Old May 15, 2012, 07:57 AM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
Is a motor's tolerance for power output strictly limited by energy wasted as heat?
As I understand it, a given motor has a certain efficiency rate. The delta between the input power and the output power is absorbed by the motor as heat...and assuming a certain level of cooling airflow, for a given motor mass, a certain wattage as waste heat will be tolerated.
So assuming that the waste heat wattage is kept the same, is there any reason that one wouldn't be able to go up in voltage? Or stated another way, is it possible to run motors at higher voltage levels, assuming the amps are kept sufficiently low?
Thanks for any information on this!
MRGTX is offline Find More Posts by MRGTX
Old May 15, 2012, 12:23 PM
peterangus is offline
Find More Posts by peterangus
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
Yes.
eg:
When set-up to operate continuously at 80% efficiency, the power output will be 4 times the cooling power. Regardless of the operating voltage.
And there seems to be little change in peak efficiency as voltage is increased,
So the cooling provision effectively limits the usable power.
peterangus is offline Find More Posts by peterangus
Old May 15, 2012, 12:31 PM
snoopy_schulz is offline
Find More Posts by snoopy_schulz
snoopy_schulz's Avatar
Germany, lake of constance
Joined Oct 2010
Hi MRGTX
You can run a dc motor at higher voltage levels, assuming the amps are kept within motor current limit.
The power loss of a dc motor is given in first order by I^2 *R. I is the motor current, R is the motor resistance.
Running a dc-motor with higher voltage at same motor current (prop with less diameter/pitch) means a higher shaft speed. Thus check max allowed speed of motor and max rpm of ESC. Also ESC/BEC must be able to handle higher voltage.
Best regards
Micha
snoopy_schulz is offline Find More Posts by snoopy_schulz
Old May 15, 2012, 08:53 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Yes, up to a point. At very high rpm the bearings may fail or the rotor may fly apart. Cheap outrunners with unbalanced rotors may suffer excessive vibration. The ESC may not be able to commutate fast enough (some controllers are limited to 21,000rpm or less with a 14 pole motor).
I^2*R is not the only loss. Magnetic losses also get worse as rpm increases. At some point the total loss will become excessive even at low current. High rpm motors usually have fewer magnets and thinner laminations to reduce magnetic losses, and often include a fan to help keep them cool.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Discussion The unelected's war on US prosperity and cheap energy MtnGoat Life, The Universe, and Politics 11 Mar 29, 2012 02:48 PM
Discussion New WK-M: Every motor on the XA Hexa starts up as soon as it's powered up. brianshell Multirotor Talk 8 Jan 15, 2012 04:11 AM
Discussion Whatīs the output power on a stock Futaba 2.4 Ghz transmitter? Voguna FPV Talk 4 Sep 20, 2010 09:26 AM
Tail shaft size on the Zoom? Final output ratio for it as well vs main shaft? Admiral_Red Mini Helis 1 Jun 08, 2004 05:40 PM
It's not as good as DNA's but here is some motor test data on qc830's Spaulding Parkflyers 5 Feb 04, 2002 04:39 PM
