Nov 02, 2003, 06:33 PM
Ravenna,Nbraska
Joined Sep 2003
Cessna 185 with floats in foam project..
I would like to take this opportunity to tell all of my building technique regarding scratchbuilding a foam scale model..
A lot of the material I will present will be review to some of the older gents, but hopefully it may answer some questions that some of our newer modelers may have.. I hope to be helpful and entertaining, and thank you in advance for your attention..
I decided on the Cessna 185 with a 33 inch wingspan and would hope to fly in with a GWS 400C and three blade prop.
Step 1....Making the patterns
I start by making a clear transparancy of the 3 view drawing of the Cessna on my copy machine and then use an overhead projecter to project the image onto a piece of poster board hung on the wall and trace the outline..This enlarged outline is then cut out with scissors, and becomes my pattern.. By backing up or going forward with the projector on tshe floor, I can make the image larger or smaller until the correct size appears..
The next 4 photos will illustrate...
