Old Oct 14, 2012, 05:59 AM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
I use to just L bend into a hole I'd put in the horn but since we're talking micros here, I now just use a small drop of 5 min epoxy or even CA with a kicker once I'm sure I'm at neutral everywhere.
If you mess up or have to change them you'll need to get a real thin razor to do so. I just break apart used disposable twins. The blades although not good enough for a shave are great for cutting foam, paper or other things since they are super thin you can cut a point on them and they are also flexable. Plus I'm recycling.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Oct 14, 2012, 05:25 PM
vtdiy is offline
Find More Posts by vtdiy
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Thanks Pete, how simple --glue it to the horn! I'm going to try hot glue.
Do you do the elevator and rudder with bead wire and tube, too, or pushrods?
vtdiy is offline Find More Posts by vtdiy
Old Oct 14, 2012, 09:05 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Push rods. Too lazy to do pull pull lines
Pete
Old Oct 15, 2012, 12:19 AM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Thanks again!
I tried out the glued aileron horn and bead wire cable in another plane today -- an old Cox P-47 that I resurrected from bits and pieces. Added the ailerons, since it was RET before, and a new 10 gram brushless and 400 mah 2s batt, and WoW. Total transformation. Practically unflyable before, but now I would say it is the best flying plane I own!
Re-did all of the Nieuport laser prints, and glued them to real Depron this time. Added 1.2 mm CF tubes in LE under tissue this time. Put fuselage together.
Old Oct 15, 2012, 12:09 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Tissue "Grades"
Originally Posted by vtdiy View Post
Re-did all of the Nieuport laser prints, ...
To reiterate some points about tissue differences:
I have a big selection of various tissue packs that I've accumulated trying to find the one that prints best. By "best" I mean one that is bright white, doesn't have holes, and brings out the best quality of the laser toner while toughly bonding it to the tissue. An unsuitable tissue is one that's too pourous, letting too much toner go through to the carrier paper (as shown in the attachment). The density of the various tissues is obvious when holding them up to a light source.
My experience is that it's best to print on the dull side of wrapping tissue I got from CVS Pharmacy. Unfortunately it's only sold around the holidays, and I ran out this year (but the holidays start earlier every year, so I assume it will be restocked soon). I found a suitable substitute at Michaels' craft store in their "Celebrate It" tissue.
Hope this saves you some searching time.
Gene
speedy01 is offline Find More Posts by speedy01
Old Oct 15, 2012, 02:47 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
printing on esaki tissue, the shiny side gave my a grey color very bright, like the b17 in the aluminum skin, while the dull side gave me a more realistic 'matte' finish.
epson inkjet ink is somewhat waterproof (i guess it yould be water resistant then huh?)
i have not tested it long term, only wet and and rubbed and no ink smudging or runnning.
nemoskull is offline Find More Posts by nemoskull
Old Oct 15, 2012, 08:14 PM
vtdiy is offline
low tech high tech
vtdiy's Avatar
Southern Vermont
Joined Feb 2007
Thank you Gene for the tissue information.
Old Oct 17, 2012, 07:42 AM
TedD60 is offline
Find More Posts by TedD60
Joined May 2012
Originally Posted by speedy01 View Post
You may want to increase the rudder on some of these WWI builds - 15% is what Pete likes.
Why do we do this?
Do all models of scale a/c need this?
I remember looking at plans for scale models in MAN years ago ... especially for Free-flight and R/C ... and seeing that they would give TWO outlines for the tail, one was "scale" and the other was the size built for the model.
I've always assumed that it was for increased stability and perhaps to create a stronger effect for the control surface, but I have never known for certain.
TedD60 is offline Find More Posts by TedD60
Old Oct 28, 2012, 10:14 AM
TedD60 is offline
Joined May 2012
Has anybody ever posted a pattern for the airfoil section of a wing baking jig?
I just need the pattern for the airfoil ... building the rest of the jig looks pretty easy.
I thought I remembered copying one and printing it out some time ago ... but just can't find it.
Old Dec 12, 2013, 02:14 PM
Altbob is offline
Find More Posts by Altbob
Altbob's Avatar
Joined Oct 2012
Followed this over from Papermodeler.com I've been wanting to do this for years! Thanks for all the lovely step by step photos and instructions. My new favorite thread!
Altbob is offline Find More Posts by Altbob
Old Dec 12, 2013, 05:04 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Love that site!
Gene K
Old Apr 07, 2016, 03:32 PM
speedy01 is offline
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by deadbird View Post
I feel a bit guilty as I intended to make some Depron parts for you guys ....Guess I'll have to let the guilt build until I can take it no more!!!
Are we there yet, Jon?
Gene K
Discussion new to helis but not rc with another which micro FP to get nickypoo Micro Helis 22 May 15, 2012 08:32 PM
Discussion Is there another option? Micro BL Setup elvill Micro Cars 2 May 08, 2012 02:53 PM
Discussion Possible Micro Nieuport 25 mtflyr Scratchbuilt Indoor and Micro Models 49 Apr 12, 2012 12:30 PM
Discussion Another new Micro frame, now from Turnigy!!! tc3wins Multirotor Talk 2 Mar 08, 2012 06:06 PM
Discussion Start of Micro Nieuport 17 mtflyr Scratchbuilt Indoor and Micro Models 77 Dec 23, 2011 11:07 AM
