Old May 15, 2012, 07:25 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Xb 35 ?
Just scanned a plan set for an XB35 From Model aviation circa '96
Dunno on the appropriateness of this. So it's only here as a Wee jpeg.
Also a couple of piccies of a semi recent and Exquisite xb35 model
Bare is offline Find More Posts by Bare
Old May 15, 2012, 07:55 PM
HerkS is online now
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Interesting construct Bare
Can you read the dimensions. The resolution of the picture is not good enough for me to read the fine print
Thanks - Herk
HerkS is online now Find More Posts by HerkS
Old May 15, 2012, 09:55 PM
Bare is offline
Canada
Joined Nov 2000
OK; I have good resolution images.. but discretion seemed the best path.
It's of 1/32" ! scale.
Original was a BIG plane.
wingspan: 64.5"
length; 17.5"
wing area ; 562.5 square inches
weight: : 46 oz ,
albeit using 4 Peck 'silver streaks' (ersatz S400's I would imagine) and 7 1500 NiCad cells
Even so the wing loading is just under 12oz /ft
Oddly, this model/build article used 1/32 sheeting which imo is too fragile/ thin.. legacy of the nicad cells and the cast iron motors I suppose.
The Lovely photo'd one is glass/epoxy laminated then covered in " Flite metal' .
A genuinely exquisite job .. well detailed too.
Something for me to aspire to :-)
Old May 16, 2012, 07:32 AM
HerkS is online now
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
I've been looking at the Northrop history quite a bit lately. Have been focused mostly on the N9M which was the test model for this big one.
The experiment I did with it indicated that the design wing twist of 4 degrees seems about right. I couldn't see anywhere on the plan an indication that it should have twist. It may of course have been described in the article - or it may be on the plan but I can't read it.
I also felt that working drag rudders would have helped a lot.
As drawn, the slot would be ineffective and probably would have actually detracted from the aerodynamics of the wing. Slots and slats need to contract toward the exit, and the exit needs to be aimed over the upper surface of the wing.
If you thought of building something like this, a slope glider version of the B-49 jet version would be a good starting point - avoiding all the weight and complexity of the power system. The basic wing plan layout would be the same.
Old May 16, 2012, 07:42 AM
Jon Snow is offline
Find More Posts by Jon Snow
You know nothing....
Jon Snow's Avatar
Joined Sep 2011
Herks,3o washout indicated on the plan.I noticed from some photos of the plane the tip appears to be an inverted airfoil.Is that the case?This would give a wash out effect?
Stuart
Jon Snow is offline Find More Posts by Jon Snow
Old May 16, 2012, 08:01 AM
HerkS is online now
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
An inverted airfoil would have the effect of washout. So does up elevon trim.
Northrop however was adamant that his designs have symmetrical airfoils all the way from root to tip, so an inverted airfoil would not be scale.
On one of the N9M prototypes the part of the wing outboard of the elevon was used as a pitch trim surface. If some up trim was introduced to that surface it would look somewhat like an inverted airfoil. The N9M that has been restored, has drag rudders in that area. I think all of the bombers had drag rudders out there.
Old May 16, 2012, 08:57 AM
kleinaberfein is offline
Find More Posts by kleinaberfein
Closed Account
Joined Jul 2009
That looks quite interesting :-)
Jens
kleinaberfein is offline Find More Posts by kleinaberfein
Old May 16, 2012, 09:14 AM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
Herks,my mistake,it was the curve on the tip giving an illusion.
Jens,"that looks quite interesting"? You wouldn't be......or would you.
There's some really good pics first page of a google search.Xb35,HoXVIII-they'd make a nice pair.Both using Herks drag rudder system.
Regards Stuart
Old May 16, 2012, 10:13 AM
Closed Account
Joined Jul 2009
No no Stuart I have other plans right now ... but .... that is an interesting set of plans and ...
Jens
Old May 16, 2012, 11:44 AM
Bare is offline
Canada
Joined Nov 2000
Ooops..
more info that was illegibly on the plans image posted :
Washout is /was 5 degrees on this model
There are No rudders drag or otherwise, the Author claimed no instability issues . Presumably those 4 props add significantly.
Also the leading edge slots used in this plan, albeit of erm... reduced/simplified design were soon 'taped over' as they caused problematic drag at takeoff.
Stability is stated as good, allegedly a well behaved flying toy as no bad habits were encountered other that the typ sensitivity to CG issues.
But then rarely do any of these build articles ever mention much about 'aggressive' flying.. so that aspect often remains unspoken of... until trying it.
The full size paper plan (and article ?) is available from Model Aviation as 814 XB35
I believe that the shiny photo'd one...
was scratch built sans benefit of 'plans' :-)
Old May 16, 2012, 11:36 PM
birdofplay is online now
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Found this pic out there
birdofplay is online now Find More Posts by birdofplay
Old May 16, 2012, 11:45 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
The twist isn't easy to see but the blueprints say 4 degrees and the tip control surfaces are pitch trimmers with integrated drag rudders. They are not part of the roll control system therefor not elevons. The next surface inboard of them is the elevon and inboard of that is a landing flap. This arrangement of control surfaces is why I wouldn't recommend Northrop's control system. By cutting the elevons off short of the tips it creates induced drag that contributes to adverse yaw.
__Norm
nmasters is offline Find More Posts by nmasters
Old May 18, 2012, 07:43 PM
Bare is offline
Canada
Joined Nov 2000
erm what Are? you talking about ?
These plans say 5 degrees and ken's model is similar, albeit built entirely from 3 views Seemed to work 'just fine' by my observations.
Charitably: (I could do far worse :-) Real Life is a whole world away from theory, picked up gawd knows where.
As example:13 year old Boys have lotsa theories re Sex... I know I certainly did :-)
But often (usually bungle the reality.. when the rubber meets the road.. speaking figuratively... certainly true the first few times for most of us :-)
Old May 18, 2012, 11:41 PM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Note the caption under Bob's picture of the N9-M
Old May 30, 2012, 04:03 PM
TRP is offline
TRP
Find More Posts by TRP
TRP
TRP's Avatar
United States, CA, Morgan Hill
Joined Jun 2002
I just ordered a set of plans from: http://www.modelaircraft.org/plans/plans96.aspx
24.00 - for the two plan sheets plus the construction article
Half price for a second set.
Shipping is 9.00 (Flat rate)
AMA members get 10% off.
Now I need to find someone to laser cut me some parts. Brian - are you listening?
TRP is offline Find More Posts by TRP
Build Log 35" Xb-70 agriebel Pusher Prop Jet Models 128 Jul 29, 2012 11:06 PM
Discussion looking for Northrop XB-35 Plans tlh101 Scale Kit/Scratch Built 10 Nov 08, 2011 07:19 PM
