apr 08, 2012 07:45 AM
Discussion KK board won't power up. HELP!!! BOILER1 Multirotor Talk 26 Mar 15, 2012 02:13 PM
