Old May 17, 2012, 06:38 AM
jamesrini is offline
Find More Posts by jamesrini
USA, NJ, West Paterson
Joined Feb 2008
Help!
Dle 55 how can do I use crank pressure for smoke?
I'd like to try and use the crankcase pressure to pump the smoke oil before I spend extra money on a pump. I have the dubro super smoke valve and sullivan check valve. So the question is how do I tap into the crank pressure. There's a fuel line that goes from plastic reed spacer to the carb is this crank pressure ? If so do I just simply unplug one side and use the other to go to the tank or do I use a tee fitting in between the two.
Description:
jamesrini is offline Find More Posts by jamesrini
Old May 17, 2012, 11:58 AM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
"Crankcase pressure" would be tapped from the bottom end. Expect something in the range of 7-10psi or so, and it will be pulse on the downstroke and you'll need the checkvalve. Crank case pressure is a kind of medium pressure. Mufflers are low pressure in the 3psi range, Timed crankcase pressure (i.e. a pressure tap on the opposite side of the crank from a front induction engine's carb) can be in the 15PSI range..
NACA0012 is offline Find More Posts by NACA0012
Old May 17, 2012, 12:15 PM
Joined Feb 2008
Thanks I do t want to drill and tap the case on a new motor so I think I'm gonna just buy a pump. I was hoping that fuel line would make it easy but i found out that the fuel line is sort of a fuel bypass and I can't use it. So pump it is
Thanks for the info.
Old May 17, 2012, 04:15 PM
NACA0012 is offline
Joined Mar 2012
There appears to be a small casting boss with a depression in it on the case just above and to the right of the carb (looking at the engine from the rear) that would be ideal for a pressure tap nipple.
You might ask the DLE people if it can be used for a pressure tap. If they'd sanction its use, your warranty would probably stay intact.
For Sale FS or trade DLE 30 for a DLE 55 scottiesoccer1 Aircraft - Fuel - Engines and Accessories (FS/W) 3 May 02, 2015 07:51 AM
Discussion u-can-do 60 with dle? michael88997 Fuel Plane Talk 9 Apr 26, 2012 12:43 PM
Sold Muffler for DLE 55 never used $45 Plus shipping. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 23, 2012 03:47 PM
Question How Can I Use my Laptop for a Monitor? wannabe FPV Talk 27 Jan 30, 2012 11:52 AM
Discussion How do you use hot glue for long joints? chris1379 Foamies (Scratchbuilt) 30 Jan 10, 2012 04:07 PM
