Old May 17, 2012, 07:51 PM
StewieRC is offline
Find More Posts by StewieRC
This Calls for a Sexy Party
StewieRC's Avatar
Minneapolis
Joined Sep 2010
will extend wing span = More power for my plane ?
so i'm currently re-build my plane using an old undercamber wing from my 24 inch blu-baby.
the old plane have a profile fuse, so this plane will be a little heavier, i'm sitting here thinking what if i stretch my plane wing span to 30+ inches ( same chord, same airfoil, same power system. etc )
will the gliding be better since wing loading will be lower ?
p/s : i'm pretty sure i have to increase my vertical stab size too. am i right ?
StewieRC is offline Find More Posts by StewieRC
Old May 17, 2012, 11:29 PM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
i think yes to all. but wait for some of the smart guys to answer.
xrx1113 is offline Find More Posts by xrx1113
Old May 17, 2012, 11:33 PM
StewieRC is offline
StewieRC's Avatar
Minneapolis
Joined Sep 2010
i'm thinking the same thing too, a slightly longer wingspan = more lift therefor i can climb faster.
Old May 17, 2012, 11:49 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I did the same thing.
The longer span added more weight and drag, so it didn't seem to climb much better because it took more power.
But it did glide better.
Butch777 is offline Find More Posts by Butch777
Old May 18, 2012, 12:34 AM
StewieRC is offline
StewieRC's Avatar
Minneapolis
Joined Sep 2010
well the entire purpose of this plane is too climb up really high shut down the power to glide and record video footage.
Look like i'll give this a try then, if the glide performance is increase by just a little bit, i'm one happy camper.
@butch777 is there anything i should know about, did you increase the size of your elevator or vertical stabilizer at all ?
Old May 18, 2012, 12:40 AM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
In a word, no. What most rc pilots consider a climb has more to do with how much thrust your motor can produce than how much lift your wing creates.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old May 18, 2012, 12:45 AM
Eclipse_7's Avatar
Joined Nov 2003
The higher the aspect ratio of your wing, the more efficient it should be. So the effect should be a better glide. Pitch should not be a problem, but a longer wing will dampen your rudder inputs, a larger rudder would counteract that.
Old May 18, 2012, 01:05 AM
StewieRC is offline
StewieRC's Avatar
Minneapolis
Joined Sep 2010
so stretching a 24 inch undercamber wing to 30 inch will only improve the glide, not the climbing part right ?
Old May 18, 2012, 01:10 AM
NFA Fabrication is offline
Find More Posts by NFA Fabrication
Joined Feb 2012
Correct sir. It will more than likely allow slower flying as well. You are probably going to want to add power for what you are planning.
NFA Fabrication is offline Find More Posts by NFA Fabrication
Old May 18, 2012, 01:17 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
....so this plane will be a little heavier,....
If you want the plane to climb better and fly for longer on the same powertrain then by far and away the best way to do it is make the plane lighter. Adding lightness will both improve the rate of climb AND slow down the rate of descant in the glide.
If the plane is significantly heavier and the powertrain is the same then it's performance in terms of climb and overall duration will almost certainly be worse.
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old May 18, 2012, 01:24 AM
StewieRC is offline
StewieRC's Avatar
Minneapolis
Joined Sep 2010
i'm looking at around 1:1 thrust ratio if i stretch the wing out a little bit, i guess i will stretch it out, i'm currently using my power system on a 2s right now, waiting for 2 3s battery to get here from China ( 3s will give me an extra 70g of thrust, bring the thrust ratio to around 1:4 )
Old May 18, 2012, 02:43 AM
Aberdeen
Joined Mar 2006
In theory if you have a thrust/weight ratio greater than 1:1 then 'any' wing is only slowing your climb down. If you can climb vertical then all your lift is coming from the prop so a bigger wing is just adding weight and drag which will slow the climb down, not speed it up.
Old May 18, 2012, 07:58 AM
StewieRC is offline
StewieRC's Avatar
Minneapolis
Joined Sep 2010
Thanks, now i know that longer wing will not help the on the plane climbing part ( mine 24 inch can climb at a 45 degrees angle on 3/4 throttle )
a longer wing will only help the gliding + weight carrying capacity right ?
Old May 18, 2012, 08:07 AM
Aberdeen
Joined Mar 2006
Yeah, providing nothing else changes.
Old May 18, 2012, 08:57 AM
dkrhardy is offline
Find More Posts by dkrhardy
United States, FL, The Villages
Joined Oct 2010
And your ESC/motor combo will take 3s? If it originally used 2s, no guarantee it'll be OK with 3s. Check before you burn something.
Don
dkrhardy is offline Find More Posts by dkrhardy
Question How do I get more power out of my Wing? Please read Bonestockz06 Foamies (Scratchbuilt) 11 Apr 27, 2012 12:31 PM
Gallery My 1st Plane was a Super Cub, My 2nd Plane will be ... Manzooka Beginner Training Area (Aircraft-Electric) 47 Jan 31, 2012 07:23 AM
Discussion How will moving my motor forward for a better cg affect my plane? krexken Electric Plane Talk 17 Sep 11, 2011 10:44 AM
Sold Will Trade 67" Wing Span Plane !! Melbourne, Florida fltekdiver Aircraft - Electric - Airplanes (FS/W) 2 Apr 12, 2011 05:50 PM
Help! Request for twisty wing plane span and aspect ratio (or wing area) data Sled Driver Slope 17 Oct 28, 2006 12:44 PM
