Netherlands
Joined Sep 2008
It's fun to build and see the result, using torpedo's at this scale is a different ballgame, it took some tinkering to get it working. Next step would be, how she would behave when firing underwater, did again a test to see what would happen, one torp went smooth, the other did not fire, the launched one gave me enough info from the underwater vid to show she can vent the gas quickly.
Manfred. |
Netherlands
Joined Sep 2008
Tom,
Instead of all those electric connections entering the WTC, i've got only one, it could be done with SMD leds, but all those wires could mean points of failure, which you don't have with optical fibers. Made the optic connector and did some testing it's looking promising, pictures. ![]() ![]() At first i had some problems with the fibers, they were heavy and not very flexible, solved that by removing the protecting sleeve, i will seal them off with paint against lightleaks. ![]() This is the optic connector i've made, it contains four leds, two white, one green and one red. The middle thingy is a magnet which will hold the other part tight. ![]() The other part which holds the ends of the optic cables, i've splitted the white lights into two, and a seperate one for the rear upper navlight. ![]() After placing the right resistors and making the electrical connections i could do my lighttest, you can see all different colours which i want to use. ![]() I also made some brass rods for guiding the other connector in the first fase of connecting, once this done the magnet will take over. ![]() ![]() The result sofar, i succeeded in getting more light at the upper navlight, now i have to make the electrical connections watertight, and find a place to get the magnetic switch in. Also made a vid to show how things work in the real live, enjoy.
Manfred. |
| Thread Tools | |
| Build Log HMS Diamond Type 45 1/96 Scale | type45 | Scale Boats | 84 | Mar 22, 2013 06:12 PM |
| For Sale Deans Marine HMS Skirmisher – 1/96 scale | hampboats | Boats (FS/W) | 6 | Jun 08, 2012 03:02 PM |
| Build Log 1/96 HMS York Batch 3 Type 42 | travelling_man | Scale Boats | 1 | Dec 01, 2011 06:52 PM |
| Discussion SSY 1/96 Alfa or Precision Patterns 1/96 Permit | redboat219 | Submarines | 10 | Sep 27, 2011 08:13 AM |
| New Product D&E German 212 1:96 scale instructions & plans | kazzer | Submarines | 0 | Nov 21, 2009 08:55 AM |
