Old May 16, 2012, 10:58 PM
Marcialtech is offline
Find More Posts by Marcialtech
Marcialtech's Avatar
Joined May 2012
Marcialtech Large 74 inch Flying wing, Modular wing concept .
Hello
I just wanted to share these photos , i was told you guys might like it...
Have you ever wanted a very large Flying wing ? , with more than 6 foot wingspan yet can still fit inside the trunk of your car ???... Well here's a simple design concept that i was working on a few months ago ( see photo ) .
This is just a spur of the moment design concept ( no drawing or template made ), just wanted to see if a modular wing design is a good idea, i wanted it to be put together like LEGO blocks , the angular pattern of the wing separation is made that way intentionally to distribute load stress on the base of the wing , there are no carbon fiber rods or wood dowels on the plane, motor mount is the only place where i used Balsa, the entire Flying wing is made out of half inch pink foam from Home depot.
Wingspan = 74 inch
Weight = 5 lbs
flying weight = 6 lbs ( 8.5 lbs max )
payload = 2.5 lbs
battery 4,000 mah 4 cell 30C
Flight time = 20 to 25 min.
Marcialtech is offline Find More Posts by Marcialtech
Old May 16, 2012, 11:03 PM
fnffishcore is offline
Find More Posts by fnffishcore
fnffishcore's Avatar
United States, MD, Chesapeake Beach
Joined Jan 2011
LOVE IT!!!
How are the wings attached? Do they just pop into place, or are they anchored somehow?
fnffishcore is offline Find More Posts by fnffishcore
Old May 16, 2012, 11:21 PM
Joined May 2012
I insert locking pin on the fuselage to lock the wing in place ... ( look for 6 small white circle on the fuselage )
Old May 17, 2012, 12:10 AM
sawman is offline
Find More Posts by sawman
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Very interesting and well done. Would like to see a flight report and/or video. Looks to be a simple KF airfoil setup. Thank you for sharing.
sawman is offline Find More Posts by sawman
Old May 17, 2012, 09:28 AM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Brilliant concept and execution! Do I see both elevons and flaps? How are the control connections done? How about launching? 5 pounds could be a handful without assistance.
I think you'll get swamped with requests for plans and more details. Great job, Marcialtech. Awaiting more info...
potshot is offline Find More Posts by potshot
Old May 17, 2012, 09:59 PM
Joined May 2012
Here's the video , I recorded this today during my lunch period at work . There are 4 servo on this plane, right now it is only setup as elevon.
Large Flying wing 74 inch Wingspan ( with interlocking modular wing concept ) (5 min 45 sec)
Old May 18, 2012, 07:19 AM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
That is impressive... love the size and design, it looks like a very nice flying wing.
Mark
mthomas is offline Find More Posts by mthomas
Old May 18, 2012, 05:25 PM
gobigdale is offline
Find More Posts by gobigdale
Time To Fly?
gobigdale's Avatar
Gig Harbor, WA
Joined May 2002
Love this thing! great job.
gobigdale is offline Find More Posts by gobigdale
Old May 19, 2012, 01:02 PM
potshot is offline
potshot's Avatar
Joined Mar 2009
What they said - for sure! Dynamite!
Old May 19, 2012, 02:14 PM
Joined May 2012
Thanks!
The plane is very easy to hand launch , there's a handle under the fuselage right at the CG line. It flies and glide even better with an extra pound of payload ( at 7lbs flying weight ) , great for FPV with extra batteries on board for long duration flight.
Old Jun 07, 2012, 05:36 PM
Joined May 2012
This is my new project...not exactly a flying wing so it is somewhat off topic ( sorry ) ..just for FYI anyway, thanks.
Old Jun 08, 2012, 07:22 AM
BravoGolf is offline
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
Marcialtech wing
Nice job, I love it!
Very high cool factor on the design and build. Enjoyed the video as well. Flight characteristics look nice too.
Will you be making any drawings or plans available? I would love to build a 60" version. I hike in the mountains quite a bit and am looking for something "back packable".
Questions:
What size motor and prop are you running on that? I read you get a 20-25 minute flight time on 4000 4S, thats great.
What servos are you using?
Did you ever mess around with any programing of the split elevons? Results?
Thanks for sharing,
BG
The bird wing looks quite impressive as well, would love to see a thread on that.
BTW: I saw a foam manaquin in the background of one of your build photos, do you work in a shop that cuts foam?
BravoGolf is offline Find More Posts by BravoGolf
Old Jun 10, 2012, 09:14 AM
rcta15 is offline
Find More Posts by rcta15
rcta15's Avatar
United Kingdom, England, Portsmouth
Joined Jan 2009
can i ask which aerofoil did you use please?
many thanks RCT
rcta15 is offline Find More Posts by rcta15
Old Jun 11, 2012, 05:33 AM
space 1 is online now
Find More Posts by space 1
USA
Joined Apr 2007
Nice
NICE job watch out pink foam very weak. My 10'ft bird & U2
space 1 is online now Find More Posts by space 1
Old Jun 11, 2012, 07:24 PM
Joined May 2012
Questions:
Thanks for sharing,
BG
Thanks !,
I din't make any drawing or plans for this airplane, this was just a quick build to test how well a modular snap on wing can handle the stress around the wing joints .
The wing is made of 2 layers of half inch pink foam ( silver bottom layer and red top layer ) , and reinforced packing tape on the underside of the wing , there's no carbon fiber ,wood or fiberglass wing spar to stiffen the wing ( i wanted to see how much the wing would flex under heavy load ), as you can see from the video, the wing is holding really well at 6lbs take off weight , it flies even more stable at 7lbs ( 8,000 mah battery on board ).
I used 4 mid size metal gear servo, my thinking here was to mix them later on and see how the plane behave, right now it's only setup as elevon.
G25 motor 710kV from hobbyking and 4s 4,000 mah for normal flight , 4s 8,000 longer flight and 4s 10,000 mah for a really long flight .
I will try to document my next one and post it here when i find a time to build another one, it will most likely be fiber glassed with CF wing spar with larger motor and have a better airfoil.
The mannequin you saw in the background was for my son's super hero plane.
I do have a thread for my giant Ornithopter, you can find it here...
http://www.rcgroups.com/forums/showthread.php?t=1646522
For Sale 72 inch Flying Wing .46 Rimfire RTF LPU Frankensteen Aircraft - Electric - Airplanes (FS/W) 11 Mar 14, 2012 08:15 PM
Discussion 50" Fifty Inch Flying dollar store wing - First wing creapyd Flying Wings 22 Jan 10, 2012 02:03 PM
Discussion Flying wing concept greennomad FPV Talk 12 Nov 25, 2011 07:53 PM
Pretty Stupid Question - Powering My 74 Inch Wing Buzz_Man Flying Wings 16 Oct 20, 2004 09:10 PM
