Old May 17, 2012, 05:49 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
New Product
Isis II
Well What do you think...? this is just a depron rapid Proto of the ISIS II (took 5 Hrs to build) the final Version will be Depron Cored and Kevlar Skinned... and have a tapered Avia sport boom rather than a Straight one...
Let me Know of your Thoughts...?
Done!
My Checklist is:
Hook up Flapperons.
Hook up Elevator
finalise boom fitting and Epoxy in place...Check!
take a FG pull off the Proto Fuse...
Keenan
if your interested PM me to negotiate a Price..as this will go into limited production
And PM me if you would like to Fill one of Four Beta testing Slots...
Keenan smith is offline Find More Posts by Keenan smith
Old May 17, 2012, 07:38 PM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
I think you need a better camera!
MattN is offline Find More Posts by MattN
Old May 17, 2012, 09:21 PM
JimZinVT is offline
Find More Posts by JimZinVT
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
+1 !
JimZinVT is offline Find More Posts by JimZinVT
Old May 17, 2012, 10:01 PM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
Good work! That only took 5 hours from beginning to end?! My last build took 40 hours, and I didn't have to cut cores or make a fuse. What's the all up weight? Also, I thought that depron couldn't be hotwired. Was I wrongly informed or did you use a different method to cut the cores?
Brandon
bwill6 is offline Find More Posts by bwill6
Old May 17, 2012, 11:14 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Most depron is XPS and can be hotwired. Double check before doing.
Also, typical depron is ~15 psi compressive strength so not the best shear web. Certainly usable as a core with some creativity. An issue is getting the stuff in a thick enough batch.
samc99us is offline Find More Posts by samc99us
Old May 18, 2012, 12:40 AM
JamesCH is offline
Find More Posts by JamesCH
Falling with style
JamesCH's Avatar
Thailand, Bangkok
Joined Oct 2011
Originally Posted by mattn View Post
i think you need a better camera! :d
+1
JamesCH is offline Find More Posts by JamesCH
Old May 18, 2012, 05:35 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
finally a finished plane from K, but still same blurry photos :P as always.
Hey K whats the EDA of that plane?? seems kind of flat for a DLG. And what about the boom lenght??
I hope you get an actual video of the maiden flight and some detailed pics on those wings
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old May 18, 2012, 09:48 AM
Joined Dec 2010
Old May 18, 2012, 09:54 AM
Joined Dec 2010
Brandon
i cut Panel blanks....then i use Airfoil temlates to Sand the cores To shape
EZ
Well,
The W/S is 1500mm
The Length including Fuse is 1000mm (Minus Rudder)
the Boom Length is 600mm long..
and the Protos pod is depron built up..... (and will be pulling some PTEG pods from a new Plug of the same shape..
The Airfoil is undisclosed.... (gotta keep some secrets...)
Yeah i'll get some Video (just waiting on Mother nature...) and my action cam is Charged and Waiting...
and What Does EDA mean...?
i still have to do some linkages.....
id Say Right Now She weighs in around 150- 160g I will Weigh her Later...
Keenan
Old May 18, 2012, 02:18 PM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
hehehe k's secret airfoil, "tremble Dr drela, tremble" ehehehheeh come on K that is another depron sanded wing I can see that even with your blurry pics your secret is out and screaming
150cm and 150g is that the empty weight??? ready to fly??? if it is ready to fly you even beaten the super gee with 220g
waiting for the video opc orn:
EZ
PS. strange that you do not know what EDA means
Old May 18, 2012, 02:24 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Google "equivalent dihedral angle" and you'll find some calculations for figuring tail volume, moment, and dihedral to determine spiral stability.
It's pretty important for DLGs. My guess is you're around 4ish.
tom43004 is offline Find More Posts by tom43004
Old May 18, 2012, 02:46 PM
Joined Dec 2010
EZ
I'd Say around 160g ARF (minus battery... )
Dang my secrets Out Oh well.... But While Sanding i Do use Templates ..... to make sure that it complies to the foil i Selected...
Old May 18, 2012, 02:55 PM
Joined Dec 2010
Well i like expirimenting First...! Trail and Error is my Favorite Way...
BTW big news the boom is Being Set in Place... so i might get in a maiden tommorow or on tuesday ... Depending on the Weather and if my LHS has a Servo snake thats long Enough for the Elevator...
And for the time Being i slightly oversized the Elev to be on the safe side...
Keenan
Old May 18, 2012, 06:36 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Amazing work K! Your new Isis Glider looks like a winner! All you need now is some good weather for the maiden flight. . . . . .or should I say maiden soar!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Foam Safe Spray paint!
Old May 18, 2012, 06:40 PM
Joined Dec 2010
Yup gimme a few days and She'll Be flyin..
Wanted OLY II or OLY II S clayrb Aircraft - Sailplanes (FS/W) 11 Jun 25, 2012 08:54 PM
Build Log Isis G2: Ultralight 3D boredom.is.me Scratchbuilt Indoor and Micro Models 14 Apr 05, 2012 12:23 AM
New Product Now available: Cox Black Widow II - Golden Bee II - Venom II xenalook 1/2A Planes 0 Mar 22, 2012 02:09 PM
Discussion Here's hoping Carter II brings Reagan II 7oneWo1f Life, The Universe, and Politics 16 Jan 14, 2012 02:18 PM
Sold OS 91FS-II SURPASS II with Pump ton2di Aircraft - Fuel - Engines and Accessories (FS/W) 1 Sep 11, 2011 08:17 PM
