Old Sep 04, 2012, 10:02 AM
3b3b is offline
Find More Posts by 3b3b
Joined Jul 2012
Between one 4s vs two 2s, I've had better overall results with two 2s side by side right in the middle of the tray.
3b3b is offline Find More Posts by 3b3b
Old Sep 04, 2012, 08:24 PM
brad1161 is offline
Find More Posts by brad1161
Joined Jul 2012
Originally Posted by Diesel6401 View Post
doubt it will run on 3s unless you change the esc. The stock lvc is preset and set for 4s.
I would disagree, I did a battery testing thread and the results heavily varied.
What battery did you like the best?
brad1161 is offline Find More Posts by brad1161
Old Sep 09, 2012, 05:29 AM
NYCrcPILOT is offline
Find More Posts by NYCrcPILOT
United States, SC, Little River
Joined May 2002
Tested the R 30 on 3 battery combos. 3S 4400, 2x 3S 2200 in parallel, 2x 2S 3300. All 3 started out fine but started slowing down after 1-2 minutes. Boat handles great!
NYCrcPILOT is offline Find More Posts by NYCrcPILOT
Old Sep 09, 2012, 06:47 AM
Diesel6401 is offline
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Gens Ace packs. I've ran the 2s 5300mah 30c packs in several different boats and they ran great I also have the 4s 5300mah 30c packs I run in parallel in my pursuit and she scoots along rather nicely.
Diesel6401 is offline Find More Posts by Diesel6401
Old Sep 10, 2012, 04:34 PM
homer49 is offline
Find More Posts by homer49
Bob Olson
homer49's Avatar
Granger, Indiana
Joined Nov 2006
scoot?
You are running 2, 4 cell 5300 packs in paralell?? for 10,600 Arent two of them a little heavy?? around 1400 grams? Must abe able to run for a very long time. I thought the pursuit only needed one 4-cell around 4500 - 5000???
homer49 is offline Find More Posts by homer49
Old Sep 10, 2012, 04:35 PM
homer49 is offline
Bob Olson
homer49's Avatar
Granger, Indiana
Joined Nov 2006
Am only asking bcause I have a pursuit on the way and have not yet decided on packs, or a high output charger for that matter.
Old Sep 10, 2012, 04:39 PM
boaterguy is offline
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
Charger wise, just go with something like the accucel 6. It may not be the biggest charger but it's my only one (kinda) and it charges all my packs no problem, even up to 4S 5000mah.
boaterguy is offline Find More Posts by boaterguy
Old Sep 11, 2012, 03:14 AM
lagcisco is offline
Find More Posts by lagcisco
Los Angeles Industry, California, United States
Joined May 2003
This looks like the boat for me!
Question though, can I run this boat in the ocean? With waves? Not too big of a waves.. Also, what about in a canal that is fed into the ocean? Not sure if the canal water is salt-water or not.
lagcisco is offline Find More Posts by lagcisco
Old Sep 11, 2012, 05:26 AM
chipgibbs is offline
Find More Posts by chipgibbs
ChipG
Manassas, VA
Joined May 2008
Running in Salt water
There's a little more maintinance when running in salt water. You've got to clear the cooling system with fresh water and then some WD40. Also the salt will take the shine off your hardware quickly.
I took my R30 to Maine with me and had a blast in the ocean except when I picked up seaweed. This happened several times and the steering goes away completely so, you may have to go get the boat.
ChipG
chipgibbs is offline Find More Posts by chipgibbs
Old Sep 23, 2012, 03:52 PM
ChipG
Manassas, VA
Joined May 2008
Revolt runnin good
Had my Revolt out today at Columbia MD. I put a Voltron GPS in it and clocked 42.6mph on several runs.
I'm waiting on a Grim 45 X 68 to see what a difference it will make.
Good times
Old Oct 01, 2012, 11:50 AM
ChipG
Manassas, VA
Joined May 2008
Grim 45 X 68 lifter
The conditions from last weekend to this past weekend couldn't have been more different. Last weekend I clocked my Revolt at 42.6mph with an Octura X642 and the boat was hard to keep on the water due to the windy conditions.
This weekend I had both the X642 & the 45 X 68 lifter. I ran both, no wind, the X642 ran 42.6mph and the 45X68 ran 42.9. The lifter seemed noticably faster until I looked at the gps. The lack of any ripples on the water really seems to slow things down. Both props are ballanced & sharpened.
Both runs are with a Hyperion 4S 4200mah battery (new) and a Velocity RC GPS. The only adjustments I've made are to raise the strut until it was at "0" checked with a straight edge. I have also replaced the Collet & Flex shaft with OSE parts.
ChipG
Old Oct 03, 2012, 08:22 PM
Travis MCH is offline
Find More Posts by Travis MCH
Travis MCH's Avatar
United States, TX, New Braunfels
Joined May 2011
Hey Guys
I've been flying helis for a couple years now but on occasion run my aquacraft Rio EP.
The Rio is brushed and not real fast so I would like to get a more upgraded faster brushless boat. With all the reviews I've read I've pretty much narrowed it down to the Revolt 30 or the new Impulse 31 V2 from Pro Boat.
Which boat do you think I should get?
Travis
Travis MCH is offline Find More Posts by Travis MCH
Old Oct 03, 2012, 09:17 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The Impulse is a bit more money, but the ESC can handle 6s as long as you prop down. For my money, I would get the Revolt. I've heard they're easier to get handling nicely and are a bit faster out of the box.
wparsons is offline Find More Posts by wparsons
Old Oct 06, 2012, 12:39 PM
ChipG
Manassas, VA
Joined May 2008
Revolt 30 hits 47.8 stock except prop
My Revolt 30 hit 47.8 mph today in Centreville VA. Recorded on gps.
The first run was 46.6 run 2 was 47.8. I did take photos of the gps for internet proof but, only the 46.6 photo came out clear. you can kinda make out the 47.8 if you try.
The prop is an Octura M545.....I doubt you can get much more outta this boat without an upgrade motor & ESC.
Old Oct 06, 2012, 08:52 PM
Firehawk548 is offline
Find More Posts by Firehawk548
Joined Jun 2012
Chip nice meeting you guys today and i got to see this boat run first hand and the 47.8 run looked great
Firehawk548 is offline Find More Posts by Firehawk548
Discussion ReVolt Jet Design Constructive Input geostomp Electric Ducted Fan Jet Talk 75 Sep 14, 2014 02:32 PM
Build Log ReVolt Rush (Full Composite 90mm 5lbs auw) geostomp Electric Ducted Fan Jet Talk 314 Oct 14, 2012 02:04 PM
Cool ReVolt 70mm Flyable Concept @ 3000watts maiden video added gundamnitpete Electric Ducted Fan Jet Talk 43 Oct 02, 2009 02:34 PM
Discussion Arrogance breeds revolt. rcjetpilot Life, The Universe, and Politics 13 Aug 03, 2009 11:49 AM
Build Log ReVolt Winkman1 Scale Boats 15 Apr 06, 2009 05:17 PM
