Old May 17, 2012, 04:53 PM
flyman065 is offline
Find More Posts by flyman065
Joined May 2012
where do I string the antenna wire on the LT 711
Just bought the LT 711. after I remove the canopy I found the antenna coiled up on the battery in the nose of the heli, is this right? my other one ( 9053) the antenna shoots out to the tail, or was this done for shipping reasons ??
flyman065 is offline Find More Posts by flyman065
Old May 18, 2012, 03:48 PM
pigmypuncher is offline
Find More Posts by pigmypuncher
pigmypuncher's Avatar
United States, TX
Joined Oct 2010
That's were mine was also. I tried letting it hang out the bottom of the canopy thinking it would increase my reception. Unfortunately it seemed to have the opposite effect, and started to have intermittent connectivity issues <40 ft. I put it back into a coil were it was before I messed with it, and the issue went away... YMMV.
pigmypuncher is offline Find More Posts by pigmypuncher
Old May 18, 2012, 03:57 PM
SubtleT is offline
Find More Posts by SubtleT
Vroooom putta putta putta
SubtleT's Avatar
Joined Feb 2011
As far as I can tell from some pictures this is a 2.4GHz heli.
That "coil" you see probably isn't very long. Most likely it is really shaped with just a couple of bends in order to function as a hillbilly "diversity" antennta, to avoid being too directional. Straighten it out and you have a detuned whip antenna instead.
The length from bend to bend should probably be a hair over 3cm so that each straight run can function as a 1/4-wave monopole at 2.4GHz.
SubtleT is offline Find More Posts by SubtleT
Question Hawkspy LT-711 Parts (tail assembly) pigmypuncher Beginner Training Area (Heli-Electric) 2 Jun 22, 2012 08:53 PM
Help! Hawkspy lt-711 Scottkooi Beginner Training Area (Heli-Electric) 3 Mar 26, 2012 12:27 PM
Discussion LT-711 Skyhawk falls on side during lift off cbishop10 Beginner Training Area (Heli-Electric) 21 Jan 14, 2012 04:49 PM
New Product LT-711 &LT-712 Hawkspy 3CH RC Helicopter RTF w/ Built-in Gyro, Spy Camera thercguy Coaxial Helicopters 1 Dec 11, 2011 10:48 AM
