Old May 15, 2012, 05:19 PM
defxxx is offline
Find More Posts by defxxx
Joined Mar 2012
HoverflyGIMBAL - Input Voltage? Manual?
Hi -
I'm trying to get a jump on lining up the rest of my gimbal situation while waiting for the HoverflyGIMBAL to arrive. What is the input voltage range of the board and what voltage does it output to the servos?
It would be great if it accepted greater than 12V and let you step down the output to servos and radio receiver separately. My wireless video transmitter downlink is 12V so if I could power the whole gimbal/servos/video off one battery...perrrrfect!
Is there a manual out for the Gimbal yet?
defxxx is offline Find More Posts by defxxx
Old May 15, 2012, 05:21 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
that is a good question.
really 7.4 would be ideal since many high end gimbal servos are brushless and need HV...
I am guessing it is 6v but we will see what Al or George say.
Adidas4275 is offline Find More Posts by Adidas4275
Old May 15, 2012, 05:31 PM
defxxx is offline
Joined Mar 2012
Absolutely. If I can use one 4S battery, and the Gimbal could step it down to 7.4 for the Rx/Servos, I'd be very pleased.
Old May 15, 2012, 05:35 PM
photronix is offline
Find More Posts by photronix
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
The manual is coming....
The input power to the gimbal is what ever your servos will need. There is a little solder jumper on the board for <6V or >6V. It comes from us set to 6 volts and greater because most gimbal servos use either 6V or 7.4V.
It will be best to use a UBEC such as the one from Castle Creations set to what your servos need.
photronix is offline Find More Posts by photronix
Old May 15, 2012, 06:15 PM
Adidas4275's Avatar
Joined Mar 2011
Good to know
Old May 15, 2012, 07:32 PM
defxxx is offline
Joined Mar 2012
Ok, I have an extra one of those Castle 10a BECs. Sounds good.
Have you guys been running your AV200 with the stock Savox servos? At 7.4 or 6v?
Old May 16, 2012, 06:12 PM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
I believe the servos on the av200 are 6v. You have to look up the specs on each servo.
Old May 16, 2012, 06:25 PM
Adidas4275's Avatar
Joined Mar 2011
i dont think those savoxs are rated for 7.4v .... 6v i am 99% sure
Old May 16, 2012, 08:50 PM
defxxx is offline
Joined Mar 2012
You are right, I was just wondering if anyone has been over-driving them in a gimbal.
Old May 17, 2012, 02:36 PM
hoverben is offline
Find More Posts by hoverben
Hoverfly Technologies
hoverben's Avatar
United States, FL, Winter Springs
Joined Nov 2011
Quick Start Guide is now available:
http://www.hoverflytech.com/uploads/...tart_Guide.pdf
hoverben is offline Find More Posts by hoverben
Old May 17, 2012, 02:54 PM
Adidas4275's Avatar
Joined Mar 2011
thanks.... there are many people interested in the gimbal controller...... I am sharing this in other threads as well
Alert receiver input voltage marvin.t Racing Boats - Electric 8 Apr 14, 2012 07:32 AM
Discussion What Voltage Regulator can output 5Volts with 8 to 70 volts Input ? lazy-b DIY Electronics 4 Apr 03, 2012 05:45 PM
Discussion What is the Minimum Input Voltage for a CC BEC Pro? Alan Hahn Castle Creations 2 Mar 22, 2012 03:41 PM
Discussion Input Battery Voltage Error taekwondo Batteries and Chargers 8 Jan 11, 2012 04:41 PM
Discussion 4S Gold reporting wrong input voltage a1pcfixer FMA Direct 8 Oct 31, 2011 12:38 PM
