As mentioned earlier, you can build a 8" x 12" precision metal lathe using a hand drill and files. It will drill and bore with precision.
Get the foundry book and the lathe book by David Gingery, and follow the instructions. If you don't have a drill press you can still drill accurate square to surface holes with a drill guide made by drilling a few different size holes (to accommodate common drill sizes) in a block of aluminum or steel on someone else's drill press. In all drilling operations, to get accurate hole locations you need to center punch, and step drill out. This applies to hand drills and drill press's alike. You can even make a drill guide without access to a drill press if you strap your drill to a bench top on a formed block with hose clamps, making sure the drill bit is parallel to the table top. Add some temporary wood rails on the bench under the bit to guide your block and slide the block into the bit, using the rails as guides. With this block as a guide you can then drill square to surface holes with the hand drill. Making a basic lathe is as simple as fixing a hand drill to a bench top, and making a simple tailstock attached to the bench surface. If you dress up the above rails and block drilling procedure, it IS a lathe. The block can become a tailstock if you fit it with a homemade center, since you drilled it parallel with the bench surface. |
The motors are actually 6v I think (Unimat1), standard RS380 types, but it's not hard to adapt a 540 (as per Unimat PL), or an old drill motor etc. And yes, by all logic there should be a huge community of HK 6in1 users posting their work and mods. |
| Thread Tools | |
| Discussion Any Subaru owners over in Europe? Looking to buy some parts.. | davekra | Chit Chat | 1 | Mar 04, 2012 10:50 PM |
| Help! Any 411 on Hobbyking 1.4M P-51 | TxToast | Electric Warbirds | 2 | Feb 23, 2012 07:05 AM |
| Discussion Hobbyking v2.1 owners | chatch15117 | Multirotor Talk | 17 | Jan 25, 2012 12:07 PM |
| Discussion Any New 1/5 or 1/6 Scale Fokker D-7 ARFs Coming? | TallyHo1956 | Electric Warbirds | 6 | Jan 04, 2012 05:00 PM |
