Hervey Bay, Queensland, Australia
Joined Mar 2008
Modern castor based lubricants that can be used as lubricant with diesels, though they may cause a white waxy precipitate with glow fuel:
Castrol R30 Castrol A747 Maxima 927 Shell Racing R30 Fuchs Racing R30 Klotz BeNol These are typically found in motorcycle and kart supply shops. |
amherst,nova scotia,canada
Joined Nov 2003
Joined Nov 2003
Albion Park Rail Aus
Joined Nov 2009
Ether sources
That is exactly the reason why it is almost impossible to obtain. The control line guys have a source - somewhere, otherwise you have to be a manufacturing company to justify why you need it and then only available in huge commercial quantities. There are a few of the "manufacturing chemists" (ie those that still mix up the elixirs of yesterday) that stock ether, however inquiries are always stone-walled. regards Alex |
Canada, ON, Cottam
Joined Jan 2012
I think the ether from the winter starting fluid is what most of the diesel guys are using. The can is turned upside down and emptied of the propellant and the remaining mostly ether is used. It is only needed to start, and I have seen some youtube videos of motors running fine using a starter with no ether. Just castor and kero. One guy sprayed the ether for a prime, and then it ran on the kero/castor. I had one diesel as a kid and never had good luck with it. It only started for other people. I think it didn't like me.
To remove varnish, I used a wood dowel with fine steel wool wrapped around it, soak in fuel and spin by hand in cylinder with the glow head removed. Have also used tooth paste on the steel wool. Wash cylinder thorougly with hot water and detergent, dry with paper towel/Q-Tip, and lastly apply 3-IN-1 oil or Marvel Mystery oil while re-assembling the engine. Varnishing usually doesn't recur after initial break-in and varnish removal.Do not over-tighten cylinder and glow head, use only 2 Cox wrenches. If connecting rod becomes loose in piston, tighten (carefully) with Cox reset tool following instructions.
Canada, ON, Cottam
Joined Jan 2012
A lot of people run without castor. At a risk of getting tarred and feathered here, I would say it is wise to add a bit of castor, like 3 to 4 oz. to a gallon to all commercial fuel. The older steel pistons and even the newer plain bearing ones likely benefit more from more castor. ABC BB motors can survive without castor if not run too lean IMHO.
Joined Feb 2006
I've seen engines die from poor tuning + a lack of castor. Although at this size, most people chalked it up to .049’s being toys...
![]() I’m sure you can get away without and I know synthetics do great, but I’ve no doubt castor has saved me a few times. I’ve thrown more than one airplane into the air only to hear it unload to a lean run, then followed it around the sky until it either died or ran out the tank… They might land smoking, but they always ran again. I’ve also ruined a few ancient swap meet engines from running modern fuels that ate away all the varnish and crucial gunk that kept the motor sealed… They lost compression and got all sloppy. I’ll keep adding castor… even if it now comes with a homeopathy label covered in cursive scripts and flowers... Aside from the occasional swap meet clunker, all my dead engines passed away due to sudden deceleration.
If you tune any engine right and stay within the recommended prop sizes (within reason for altitude etc.), you'll typically be ok. As I recall, it's high heat that kills the synthetics. They break down into shorter chain molecules and "burn off" leaving a lack of lubrication. Castor cooks into longer chain molecules and gets sticky, especially in that piston cup, ultimately turning into the varnish that stains the engine. A couple lean runs on synthetics can wear out a cylinder where castor will often leave the engine filthy, but not much worse for the experience. ymmv...
| Thread Tools | |
| Discussion castor oil | grrmisfit | Engines | 15 | Mar 19, 2012 11:04 AM |
| Discussion Why have castor oil in your fuel opposed to synthetic oil? | Sir-Ipswich | Car Talk | 1 | Aug 09, 2007 06:48 AM |
| Castor or synthetic oil? | W'rkncacnter | Engines | 10 | Aug 18, 2004 04:25 AM |
| Removing Castor Oil from Wood? | Brill 1 | Fuel Plane Talk | 12 | Jan 27, 2004 03:04 PM |
