Old May 16, 2012, 08:16 AM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
Fuel Proofing
My question is two coats of Aerogloss Sanding Sealer sufficent for fuel proofing?
Yes I know I can also use thinned 30 min epoxy but I am asking about the AeroGloss Sanding Sealer because it is much thiner, like water I was intending to apply two coats not sanding after the second coat.
Thanks Tom
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old May 16, 2012, 08:26 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
I don't know I've either used dope or epoxy
jetmech05 is offline Find More Posts by jetmech05
Old May 16, 2012, 08:32 AM
Joined Mar 2012
I believe that the Aerogloss Sanding sealer is some kind of Dope.
Old May 16, 2012, 06:35 PM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
With dope based finishes, you need to keep applying enough coats that the surface starts to develop a sheen when held up to the light.
Usually I thin the first couple of coats heavily with acetone (because its cheap compared to dope thinners) so they'll soak deeply into the wood. That penetration provides a nice mechanical bond for subsequent coats to adhere to
NACA0012 is offline Find More Posts by NACA0012
Old May 16, 2012, 07:48 PM
Jacksonville Fla.
Joined Mar 2007
Tom what part of MD? In the late and mid 70's I was in Quantico then went to Andrews AFB. Went back to VA. in 97 where I worked at DCA...often I'd go to BWI to fix something...even been to Martin State airport.
Old May 16, 2012, 09:24 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
Yes, you need more dope on than that. Aerogloss is tricky. I tried cleaning a gun, after shooting Aerogloss clear, with a cheap lacquer thinner. and got grey jello. I had to clean it out with Aerogloss thinner. In my experience, Sig butyrate dopes are compatible with Aerogloss, but try a test panel first.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old May 17, 2012, 07:51 AM
Joined Mar 2012
I put one coat of Aerogloss Sanding sealer on and it doesnt seam to make much of a difference, It soaks in and is realy costly compared to just using BSI finish Cure or Hot Zap 30 min Epoxy, so I wil revert to those because they provide an obvious gloss finish.
Old May 18, 2012, 09:39 AM
NACA0012 is offline
Joined Mar 2012
Tom, ordinary white Elmers GlueAll is nitromethane proof too (and stays flexible for decades). As long as you don't let it get wet with water in the rain, it works great as fuel proofer for firewalls, tank compartments and such.
Help! Glow Fuel Proofing Latex Paint. dterer1 Painting and Finishing Tips 24 Sep 22, 2015 07:11 AM
Question Best fuel proof spray paint livin on edge540 Scale Fuel Planes 13 Apr 23, 2015 11:44 PM
Discussion Best fuel tank system (proof) The search for the best performing tank setups schusterjo Fuel Plane Talk 414 Aug 29, 2012 12:19 PM
Discussion What's a good fuel proof paint? expo The Builders Workshop 10 Dec 02, 2011 09:40 PM
Question Fuel proofing for solar film covering mystifried Beginner Training Area (Fuel) 4 Sep 18, 2011 01:29 AM
