Old Jul 30, 2012, 03:13 PM
Raf_Bob is offline
Find More Posts by Raf_Bob
United Kingdom, England, Lancs
Joined Sep 2006
Originally Posted by Sundancer View Post
I get a bit more than that in the Witch Sparks with a GWS 6 x 3 I got 5 amps/35 watts, in the Sportster with a 5 x 3 GWS 3.5 amps/25 watts. You should have plenty for the Senator at 6 ounces with that set up Bob.
Thanks George. Your post came up just as I'd posted my reply to Sparks. When I've tested this outfit (tomorrow) I'll let you know what I get.
Raf_Bob is offline Find More Posts by Raf_Bob
Old Jul 30, 2012, 03:48 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Note that SD squeezes a little more with a gws 6x3, so you will have enough I think. Different props and batteries will all affect your wattage readings somewhat.
I use 5x3 gws E props on models with the 1811 that weigh up to 5/6 oz, for 6 and above I find the 6x3 TGS sport work really well and still stay within the range of a 6A esc on a 2s lipo. Always worth putting them on the wattmeter just to see what the static power levels come out like.
The flight levels of load / power usage should generally be a little lower from the static measured value once the prop unloads a little in normal flight. You should be able to tell just by holding the model with a WOT, if its going to have enough wallop, the wattmeter just helps you to avoid overloading your system components
sparks
sparks59 is offline Find More Posts by sparks59
Old Jul 30, 2012, 04:38 PM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
...if you've experience!! Unfortunately, I am more used to a hopped-up EasyStar which is putting out almost 200W..... so the 1811 seems to create a mere zephyr. Good job the Ajax (currently) weighs a bit less than the kilogramme and a bit of the foamie!!!
I will be putting the Wattmeter on the Ajax soon...
Colonel Blink is offline Find More Posts by Colonel Blink
Old Jul 31, 2012, 08:30 AM
Raf_Bob is offline
Joined Sep 2006
A readout from my watt meter. 6x3 prop. Maximum power on full charge was about 24 watts.
I'll mount the stuff in the model now and see how (if) it goes.
Old Jul 31, 2012, 09:30 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
24 watts should equate to 60+ watts per pound if the model is 6 ounces, believe me that will be plenty for a model like the Senator.
How long into the run was that reading? It was just that the voltage looked a little lower than I would have expected.
Sundancer is offline Find More Posts by Sundancer
Old Jul 31, 2012, 09:35 AM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
I'm guessing it was well into the run, unless your battery is less than healthy!
Even so, as George says, there still should be plenty enough oomph to fly the senator at 60w/lb
sparks
Old Jul 31, 2012, 12:24 PM
Raf_Bob is offline
Joined Sep 2006
I didn't time it but I would think around 2 mins. total after several stops and starts. I'll do another run and be a bit more "scientific" about it. Putting finishing touches to the model now but I may chicken out of the logo! The text style I like would be too difficult to do in tissue as it's rather flimsy script. Others would be easier I know but I don't have a "feel" for anything else yet.
Thanks for your replies. I'd never have got this far without the advice and encouragement you lot have given me.
Old Aug 08, 2012, 01:36 PM
Raf_Bob is offline
Joined Sep 2006
Nearly there! Noseblock to sort out and decor for wing. As seen here it weighs 5.4 ozs and balances on rear spar.
Old Aug 08, 2012, 01:39 PM
Raf_Bob is offline
Joined Sep 2006
Nearly there. Noseblock to sort out and possibly a logo for the wing. 5.4 ozs and balances on rear spar.
Old Aug 08, 2012, 04:49 PM
bigisbest is offline
Find More Posts by bigisbest
United Kingdom, Minehead
Joined Oct 2011
Its looking realy good Bob, cant wait to here how it fly's.
bigisbest is offline Find More Posts by bigisbest
Old Aug 08, 2012, 05:12 PM
brokenspar is offline
Find More Posts by brokenspar
The dog ate my clearance
brokenspar's Avatar
Joined Jan 2004
Neatly done, looking good...
brokenspar is offline Find More Posts by brokenspar
Old Aug 09, 2012, 02:17 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
Weight and CG sound to be fine Bob, should be a guaranteed flier. I'll put in a request for some calm weather for you!!
Old Aug 09, 2012, 02:33 AM
Raf_Bob is offline
Joined Sep 2006
Thanks George, the weather will be the major factor now I think.
Old Sep 07, 2012, 02:25 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Hi Bob, just bumping your thread back up and wondering if you are any closer to that first flight?
Old Oct 08, 2012, 01:43 PM
Raf_Bob is offline
Joined Sep 2006
Well, it's finished at last. Just awaiting a couple of grub screws to secure the motor shaft extension and we'll be ready to fly.
George, sorry to have missed replying to your last entry, I was away from home and failed to see it when I returned. I'll post a little more info. when I've balanced it and can give a final weight.
Build Log Britkit Build Off May 2012-31/12/2012 - Keil Kraft Sportster x1.8 Sundancer Vintage & Old-Timer Designs 66 Aug 17, 2013 11:45 AM
Build Log KK Gipsy for Britkit build off kkphantom Vintage & Old-Timer Designs 150 Mar 30, 2013 09:37 AM
Discussion "Britkit" Build Off April 2012 - 31/12/2012 Sundancer Vintage & Old-Timer Designs 303 Jan 01, 2013 04:47 PM
Build Log "BritKit" Build Off 2012 - Veron Phoenix RFJ Vintage & Old-Timer Designs 37 Jun 08, 2012 06:28 AM
Discussion Model "Build-Off" Like TV Biker Build-off E-Challenged Scale Kit/Scratch Built 171 Jan 04, 2007 08:54 PM
