This thread is privately moderated by JimDrew, who may elect to delete unwanted replies.
Old May 17, 2012, 03:50 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Mini-HowTo
Binding your XtremeLink® system
Here is a step-by-step guide for binding your system (single receiver).
Always start any binding procedure by turning off your transmitter and power off all receivers.
Binding 8 and 10 channel receivers:
  • Apply power to your receiver.
  • When the receiver's LED is flashing RED, press and hold the programming button on the receiver until the LED turns GREEN, and then release the programming button. The LED will now flash orange, indicating it is in binding mode.
  • Press and hold the button labeled PROG on your transmitter module while turning on the power to your transmitter. If you are using an internal module (like an EVO or Profi), press and hold the button on the board while turning on the power.
  • Wait for the LED on the transmitter module (or internal board) to turn green and release the button.
  • The units will immediately bind.
  • The LED on the transmitter module (or internal board) will now be green.
  • The LED on the receiver will now be green.
  • Power off the transmitter and receiver.
  • They are now ready to be used.
Binding a single Nano receiver:
  • When the receiver's LED is flashing, attach the jumper (provided with your receiver) to the port labeled "B" (binding/battery). Leave the jumper on until the LED turns solid, then remove the jumper. The LED will now be flashing fast, indicating it is in binding mode.
  • The LED on the receiver will now be off.
Binding multiple Nano receivers:
  • Apply power to your first receiver.
  • When the receiver's LED is flashing, attach the jumper (provided with your receiver) to the port labeled "B" (binding/battery). Leave the jumper on until the LED turns solid, then remove the jumper. The LED will now be flashing fast, indicating it is in master binding mode.
  • ALL slave receivers must be put into slave binding mode. Attaching the jumper for two seconds and removing it will make the LED turn solid red, indicating the receiver is in slave binding mode. Repeat this process for all slave receivers. Leave the last receiver in master binding mode.
  • The LED on all receiver will now be off.
JimDrew is offline Find More Posts by JimDrew
Found looking for the xtremelink for the multiplex royal evo 9 mykwilwin Aircraft - General - Radio Equipment (FS/W) 1 May 17, 2012 04:01 PM
Discussion Rapier Missile system for Olympics... your Funjet might become a target! Iboxx83 FPV Talk 3 May 03, 2012 08:33 PM
Question How do you price your RTF systems for photo/video? peoples Multirotor Talk 4 Mar 31, 2012 04:52 PM
Sold XtremeLink Futaba 2.4 system mxerman Aircraft - General - Radio Equipment (FS/W) 2 Sep 28, 2008 09:41 AM
Cool XtremeLink radio system Leonardo Slope 2 Sep 11, 2006 08:35 AM
