Old May 17, 2012, 06:25 PM
Nitro_Nancy is offline
Find More Posts by Nitro_Nancy
Nitro_Nancy's Avatar
United States, CA, Industry
Joined Jan 2011
Yippee!
Nitroplanes.com Tech One Pop Wing EPP Kit BACK IN STOCK!
Pilots! Nitroplanes.com just got back in stock our line of Tech One Pop Wing Kits! If you wanted to get a hold of one before but it was too late, now is your chance! For those who haven't heard of our Tech One Pop Wing Kits. Here are some details and specs:
Fuselage length: 575mm (22.6in.)
Wingspan: 900mm (35.4in.)
Flying Weight:300--350g (with battery)
Needed to Complete:
Motor: T2208 KV 1370
ESC: 15-20 Amp?
Propeller: 7050E OR 6050E
Servo: 8g micro servo * 2pcs
TX/RX: 4 channel
Battery: 11.1V 800-1200mAh Li-po 20C
These are great for beginners because the EPP Foam makes these planes indestructible! My favorite are the fun abstract colors. Stand out in the sky this summer!
Check out our pilot Antonio do a test flight :
New Tech One RC Pop Wing Flight Review (9 min 46 sec)
http://www.nitroplanes.com/02a-019-p...green-kit.html
http://www.nitroplanes.com/02a-019-p...black-kit.html
Happy Flying!!!
Nitro_Nancy is offline Find More Posts by Nitro_Nancy
Site Sponsor
Old May 18, 2012, 04:48 AM
Syner01 is offline
Find More Posts by Syner01
United States, NJ, Lodi
Joined Jan 2012
I didn't get this line from nitro only because they were sold out at the time. Nitro actually has good pricing for this line.
See my cheat sheet on this line here:
http://www.rcgroups.com/forums/showt...9#post21536819
Some of my vids with this line also:
Mini
LazerToyz Techone Mini Popwing 800mah 3s (7 min 14 sec)
Popwing
Lazertoyz Techone Popwing 2200mah 40C Battery (8 min 0 sec)
Mini
Lazertoyz Techone MiniPopwing 800mah Generic Battery (3 min 20 sec)
Popwing on 4s
Lazertoyz Techone Popwing 850mah 4S 45-90C Battery (4 min 8 sec)
Syner01 is offline Find More Posts by Syner01
Old May 20, 2012, 03:07 AM
Soar Neck is offline
Find More Posts by Soar Neck
United States, CA, Roseville
Joined May 2011
I will be getting one of these fore sure. Maybe two. I have a hk tek sumo which is the exact same plane, minus graphics. I was set up to buy a ritewing tl 50 but once again I got screwed out of one by klique. It must not be in my cards to own a ritewing so i will stick with the much less expensive popwing and tek sumo. I cant wait to add another wing to the fleet
Soar Neck is offline Find More Posts by Soar Neck
Old May 21, 2012, 03:45 PM
PelagicFish is offline
Find More Posts by PelagicFish
Joined Jun 2009
I would like to order one of these right now, but I"m totally confused about what motor to get with it. Could somebody please point me towards a motor that would be good on this plane? (Best would be if NitroPlanes sells it.)
What should I be looking for? Watts? Kv? Or something else?
PS, I should probably add that I just "chatted" with NitroPlanes technical service. They told me that they don't sell a motor that will work with this plane. I find that kind of hard to believe. (I'd settle for any reasonably priced motor that works.)
PelagicFish is offline Find More Posts by PelagicFish
Old May 21, 2012, 06:39 PM
Joined May 2011
Here are motors that will work. The suggested battery/motor setup is small but will be a light weight build.
