Old May 14, 2012, 07:10 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
New ALZRC 3GY V2.0 FBL System
If you do not know, ALZRC is phasing out their older 3GYS 3-axis flybarless gyro for their newer 3GY. It is about time to separate the 3GY discussion from the 3GYS discussion.
__________________________________________________ __________________________________________________ ___________________
Originally Posted by beenflying View Post
That price is looking good! With the continued work robird is doing on this gyro (working with a pro and adding governor), we could end up with a gyro the equivalent of the Mikado Vbar.
Just an FYI, I've started another thread that will have a review and a resource of information (also links back to this thread) in the first post here:
http://www.rcgroups.com/forums/showthread.php?t=1685138
boredom.is.me is offline Find More Posts by boredom.is.me
Old May 14, 2012, 08:03 PM
Joined Nov 2007
I also got a flight in on mine today with KBDD tail blades. I had to turn the gain way down. I think it is somewhere around 20.
Old May 14, 2012, 08:05 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
All the bugs worked out now? Any other changes in the firmware outside of the vibra monitor?
ridge_racer is offline Find More Posts by ridge_racer
Old May 14, 2012, 08:31 PM
Joined Nov 2007
I am flying with different blades now. I have some Stealth 315mm blades on. They are the same length, a little wider, and better quality, but the heli doesn't fly as nicely with them. They are not FBL specified blades which is most likely the reason.
Other than the vibra analysis, all I have now is the #2 led that blinks every once in a while. Nothing seems to be an issue though so I am assuming it is normal.
Old May 14, 2012, 08:43 PM
Joined Nov 2010
Just installed and read the help tab. I'm curious as well as how is it determining rpm?
Old May 14, 2012, 11:51 PM
Joined Nov 2007
I had a night time flight were I worked out the basic gyro settings for elev, aile, and rudd for the Stealth blades. I looked into the differences between FB and FBL blades, and yes, the blades I have on now do react quicker, which I guess initially caught me off guard. I'll add a little more expo to help compensate for this. I still need to correct my blade tracking.
I haven't taken it into the open yet, but from what I can tell, the tail is holding much better, nearly on point.
Old May 15, 2012, 03:12 PM
IFHELI is offline
Find More Posts by IFHELI
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
I wanted to get out this past weekend but having troubles with the double sided tape. None of it will stay stuck to the frames of this heli. I ran out of my 3M # 4010 and used the stock stuff from the ZYX`s. I went out yesterday and bought two rolls of it so I`m stocked up for awhile now.....
I wish they would give out some information on the vibra analyse.
IFHELI is offline Find More Posts by IFHELI
Old May 15, 2012, 03:24 PM
Joined Nov 2007
...like how rpm is derived.
Old May 15, 2012, 03:43 PM
IFHELI is offline
IFHELI's Avatar
Joined Apr 2010
I`m useing the Gov. on my CC ESC`s and it is not set perfect and the 3GY vib logger is very close to the RPM`s I`m seeing.
Old May 15, 2012, 04:57 PM
Joined Nov 2007
I just noticed that they got rid of the delay in the performance window.
Old May 15, 2012, 05:47 PM
Joined Nov 2010
The vibration analyse might be frequency based. Every set rpm for the main and tail rotor generates a certain frequency that the gyro is picking up and calculating rpms from.
Old May 17, 2012, 05:09 PM
Joined Nov 2010
I sent an email to rc711 asking for some information on how the vibra analysis works and how to use it. Waiting for a reply.
Old May 18, 2012, 02:57 PM
Joined Nov 2007
I had fun pushing my limits today. (That normally means there is bad news.) I just need an open space now...and a screwdriver so I can replace one of my servo arms...and new blades. I changed my main shaft and my feathering shaft suffered no damage. This is really good considering how everyone said to stay away from the SS stuff. I shattered one of CF blades. I also lost half a tooth on my man gear. I wonder if that will be an issue.
Old May 18, 2012, 03:18 PM
Joined Nov 2010
The main gear might strip further and it's going to sound a little crappy.
Discussion ALZRC Devil 450 PRO!! 3GY gyro ver 2.0.3 pitchp Mini Helis 7 Jun 10, 2012 10:30 PM
Build Log ALZRC 450 pro V2, More bling then JLo! Hot_Wheels Mini Helis 19 Mar 13, 2012 12:30 AM
Discussion ALZRC 450 Pro V2 FBL Radio and 3x1000 FBL placement electrojolt Mini Helis 2 Feb 05, 2012 06:28 PM
