Old Jun 11, 2012, 01:01 AM
Lupus78 is offline
Find More Posts by Lupus78
"We're in the pipe, 5 by 5"
Lupus78's Avatar
Finland, Vantaa
Joined Jun 2010
Originally Posted by PiperCub49 View Post
Pete,
Is there any place we can keep up with and/or see your friend's work?
Haven't posted anything yet. So here's the first teasers.
I'm working on some Clergets, Lewis guns, Vickers etc. for micro use. I'll also try and make some bigger scale versions for bigger planes. Here's just couple WIP screenshots of what I've done. They will be available directly from Shapeways, once mtflyr has received his batch of items and we've both approved them. They will be 3d printed with the Shapeways "Frosted Ultra-Detail" material.
Lupus78 is offline Find More Posts by Lupus78
Old Jun 11, 2012, 07:40 AM
Vrated is offline
Find More Posts by Vrated
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
Is 3d printing anything like stereolithography? nice work.
Vrated is offline Find More Posts by Vrated
Old Jun 11, 2012, 07:59 AM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Its' Here!!!
I had a big box delivered to my door in the middle of a tremendous downpour last Friday - in perfect shape. Inside was an even more perfect gift: Pete's beautiful Nieuport. I was floored and spent the next hour just admiring all the wonderful detailing Pete put into this bird. The images he posted don't do this masterpiece justice! The Le Rhone and Lewis gun were particularly impressive!
I programmed my DX8 per Pete's recommendations, and ran the Nieuport through its paces - again, perfect (after I reversed the elevator control). The spinning engine is particularly impressive.
All I need now is a break from the inundating rains, and I'll be off into the wild blue yonder.
Thanks, Pete...I don't know how to adequately express my appreciation, but I'll try showing by sending more pre-tissued paper models for you to turn into flying machine masterpieces.
Gene K
speedy01 is online now Find More Posts by speedy01
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Thanks UNGN, I also know better now besides being the GuRu of e-stuff you really know your motors too.
Do you still do car racing stuff? Cool...
Excellent Toni thanks for posting the info. on you super cool designs and Shapeways.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Jun 11, 2012, 08:10 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Pete,
Nice work, as always. Even though I haven't done any printed tissue in years I'm always happy to see it still being done, and so well.
Lupus78, nice work on Shapeways parts. I think it's an excellent idea to design scale pieces that can be purchased via Shapeways.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jun 11, 2012, 09:01 AM
Gulf Breeze, FL
Joined Jul 2006
It's Alive! Dawn Patrol
Yesterday, during a break from the rains (we set a single day record in Pensacola for rainfall - 14 inches), I just had to take the Nieuport outside..even though the wind was too high. My intent was to just do some taxi tests (y'all know that routine). Well, (and you know what's coming next) ... it did lift off nicely, but after about 15 feet at low altitude, I wisely yielded to the wind and aborted.
This morning I beat the sun (but not the wind) and excitedly sped off to the wet soccer fields. Since I knew from yesterday that Pete had set up a good flyer, I boldly launched into a 5MPH head wind - what a beautiful sight! After a fast downwind and stable turn into the wind (aided by the programmed rudder/aileron interface), the Nieuport slowed down to a crawl for an impressive fly-by. I didn't push the flight envelope, choosing instead to just admire that beautiful yellow Nieuport in the early morning sunrise.
After the first battery, I loaded a Hyperion 240 and the little Nieuport shot into the sky courtesy of that strong Mustang motor ... until..... until the prop unscrewed itself! I very obviously should have checked the propafter the first flight since Pete had reversed the prop shaft, resulting in reversed threads. On impact, the Lewis gun popped off as Pete intended, and the Nieuport was ready to take to the skies again after I secured the prop and gun. However, I decided to take it home to give it a complete check (which it passed with flying colors).
So Pete, it flies as great as it looks - excellent job all around!
