Old May 31, 2012, 01:06 PM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
TRP: Cool !
Be sure to start a build log, preferrably here in the Nurflugel forum. We'd all like to see it.
If you are really looking for a laser cutter, I like FoxLite. Contact Gary there at gary@foxlite.com
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Jun 03, 2012, 12:32 PM
TRP is offline
TRP
Find More Posts by TRP
TRP
TRP's Avatar
United States, CA, Morgan Hill
Joined Jun 2002
The plans arrived yesterday. They look good, but the AMA sent me the wrong 'build article'. They sent me build article 815. These plans are 814-1. Oops. I'll contact them on Monday and see if I can get a new article sent out.
Kent, Thanks for the info. I'm in contact with a laser cutter (cpdude) to see what sort of cost we'd be looking at.
A lifetime ago I started to do a scratch built 110" - XB-49, but ran out of steam on it.I was going to sheet it with balsa and polyspan. I was pretty new to the hobby and many people told me that nothing would stick to the foam cores I had cut and that I should have gone with a different type of foam. I tried applying the covering directly to the foam and it came out okay, but it wasn't what I had in mind. I also wasn't happy with how the motor was mounted. It took a roll of solder on the nose too keep the model from tipping back on it's tails. These two items pretty much killed my momentum on the project. I really like that Brian came up with for his Horten models. This may revive the project in one form or another.
TRP is offline Find More Posts by TRP
Old Jun 04, 2012, 02:36 PM
TRP is offline
TRP
TRP
TRP's Avatar
Joined Jun 2002
By the time you read this, the scanned version of the plans will already be in the hands of a skilled and qualified balsa burner. We'll see what he says.
I was looking at the 110" one yesterday. Anyone know anything about EPP foam? I'd like to figure out if I can scrap the monokote covering and adhere some contest grade balsa skins to the big one. A while back I was told I'd have a hard time getting wood to stick to it. From what I read at the time I should have been okay. Anyone have any experience?
Feel free to PM me off thread, as I don't want to side track Bear's thread.
Thanks!
Ted
Old Jun 05, 2012, 04:35 PM
TRP is offline
TRP
TRP
TRP's Avatar
Joined Jun 2002
Pretty quiet around here.
Does anyone else have these plans? Is anyone planning on building one?
T
Old Sep 18, 2012, 05:48 PM
Blendedwing is offline
Find More Posts by Blendedwing
Blendedwing's Avatar
Joined Jun 2011
I habe built this and finished testing it today.
Have a look and tell me what you think of it.
Northrop YB-35 RC Modell Jungfernflug. (8 min 7 sec)
Blendedwing is offline Find More Posts by Blendedwing
Old Sep 18, 2012, 06:01 PM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
That wing looks great in the air. Well done.
Mark
Quick61 is offline Find More Posts by Quick61
Old Sep 19, 2012, 10:22 AM
Jon Snow is offline
Find More Posts by Jon Snow
You know nothing....
Jon Snow's Avatar
Joined Sep 2011
Ditto what Mark said,nice job.Can you post some details please,weight cog etc.
Regards Stuart
Jon Snow is offline Find More Posts by Jon Snow
Old Sep 19, 2012, 11:22 AM
kleinaberfein is offline
Find More Posts by kleinaberfein
Closed Account
Joined Jul 2009
Schön schön.
Jens
kleinaberfein is offline Find More Posts by kleinaberfein
Old Sep 19, 2012, 03:54 PM
g_munu is offline
Find More Posts by g_munu
_
Joined Aug 2012
Looks really nice. Coordinated turns, no wobbling. She's a smooth sailer for sure
g_munu is offline Find More Posts by g_munu
Old Sep 19, 2012, 04:39 PM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Excellent achievement -- flying qualities appear flawless.
This may of course be the pilot as well as the aircraft.
And yes - more details please. The mechanism and programming for the controls would be most interesting.
HerkS is offline Find More Posts by HerkS
Old Sep 20, 2012, 07:33 PM
Joined Jun 2011
Well, here is some information:
AUW is 55g.
The COG is located at 47% of the root chord, which corresponds to 7% Static Stability Margin.
The controls are based on Spektrum 7DX sender and Spektrum AR6410L receiver equipped with two additional AS2000LBB servos.
The receiver is programmed as Delta, and its servos control the right side Northrop split flap. The two external servos control the left side.
The upper split flap surfaces are controlled as delta surfaces. The lower split flap surfaces are controlled through a number of server mixes.
The counterrotating engines and propellers are from Silverlit, the toys company.
The accumulator is a ThunderPower 325mAh, 65C.
Does that help?
Old Sep 24, 2012, 12:17 PM
Joined Jun 2011
My small model (see video in the thread) has 4° at the wingtips as measured against the reference line, but the reference line is parallel to the imaginary tarmac. The root chord is 9° above that reference line. So the total twist is 13°. Ok that may be more than strictly required, but I want to fly this ship also Indoor, at very low speeds, and there I need very high angle of attack. It all depends on how fast you want or need your model to fly.
Old Sep 24, 2012, 12:54 PM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
Love to see you fly indoors!(aircraft hanger?)
Post the video when you do.
Regards Stuart
Old Sep 26, 2012, 04:56 PM
Joined Jun 2011
Well, you are perfectly right.
The airplane trimmed as you see in this video will never be able to fly in a gym.
However, flying wings are notorious for needing plenty of accurate trimming.
This is what I have been doing in the last ten days. I am not done yet, but the indoor season starts in about four weeks. Based on the progress so far, I am cautiously optimistic I will be ready by then. There is an incredible number of adjustments that I have made, and they all bring some to the desired result.
A few days ago I reached this much progress:
Northrop YB-35 - RC Model Scale 84:1 (4 min 15 sec)
Today it was already much better, but I have no video to show yet.
I will keep you guys posted.
Old Sep 26, 2012, 05:01 PM
Joined Jun 2011
By the way for those who asked: here is the Servos layout.
Build Log 35" Xb-70 agriebel Pusher Prop Jet Models 128 Jul 29, 2012 11:06 PM
Discussion looking for Northrop XB-35 Plans tlh101 Scale Kit/Scratch Built 10 Nov 08, 2011 07:19 PM
