Old Jul 06, 2012, 01:05 AM
Sundancer is offline
Find More Posts by Sundancer
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Originally Posted by Applehoney View Post
> What did the big one weigh - and did it have much lead in the nose?
Aww.... c'mon now George, get real! Can you remember what one of your models weighed 56 years ago .... or how much lead you poured into the nose? I doubt I weighed the airplane and certainly not the ballast. Wasn't heavy, I guess; I had a comment from Britland three weeks ago from someone who said he was 'mesmerised' watching a WS cruising around over a contest site recently.... brings a warm feeling after so many years.
No Jim, I can't remember - but I do have lots of carefully preserved tatty little notebooks in which the details were recorded. Very anally retentive I know, but fun to look at sometimes.
You are right about the warm feeling, I get great pleasure every time I see or hear of someone having built and enjoy one of my designs, it has to be one of the best kicks in modelling.
Sorry Bob, back to the Senator!
Sundancer is offline Find More Posts by Sundancer
Old Jul 06, 2012, 01:20 AM
Raf_Bob is offline
Find More Posts by Raf_Bob
United Kingdom, England, Lancs
Joined Sep 2006
No problem, I enjoy the posts even if they are a bit of a diversion.
Raf_Bob is offline Find More Posts by Raf_Bob
Old Jul 24, 2012, 12:04 PM
Sky Jiver is offline
Find More Posts by Sky Jiver
Sky Jiver's Avatar
United Kingdom, England, Gt Man
Joined Jul 2012
I had a f/f Senator way back and wound the rubber motor by holding the rear dowel with my feet whilst laying on the ground, can you picture it ?
Sky Jiver is offline Find More Posts by Sky Jiver
Old Jul 24, 2012, 02:43 PM
Raf_Bob is offline
Joined Sep 2006
Ha Ha, I couldn't even get down onto the ground now! Well, if I did I'd never get up again. Still plowing sloooowly on with mine. The time of year presents too many other things to do, but progress is being made. One thing that disappoints a bit is that the nose will have to be blunted somewhat as the motor is too short to reach the original prop position without sticking out like a carbuncle. I'd like to have retained the profile as designed. Maybe a longer prop shaft could be fitted but that's unknown territory for me.
Old Jul 24, 2012, 03:38 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
Bob; for the princely sum of 1.95 you can get a collet fit prop adapter and spinner for the 2 mm shaft on your 1811 motor which will give a longer shaft that the "prop saver" option - see http://www.brchobbies.co.uk/?page=sh...tName=Adaptors. I have used this on the Sportster - see photo. Provided you make the hole in the nose block a good fit around the prop driver, you don't run much risk of bending the shaft in a whoopsie. You will need to ream your GWS 5 x 3 or 6 x 3 out a bit too fit on the shaft, but this isn't difficult.
Old Jul 24, 2012, 09:00 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
I fitted (probably the same) prop adaptor with the 1811 motor, on my Coupe recently for precisely the same reason. Seems to work well, but as George mentions, the small props do need reaming a little.
sparks
sparks59 is offline Find More Posts by sparks59
Old Jul 29, 2012, 12:50 PM
Raf_Bob is offline
Joined Sep 2006
The Senator is well advanced now as you can see from the pic. I backtracked re the elevator as it seemed too big. Converted it to single sided. Covering is not quite finished but not far off. I want to put a small "Senator" logo on the wing. I think it will be made from tissue following the technique of cutting through a printed sheet. Have yet to track down a font and style I like. Final thing will be the nose block. As seen here with servos fitted but no other "gubbins" is 85 Grms. That's about the weight of a good free flight version.
Old Jul 29, 2012, 12:53 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
That looks absolutely great Bob, you must be well pleased with it, I know I would be!
Old Jul 29, 2012, 12:57 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Almost there Bob. Looks great too!
sparks
Old Jul 29, 2012, 02:29 PM
Colonel Blink is offline
Find More Posts by Colonel Blink
So I'M meant to be in control?
Colonel Blink's Avatar
Ilkley, West Yorkshire, UK
Joined Nov 2008
Looks superb - and great idea of using black for the cockpit! I think I'll be using that on the Ajax....
Colonel Blink is offline Find More Posts by Colonel Blink
Old Jul 30, 2012, 12:33 AM
Raf_Bob is offline
Joined Sep 2006
Thanks for the appreciative comments from all. I can't claim originality re the cockpit covering though. There's a great thread on ff Senator's on the small flying arts website and I saw the idea there. It struck me as simple, neat and a lot easier than fiddling with transparent plastic which I always find a total pain to do neatly!
Old Jul 30, 2012, 11:50 AM
Raf_Bob is offline
Joined Sep 2006
I've a question re the power setup for this model. 1811 motor, 2s lipo, 6x3 slow fly prop, 10amp ESC. I'm just about to test this lot on the bench and wonder what sort of power output to expect. Expecting model to weigh around 6 ozs. so I imagine something around 25 watts would do. If anyone would care to comment please.
Old Jul 30, 2012, 12:58 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
According to my dodgy calcs from a similar set up, you are near enough at 25W Bob
sparks
ran it in webocalc,
28W, 2s 3.9A with a 6x3
Old Jul 30, 2012, 02:07 PM
Sundancer's Avatar
South-west France
Joined Sep 2007
I get a bit more than that in the Witch Sparks with a GWS 6 x 3 I got 5 amps/35 watts, in the Sportster with a 5 x 3 GWS 3.5 amps/25 watts. You should have plenty for the Senator at 6 ounces with that set up Bob.
Old Jul 30, 2012, 02:11 PM
Raf_Bob is offline
Joined Sep 2006
Thanks Sparks. Last thing I flew with elektrik was an easy glider and I just guessed at the motor/battery/prop combo. It flew(flies) ok but it wasn't a very sensible approach really. Have since acquired a watt meter so can now be a bit more "professional". I'll now stuff all the bits into the plane and soon (I hope) find out if it's got enough grunt to fly.
Build Log KK Gipsy for Britkit build off kkphantom Vintage & Old-Timer Designs 176 Jul 10, 2016 11:29 AM
Build Log Britkit Build Off May 2012-31/12/2012 - Keil Kraft Sportster x1.8 Sundancer Vintage & Old-Timer Designs 66 Aug 17, 2013 10:45 AM
Discussion "Britkit" Build Off April 2012 - 31/12/2012 Sundancer Vintage & Old-Timer Designs 303 Jan 01, 2013 03:47 PM
Build Log "BritKit" Build Off 2012 - Veron Phoenix RFJ Vintage & Old-Timer Designs 37 Jun 08, 2012 05:28 AM
Discussion Model "Build-Off" Like TV Biker Build-off E-Challenged Scale Kit/Scratch Built 171 Jan 04, 2007 07:54 PM
