Old Oct 08, 2012, 01:29 PM
Sundancer is online now
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Looks a treat Bob. Good luck with the flying, should be a formality though.
Sundancer is online now Find More Posts by Sundancer
Old Oct 08, 2012, 02:53 PM
Colonel Blink is online now
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Nice - I suggest a Blink-O-Matic spec-cam for recoding the first flight!
Colonel Blink is online now Find More Posts by Colonel Blink
Old Oct 08, 2012, 03:29 PM
Raf_Bob is offline
Find More Posts by Raf_Bob
United Kingdom, England, Lancs
Joined Sep 2006
Thanks Colonel. What is this thing? A key cam? "I know nothing".......about such wonders!
Your Ajax is superb. If the Senator is half as good I'll be satisfied. Should be flying it very soon if the weather permits.
Raf_Bob is offline Find More Posts by Raf_Bob
Old Oct 09, 2012, 02:13 AM
Joined Nov 2008
Bob - thanks for the kind words....all I need to do now is learn about trimming..
Re the Spec-cam:
Old Oct 09, 2012, 02:31 AM
Raf_Bob is offline
Joined Sep 2006
Thanks for the lead to this invisible means of spying on my friends!! I'll try to get some video of the early flights (note: I'm not saying First Fright!). May be able to persuade someone to hold my point and shoot but if not I'll strap it across me specs.
Finished weight is 165 grammes 5.8 ozs. No ballast needed for balance at 50%.
Old Oct 09, 2012, 02:39 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Excellent outcome on the weight Bob - Applehoney will have a fit, but for a radio version that is pretty damn good, and spot on for that little motor, practically the same as my Witch and I know how well that flies, so I have no worries at all that yours will be great.
Old Oct 09, 2012, 08:54 AM
Raf_Bob is offline
Joined Sep 2006
Well it's flown! Test glides only as I need a couple of small grub screws for the shaft extension. No obvious problems evident so I'll be applying power next time out.
Old Oct 10, 2012, 06:34 AM
Raf_Bob is offline
Joined Sep 2006
Flew the Senator today. Seemed really calm at home so I dropped everything and raced of to Pendle Hill. Wanted plenty of room and soft landing places. When I got there it was blowing a bit (about force 3?) and I could easily flown a medium size slope soarer! By going low on the hill I found a spot a bit calmer and launched the model with about 2/3 throttle. Flew very well and quite quickly gained height such that I could cut the motor and slope soar. Had several flights totaling about 20 mins. A mixture of power and gliding. The conditions were not ideal for checking the trim but no serious problems showed up. Will probably reduce the rudder throw a bit but nothing more just yet. Now to charge the battery and see what it used.
I wish I could show you some pics but the only "arrival" I had was when trying to manipulate a camera whilst flying low enough to show something. Got a few shots of empty sky though.
One thing I'd appreciate is your comments on this prop. Do they usually bend back like this? It's a GWS 6X3 and works fine. There are a few stress marks around the root but no other signs trauma. It's mounted on a home made motor shaft extension. I know the o-ring is not on correctly but that was an oversight when taking the shot, it didn't fly like that. Anyway I hereby present my Senator as finished, flown and ready for the build-off day of judgment! Thanks to all who have helped with advice, encouragement and kind words.
Old Oct 10, 2012, 06:36 AM
Raf_Bob is offline
Joined Sep 2006
Forgot the picture of my prop. Can one add pics to existing posts?
Old Oct 10, 2012, 07:18 AM
brokenspar is offline
Find More Posts by brokenspar
The dog ate my clearance
brokenspar's Avatar
Joined Jan 2004
Congratulations on a nice build and successful maiden flight. The Senator is on my build list, along with about 400 others....
brokenspar is offline Find More Posts by brokenspar
Old Oct 10, 2012, 07:34 AM
Joined Nov 2008
Originally Posted by Raf_Bob View Post
Forgot the picture of my prop......
Eeee!..........That bain't be lookin none too roit moi dear! I would presume that the main concerns would be:
a) One of the blades letting go and causing an unholy mess, plus the requirement to deadstick thereafter
b) Balance - if one blade is bent more than the other, it's CG will effectively be at a slightly different radius to the other, which could cause vibration, and
c) Efficiency - but if it still has enough power to fly, that's a minor issue.
But like you, rightly or wrongly I would have continued flying like that if I had no spare... what's life without a bit of danger?
Old Oct 10, 2012, 07:48 AM
Raf_Bob is offline
Joined Sep 2006
I presume from that you've not had this happen ?? Now I want to know why it happened to mine Is it to do with the way it's mounted or summat?????
Old Oct 10, 2012, 09:20 AM
Joined Nov 2008
I had simply assumed that it happened because the prop was still turning when it landed, tipping over because of the rather odd single wheel arrangement (the Ajax has the correct number of wheels)..... is that not the case??
EDIT: Is the prop saver O ring tight? I'm using the kit that came with the motor, and the prop doesn't feel like it is held anywhere near solidly enough (but it is). If the O ring is pulling against the blade root, that could bend the rather flimsy blades....
Old Oct 10, 2012, 10:02 AM
Raf_Bob is offline
Joined Sep 2006
Yep two wheels good, one wheel funny! But, I fly the Senator without it's "tripping up stick." Over rough ground what use is it? True it does form part of the model's character but that's my excuse for saving a bit of weight.
You may have it there Colonel, you may have it! The O-ring is fairly tight and does pull the roots a little. It's not excessive but I'll turn a bit off the boss and try for a slightly looser fit. May also fit it with a softish rubber band. It's worth a try.
All part of the fettling process eh? It's not only a matter of the flying!
Old Oct 10, 2012, 11:00 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Congratulations Bob - I was never in any doubt that it would fly OK, but it is nice to have it confirmed!
Re the prop; (a) If you try to straighten it, it will break
(b) I would definitely replace it; if it has stress marks it is very likely to let go, and if you lose one blade the vibration will very likely rip the motor out of the model. Don't ask me how I know
Could be too tight an O ring, but I have mine on the Sportster mounted on a rigid prop driver and have had no trouble, so I think that landing with the prop turning and the monowheel undercart may be the problem. The GWS props do have very thin blades, but I have only broken a couple and they were both in "unscheduled arrivals". Worth having a few spares, they are cheap enough.
Build Log KK Gipsy for Britkit build off kkphantom Vintage & Old-Timer Designs 164 Jun 20, 2016 02:58 PM
Build Log Britkit Build Off May 2012-31/12/2012 - Keil Kraft Sportster x1.8 Sundancer Vintage & Old-Timer Designs 66 Aug 17, 2013 10:45 AM
Discussion "Britkit" Build Off April 2012 - 31/12/2012 Sundancer Vintage & Old-Timer Designs 303 Jan 01, 2013 03:47 PM
Build Log "BritKit" Build Off 2012 - Veron Phoenix RFJ Vintage & Old-Timer Designs 37 Jun 08, 2012 05:28 AM
Discussion Model "Build-Off" Like TV Biker Build-off E-Challenged Scale Kit/Scratch Built 171 Jan 04, 2007 07:54 PM
