Old May 16, 2012, 01:27 PM
Electrofish is offline
Find More Posts by Electrofish
United States, FL, Stuart
Joined Apr 2012
Propeller & battery size questions
I am outfitting an Aeolian 1010 watt, 850 Kv motor. 6 - 24 v. on an estimated 6 lb all up weight Super Hots.
The manufacturer specs 13 x 10, 14 x 7 and 14 x 10 props.
Can I use a 13 x 8 or a 12 x 10 prop?
Also, IYO, can I run on 4 cells , or should I run on 5?
Electrofish is offline Find More Posts by Electrofish
Old May 16, 2012, 03:48 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
C4250 850kv ?
Usually the 3 prop sizes are related to the number of lipo cells. So the 13 x 10 is probably for 6s, the 14 x 7 for 5s, the 14 x 10 for 4s, (these are guesses).
Running a smaller prop on less cells is not a problem, just a bit of a waste. You probably won't get much rpm on 4s, but the current will be low and safe.
eflightray is offline Find More Posts by eflightray
Old May 17, 2012, 08:22 AM
Joined Apr 2012
Yes the C4250, 850 KV.
Thanks for the input.
Discussion Battery size and Propeller Size Help!! jstang50 Batteries and Chargers 11 Sep 26, 2014 01:46 PM
Discussion ELEV8 propeller size ogt Hoverfly Technologies 4 May 02, 2012 11:20 PM
Question Sizing Jet to Batteries question ndamico Electric Ducted Fan Jet Talk 6 Mar 24, 2012 06:13 PM
Discussion Minimum size propeller for hexa and question about my setup. Reginak Multirotor Talk 6 Feb 16, 2012 06:22 AM
Help! Which size/propellers for quad nitramf Multirotor Talk 1 Dec 25, 2011 04:32 PM
