Old May 14, 2012, 03:48 PM
King_Ice_Flash is offline
Find More Posts by King_Ice_Flash
King_Ice_Flash's Avatar
WI
MinimOSD on ground station.
Can I use the minimOSD on the RX side of the video transmitter, with the APM2.0 and the xbee, or should I order something else?
King_Ice_Flash is offline Find More Posts by King_Ice_Flash
Old May 15, 2012, 03:09 PM
WI
No one knows if I will have frame sync issues?
I can't believe no one has done this to save weight, so if they lose video signal, they will still have OSD?
Old May 15, 2012, 05:24 PM
quix-fz is offline
Find More Posts by quix-fz
Basel, Switzerland
Joined Mar 2008
i did a little test with a max7456 which the minimosd apparently uses.
i wired it up to do the osd (instead of my atmega diy osd) on the ground after the video receiver. without the receiver antenna, i got the slightest noise after going behind a wall with the tx, and the osd text was GONE! the diy osd would still be working under these conditions, the text could wobble and shift around a bit, but it does work (flying like that for months).
i'd say the max7456 is useless for on-the-ground-osd. but would love to see others confirm that or prove me wrong (could be something with my wiring/pcb), as it's beautifully simple to do osd with..
quix-fz is offline Find More Posts by quix-fz
Old May 15, 2012, 08:03 PM
WI
Thanks for testing this!
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4498 Jun 07, 2016 12:20 PM
Sold ground station package all on 1.3MHz steveiewonder FPV Equipment (FS/W) 5 May 04, 2012 02:12 PM
Question Multiple Video Receivers on Ground Station. + Question on reception in fog! beaverlover FPV Talk 4 Nov 25, 2011 02:11 PM
Discussion Mic on Ground Station Cralis FPV Talk 21 May 14, 2010 08:03 PM
