Old May 16, 2012, 07:52 PM
United States, CA, Signal Hill
Joined Aug 2009
what could cause my align esc not to make the arming beep.
the gyro still blinks and a initializes and the heli still spools up fine,.
but after i unplugged and plugged it back in few times it armed properly
esc and motor are new.
titan trex 450 v2 side to side and tail in circles fusuno canopy (7 min 17 sec)
wc_wickedclown is offline Find More Posts by wc_wickedclown
Old May 18, 2012, 02:03 AM View Post
Cable Ghost
A moderator felt this post violated the following rule: Trolling (Obnoxious behavior). It is temporarily hidden while Cable Ghost edits it. Show it to me anyway.
Old May 18, 2012, 02:09 AM
Joined Aug 2009
Originally Posted by Cable Ghost View Post
stick end point calibration... go to helifreak.com
thank you.
i did set up the end point and programmed it for gov mode etc as per the manual.
Old May 18, 2012, 09:01 AM
United States, CA, Temecula
Joined May 2006
Whats the video have to do with the ?.??
2006rfarmer is offline Find More Posts by 2006rfarmer
Old May 18, 2012, 03:58 PM
Joined May 2012
Originally Posted by wc_wickedclown View Post
thank you.
did you change the trim or sub-trim after calibration? plug it in then trim to low throttle and see if you get the beep. go to helifreak.com
cable guy is allowed to post there! lmao
Cable Ghost is offline Find More Posts by Cable Ghost
Reply With Quote  (Disabled)
Old May 18, 2012, 04:30 PM
Joined Aug 2009
well i figured like this some forums allow certain members to insult other members
and if you do it then there friends join in and help them the rants then the victim gets expelled.
if they had a fare system like rcg when you forward the complaint its dealt with
properly .
instead of accusing me of being the problem i dont use RR or HF
i get all of my help and advice from the good members of rcg and i recommend rcg to all of my friends.
i try to hear no evil see no evil speak no evil to keep the blood pressure down
thank you for the advice kind sir ill give it a try
Old May 18, 2012, 04:32 PM
Joined Aug 2009
not a bad idea
thanks
Old May 19, 2012, 02:56 PM
Joined Aug 2009
i hear the beep it is very low i can barely hear it arming.
the motor seems tight cant figure out way it goes low and high when it wants to
Old May 20, 2012, 06:07 AM
Letchworth, Great Britain (UK)
Joined Jul 2004
The ESC uses the motor as a speaker to make the beep sounds. So, if it's making a very faint beep it could be because the connections between ESC and motor are not very good, or it could theoretically (I've no experience of this) be because the motor is unable to vibrate for some reason -- possibly simply because it's meshed too tight with the main gear.
abenn is offline Find More Posts by abenn
Old May 20, 2012, 08:09 AM
Joined Aug 2009
i have been been trying to resit the motor it is a heart beat tighter then i would like it to be .
i think your correct
thank you
Old May 20, 2012, 11:25 AM
Joined Aug 2009
your tha man
thank you thank you thank you
i reset the motor beeps loud and clear now.
learn something new everyday
Old May 20, 2012, 02:44 PM
Joined Jul 2004
... learn something new everyday
Me too
The correct alignment for a motor is if you can just pass a piece of regular printer/copier paper (80g/m2 in the rest of the world; don't know what it is in USA) between the pinion and main gear. It should come out with sharp regular pleats.
Old May 23, 2012, 10:01 AM
United States, MI, Ann Arbor Charter Township
Joined Mar 2012
Very cool!
I waz gonna say hook up another motor to the esc (not mounted in the heli) to see if the beeps were louder..
But you got it.
Now you just need to mount a sub-woofer on that heli and an MP3 module.
N8LBV is offline Find More Posts by N8LBV
Old May 23, 2012, 10:05 AM
Joined Mar 2012
That's a really sweet looking 450.
I'm still training on my Esky. :-)
I was thinking about building an EXI 450 (plastic edition) from scratch next.
Just an inexpensive beat-it-up bird to try things on.
I see that you had one in the past videos.
Sorry I'm off-topic.
I do that too easily.
Old May 23, 2012, 10:27 AM
Joined Aug 2009
this is my beater
helidirect gave me 2 canopy's for 40 bucks like 20 a piece
kind of hard to have a better with all of the good parts you run across when your not looking for them .
the new align motor in my beater when poof lol a big puff of black smoke.
i got 100 hovers + out of the 10 dolla motor it had before the upgrade .
i really liked the sound of the align motor .
now im looking at buying a align mx motor for my beater
TITAN TREX 450 align motor hickory smoked BURNT UP RC HELICOPTER (3 min 6 sec)
Discussion ESC does not emit any beeps anymore, but works. tlh101 Power Systems 1 May 02, 2012 10:12 PM
Discussion My GWS ESC 25A not arming lijoy_alex GWS (Grand Wing Servo) 3 Apr 14, 2012 07:06 PM
Help! ESCs will not arm using DX7 or my 9C TM8 simages Power Systems 16 Mar 04, 2012 06:03 PM
Discussion my trxxas rustler does not revese only sometimes and makes a loud beeping sound xl.5 Electric Power Cars 2 Oct 11, 2011 06:01 AM
Discussion Suddenly beep, beep, beep is now beep beep, beep beep, beep beep - ESC arm sound chg? turnbui Micro Helis 5 Apr 14, 2008 03:12 PM
