Old May 14, 2012, 09:02 PM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
Help!
Motor cut out on heli - 450 size with Ice 50
Running a standard Ice 50 in a mini Protos 450 sized heli. On the third flight the motor quit while inverted. My flying buddy was flying it and got it rolled back over and came down hard on the skids. Bent feathering shaft and cracked canopy.
So what happened? The ESC was beeping 3 beeps with 5-10 seconds in between. The servos worked. I gather 3 beeps mean over current. However I can't imagine that it was pulling enough to shut down a standard Ice 50. Using the stock Protos motor on 3S.
I looked at the programing on the ESC and its in airplane with all default setting. I set it up last fall but got to believe I programed the ESC before flying. Could it have lost my programing?
If I did not program it and it was in airplane mode with default setting like over current. At what current draw would it shut down?
Basically I'm trying to figure out what went wrong so it doesn't happen again. Everything works right now as I tried spinning it up after I had unplugged the pack and looked everything over.
I haven't been able to try it again as i need to order and replace the bent feathering shaft.
Also, what happens to data logging once full? Does it stop recording or does it overwrite data?
TIA
JoeR is offline Find More Posts by JoeR
Old May 15, 2012, 05:22 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Make sure you have the correct setup
Current limiting insensitive
Soft Cutoff
PWM to 8, or 12 (not Outrunner as that’s for airplanes only)
Timing Low
The data log locking up when full is a bug in ICE ESC’s. You have to manually clear it every once and a while.
RC Man is online now Find More Posts by RC Man
Old May 15, 2012, 07:01 AM
JoeR is offline
USA, NY, Jamestown
Joined Jun 2000
Thanks for the insight. I always set up the ESCs in helis to insensitive current limiting. I just can't figure out why its not there now.
Something strange with the log data. At the very beginning there is a current spike to 59amps. Does Castle test the ESCs before sending out? I can't imagine why there is a spike like that for the first session. There are 6 or more sessions after with no data as as I was setting up the heli.
For Sale TP 450-Size 2415-03T Brushless Heli Motor 4850kv x2 1doubleUp Aircraft - Electric - Helis (FS/W) 3 Mar 17, 2012 03:03 PM
For Sale Kontronic Jazz 40 ESC w/Medusa BEC & Scorpion-12 Motor (4S setup f/450 size heli) helinut4ever Aircraft - Electric - Helis (FS/W) 1 Mar 11, 2012 03:18 PM
For Sale 450 size heli motor lectroglide Aircraft - Electric - Power Systems (FS/W) 0 Feb 27, 2012 12:41 PM
Sold WALKERA 450 size electric heli (450 size) $50.00 shipped. crosby Aircraft - Electric - Helis (FS/W) 4 Nov 15, 2011 06:14 PM
Sold E Flite Pitch Gauge 450 Heli size $8.50 shipped IHateThatTree Aircraft - Electric - Helis (FS/W) 2 Sep 17, 2011 11:11 AM