I run this one and a 40 amp esc with a 6x4 prop and anywhere form 1800-2200 3s or even 2-2200 3s
You could go bigger
I would even say this big
or go small
Old May 21, 2012, 10:28 PM
Joined Jun 2009
How about this? Would it be good? (For somebody that doesn't want a supercharged wing.)
http://www.hobbyking.com/hobbyking/s...er_1300KV.html
Old May 21, 2012, 11:11 PM
Joined Jun 2009
This one might be good too:
http://www.hobbyking.com/hobbyking/s...idProduct=2104
Old May 21, 2012, 11:49 PM
Joined May 2011
Both are acceptable size wise but the second one will not work unless there is some sort of prop adapter and mounting kit
Old May 23, 2012, 09:01 PM
Joined Jun 2009
Ok, so I'm going to go with that second motor. It weighs 49g. All I need now is some advice on what battery will balance it out well. Does anybody have any ideas?
My setup will look like this:
Motor: KD A22-10S Brushless Outrunner Motor (49g)
Battery: ???
Servos: HXT900 9g / 1.6kg / .12sec Micro Servo (2)
ESC: 20amp
Thanks!
Old May 23, 2012, 11:15 PM
MikeD096 is offline
Find More Posts by MikeD096
Albuquerque, NM
Joined Sep 2006
I'm running a Suppo 2212/10 (1400kv) that weighs 47g, plus prop saver and 7x5e or 7x6e APC props. A 2200mah 3S balaces great. To get a 2200 to fit, you will need to carve out a little bit of foam. I also reinforced the nose with carbon fiber rods as its prone to break off.
Be sure to scan over the other Pop Wing and Teksumo threads as well.
MikeD096 is offline Find More Posts by MikeD096
Old May 24, 2012, 01:52 PM
Joined May 2011
Battery: ???
ESC: 20amp
Thanks!
The hxt 900 will work but you might have to score the foam between the elevons and plane to make them move easier. I actually cut mine off and put hinges in them. Most 9 gram servos are too weak for this plane. I was running the hxt900 for awhile and just put these in.
Your setup will probably require a 3s 1300mah battery to balance it. The battery bay will not be big enough unless you run some super small motor.
So you picked this motor? How are you going to mount it?
Old May 24, 2012, 03:37 PM
Joined Jun 2009
I noticed that other people were running 2200mAh batteries with motors that weigh about the same as mine, or even slightly less... that's what I WAS going to get. Now I'm rethinking that idea. This is so confusing for me. Everybody seems to run different stuff, and there's so much conflicting information.
The difference in weight, between the two batteries is significant:
123g for this 1300mAh battery:
http://www.hobbyking.com/hobbyking/s...idProduct=9493
207g for this 2200mAh battery:
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
With regard to the motor, the reviews say it comes with a motor mount.
I think I'll get the beefier servos. This plane is going to take a beating, seeing as it's going to be a "learning platform" for me.
Old May 24, 2012, 06:26 PM
Joined May 2011
Yeah, You might need up to a 1800 to balance it out. Just remember that the cog is the rear carbon fiber spar. The one between motor mount and the esc receiver box. Go a little nose heavy from there and you should be fine
Old May 25, 2012, 12:55 AM
Syner01 is offline
Joined Jan 2012
See my cheat sheet here
Old Dec 30, 2014, 02:15 PM
r39o is offline
Find More Posts by r39o
Old newb
United States, CA, San Diego
Joined Feb 2003
When will the 900 mm "kit" (vs ARF) be back in stock????
http://www.nitroplanes.com/02a-019-p...white-kit.html
How do you like that for a necropost?
r39o is offline Find More Posts by r39o
Discussion Nitroplanes.com Tech One Pop Wing EPP Kit BACK IN STOCK! Nitro_Nancy Foamies (Kits) 2 Aug 10, 2012 01:22 PM
New Product Nitroplanes.com Tech One Foamie Kits Nitro_Nancy Foamies (Kits) 2 Feb 15, 2012 06:49 PM
New Product Nitroplanes.com NEW Tech One Foamie Kits Nitro_Nancy Product Announcements 0 Feb 15, 2012 03:13 PM
