Old May 16, 2012, 05:24 PM
canso is offline
Find More Posts by canso
canso's Avatar
Canada, ON, Toronto
Joined Aug 2008
motor starts spinning at half throttle
I have a 600kv 1500w motor installed with a 80amp turnigy plush esc and a 14.8v 4000mah lipo. Hooked everything up and the motor will not spin until about half throttle. What is wrong here? ESc programming? radio? I have a DX-7. The trim is set in the middle.
Thanks.
canso is offline Find More Posts by canso
Old May 16, 2012, 06:30 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
Thanks.
see if you ESC has throttle calibration.
rcalldaylong is offline Find More Posts by rcalldaylong
Old May 16, 2012, 06:38 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
Is it a car/boat esc or an airplane or Heli esc?
JimNM is offline Find More Posts by JimNM
Old May 16, 2012, 08:55 PM
canso is offline
canso's Avatar
Canada, ON, Toronto
Joined Aug 2008
It is a aircraft ESC. Hobby king plush 80amp with BEC.
Old May 16, 2012, 10:33 PM
Wintr is online now
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
The ESC probably just need to learn the throttle range; take the prop off, if it has one, and power the transmitter at full throttle, then plug in the ESC. It should beep; when it does, move the throttle to minimum, and the ESC should beep its arming pattern.
Wintr is online now Find More Posts by Wintr
Old May 17, 2012, 03:14 AM
keyman923 is offline
Find More Posts by keyman923
Former Futaba employee
Joined Aug 2006
Yes it sounds like it needs the throttle range setting set.
manual under files in case you did not get instructions??
http://www.hobbyking.com/hobbyking/s...3X10239X40.pdf
Page 3
“VERY IMPORTANT !” Because different transmitter has different throttle range, we strongly suggest you using the “Throttle Range Setting Function” to calibrate throttle range. Please read the instruction on page 4------“Throttle Range Setting”.
page 4
Throttle range setting: (Throttle range should be reset whenever a new transmitter is being used)
Switch on transmitter, move throttle stick to top Connect battery pack to ESC,and wait for about 2 seconds
“Beep-Beep-” tone should be emitted, means throttle range highest point has been correctly confirmed
Move throttle stick to the bottom, several “beep-” tones should be emitted, presenting the number of battery cells. A long “Beep-” tone should be emitted, means throttle range lowest point has been correctly confirmed.
The throttle range question sure comes up alot, Maybe we can get a sticky on this, Are they not including instructions anymore?
keyman923 is offline Find More Posts by keyman923
Old May 17, 2012, 07:20 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Thanks.
Set the trim on full off (down).
That's your problem.
hoppy is offline Find More Posts by hoppy
Old May 17, 2012, 10:28 PM
canso is offline
canso's Avatar
Canada, ON, Toronto
Joined Aug 2008
Geesh, I keep forgetting about the full throttle range thing. Thanks for the help.
Question motor spins backwards at start up from time to time 7oneWo1f Power Systems 9 Feb 06, 2012 12:45 AM
Help! STARTING a brushless MOTOR at 0 THROTTLE??? vineet_p Radios 6 Dec 01, 2011 07:55 AM
Help! STARTING a MOTOR at ZERO THROTTLE???? vineet_p Power Systems 7 Dec 01, 2011 07:54 AM
Help! My Heli starts spinning out of control upon throttle up? Bonestockz06 Beginner Training Area (Heli-Electric) 6 Sep 25, 2011 10:28 AM
Discussion Motor won't start to spin until half stick reached rpavich Power Systems 8 Oct 05, 2008 06:11 PM
