Old Oct 06, 2012, 10:41 PM
littledvl is offline
Find More Posts by littledvl
Joined Mar 2012
Originally Posted by Firehawk548 View Post
Chip nice meeting you guys today and i got to see this boat run first hand and the 47.8 run looked great
You need to get a revolt to be in this thread
Assuming no rain tomorrow ill get the revolt in the water with the m545 and hopefully get a video.
littledvl is offline Find More Posts by littledvl
Old Oct 08, 2012, 09:29 PM
Travis MCH is offline
Find More Posts by Travis MCH
Travis MCH's Avatar
United States, TX, New Braunfels
Joined May 2011
Can you please tell me where you found the Octura M545 prop and what batteries are you using? That's some serious speed ouf of that boat. Great job!
Do you have any other mods or upgrade on it?
Travis MCH is offline Find More Posts by Travis MCH
Old Oct 09, 2012, 02:21 PM
chipgibbs is offline
Find More Posts by chipgibbs
ChipG
Manassas, VA
Joined May 2008
Props & stuff
The M545 I got from Kintec, the batteries are Hyperion 4s 4200mah.
The only other mods are scuffing the bottom with 1000 grit and adjusting the strut to 0 degrees.
Chip
chipgibbs is offline Find More Posts by chipgibbs
Old Oct 09, 2012, 07:25 PM
Joined Mar 2012
I also got the M545 from kintec. I have no mods to my revolt but the prop, will sharpen my rudder, strut and turn fins this week and run it again over the weekend, running on 2- 2s 5000mah 40c sky lipos. I will bring my turn fins up also as they were catching some last time out..
This run I hit 44.2mph
Stock revolt 30 with m545 prop (0 min 49 sec)
Old Oct 10, 2012, 05:59 AM
ChipG
Manassas, VA
Joined May 2008
Dvl
Where are you runnin lildvl? Boat looks pretty good to me.
I recieved a new Leopard 4074 & Seaking 180 last night. I was thinking about putting it in the Revolt but, it may be a bit too much....and not quite enough for the new Cheetah.
ugh
Chip
Old Oct 11, 2012, 08:55 PM
Joined Mar 2012
A pond about 10min from my house, first time running there.
I think my revolt is close, will have it shaprned and set up to run on saturday or sunday and see if i can get to the 47+ range
Old Oct 12, 2012, 05:26 AM
ChipG
Manassas, VA
Joined May 2008
Revolt etc
It's nice to have a pond close by, The Centreville pond is very close to me but, you have to pre-arrange to run boats there. I think the weekend of the 20th is the last time this year we can run.
Supposed to be in the 20s tomorrow morning.
Old Oct 12, 2012, 05:35 PM
Joined Mar 2012
I got quite a few close by but no one around me runs rc boats.. Me and my dad are hoping to do some runs this weekend.
If you dont have a use for the 4074 & seaking 180, let me know, i have another motley crew hull that it will work in
Old Mar 10, 2013, 07:38 PM
RcCrawler82 is offline
Find More Posts by RcCrawler82
Houston, we've had a problem.
RcCrawler82's Avatar
United States, CA, Glendale
Joined Feb 2013
looks like this thread just dropped, was wondering how u guys were all still likeing your revolt 30's and if there was any more comparisons to the impulse 31. which one u guys think is a better boat
RcCrawler82 is offline Find More Posts by RcCrawler82
Old May 25, 2013, 10:19 AM
mannytx is offline
Find More Posts by mannytx
Joined Jan 2012
Hi, Mike grimracer zaborowski
I think there are serious problems with the design of the rudder, the water pickup hole is very high, need 1 inch below ( the water pickup hole should be no less than one inch below the keel) very small rudder, a minimum recommended length is 1 times the diameter of its support below Lx 15% 30”x15% = 4,5” minimum. (REVOLT 30 ONLY 4")
LVC not protects the batteries 2,9v
Water cooling system it should go through the esc first because it won't heat up the water enough to make a difference on the cooling on the motor. But if you run it through the motor first it will heat the water and then the water will heat the esc
thank you very much
Manny
mannytx is offline Find More Posts by mannytx
Old May 25, 2013, 10:51 AM
dobydog6507 is offline
Find More Posts by dobydog6507
Joined Oct 2011
How is this a serious problem??? Where do you get your formulas from?
dobydog6507 is offline Find More Posts by dobydog6507
Old May 26, 2013, 07:16 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Formula or not, it seems to run great on the stock rudder and doesn't seem to need a longer one at all.
What do you mean the LVC doesn't protect the batteries?
wparsons is offline Find More Posts by wparsons
Old Jun 03, 2013, 09:13 AM
metoo is offline
Find More Posts by metoo
Joined May 2008
I don't know about the rudder, but the stock ESC makes me uncomfortable as well. The voltage warning is at 12V and cut-off is at 11.6V (according to the manual). On my cars, I have my LVC at 3.1v/cell, so that would be 12.4 for a 4S pack. For that reason, I bought a Seaking ESC and sold the factory ESC. That said, many people have used the factory ESC with no complaints.
metoo is offline Find More Posts by metoo
Old Jun 03, 2013, 10:20 AM
Diesel6401 is online now
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
The stock esc is Very good! Smooth throttle and very reliable. For that reason they are so popular and heavily used by racers. The aquacraft electronics (60esc, 2030kv and 1800kv motors) are the best provided in a rtr by my experience. Lack of programming on the stock esc is the only negative I have.
Diesel6401 is online now Find More Posts by Diesel6401
Old Jun 03, 2013, 09:12 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If you're relying on the LVC at 3.1v/cell it's already too discharged IMO. The best safeguard is to time your runs.
If the packs are under 3.7v/cell resting that's more than I like.
Discussion ReVolt Jet Design Constructive Input geostomp Electric Ducted Fan Jet Talk 75 Sep 14, 2014 02:32 PM
Build Log ReVolt Rush (Full Composite 90mm 5lbs auw) geostomp Electric Ducted Fan Jet Talk 314 Oct 14, 2012 02:04 PM
Cool ReVolt 70mm Flyable Concept @ 3000watts maiden video added gundamnitpete Electric Ducted Fan Jet Talk 43 Oct 02, 2009 02:34 PM
Discussion Arrogance breeds revolt. rcjetpilot Life, The Universe, and Politics 13 Aug 03, 2009 11:49 AM
Build Log ReVolt Winkman1 Scale Boats 15 Apr 06, 2009 05:17 PM