Gene K
Old Jun 11, 2012, 09:12 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Thanks Gene, sorry about the prop. That also happened to me once while on final so it was not an issue. It's why I aslo was going to use the Mosquito shaft on mine if I do the same to lenghten the shaft that way it will be the normal direction to put the prop on.
Pete
Old Jun 11, 2012, 09:29 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I love motors and mechanical stuff. When ever I visit somewhere I usually spend a day or 2 in the technical museums trying to figure out how things worked.
It always amazes me how smart people were 100 - 200 years ago and if they had only had the internet, how much further along the world would be.
The world had practially every thing it needed in the 1890's to make an axial flow gas turbine engine by 1900-1905, but the design people and material people didn't know each other until the late 1930's early 40's. During WWII, the germans made turbine blades for their jet engines very similar to how folded card models are made, except in sheet metal. If the guy that thought up the card model idea (and the internet) was around in 1890, the wright bros might have switched to a gas turbine by 1910.
Gene, we need some video of the spinning engine!
UNGN is offline Find More Posts by UNGN
Old Jun 11, 2012, 12:20 PM
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by Gordon Johnson View Post
... I haven't done any printed tissue in years ....
Thanks one more time, Gordon, for helping me get started many moons ago!
Gene K
Old Jun 11, 2012, 03:10 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Thanks Gordon,
Your the Master...
UNGN thanks agin for all the motor info. etc.
Can't wait to see Toni's (Lupus 78) micro fake motors and other stuff should really help these birds come alive.
Pete
Old Jun 11, 2012, 08:39 PM
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by UNGN View Post
... we need some video of the spinning engine!
OK, here's a quickie:
NP 11 Features (3 min 40 sec)
Things I need to do:
1. Center the prop hub sticker - it looks wobbly in the video, but it's actually running true.
2. Apply tail and fuselage markings.
3. Reinforce the gun mount.
4. Go fly tomorrow morning.
Gene K
Old Jun 12, 2012, 11:16 AM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Pete,
Do you know the weight of your Le Rhone?
Kody
PiperCub49 is offline Find More Posts by PiperCub49
Old Jun 12, 2012, 02:45 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Hey Kody,
Take a look on page 2 of this thread. I posted a picture of the two fake motors together they are 2grs. So it's 1+ gr or so not a big deal and as I said you need some weight up front in these birds anyway I'd rather have that detail weight than just dead weight.
Pete
Old Jun 12, 2012, 03:06 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Hey Pete,
Sorry that I missed that picture. My CAD model is at 2.76g right now, and that is hollowed out! I'm not sure if you needed dead weight or if the battery was positioned to make up for any tail heaviness.
Kody
Old Jun 12, 2012, 04:14 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
OMG... Gene I couldn't stop laughing I just watched the video... You give me way too much credit. You must have a super battery in that as I don't remember it sounding that powerful... cool. That ending had me laughing...
Kody,
I have the brick and battery up as far as possible, given the fake LeRhone position and she trims out ok. What I meant was having a fake LeRhone or other motor and items up front in these short nosed WWI birds helps to get the CG. Using the PZ/P-51 set up also helps since the motor is 8mm (heavy) and it can put out enough power to have some speed. I can also fly pretty scale slow too.
I think you'll be okay with 3grs. Do you have anymore pictures of your CAD LeRhone and how would it be made? Sounds cool we need more of this 1:20-1:24 scale detail stuff.
Pete
Discussion new to helis but not rc with another which micro FP to get nickypoo Micro Helis 22 May 15, 2012 08:32 PM
Discussion Is there another option? Micro BL Setup elvill Micro Cars 2 May 08, 2012 02:53 PM
Discussion Possible Micro Nieuport 25 mtflyr Scratchbuilt Indoor and Micro Models 49 Apr 12, 2012 12:30 PM
Discussion Another new Micro frame, now from Turnigy!!! tc3wins Multirotor Talk 2 Mar 08, 2012 06:06 PM
Discussion Start of Micro Nieuport 17 mtflyr Scratchbuilt Indoor and Micro Models 77 Dec 23, 2011 11:07 AM
