Old May 14, 2012, 01:25 PM
joy4u is offline
Find More Posts by joy4u
joy4u's Avatar
India
Joined Feb 2006
Fibre glass Epoxy sheet vs Carbon fibre sheet for multirotor centre plates..
I have been building and flying multirotors for 3 years but I have never used carbon fiber sheets for center plates of the frame ..
I have always used glass fiber epoxy sheets 1mm ..
Can someone please tell me what will be the difference if I use the 1mm carbon fiber sheets instead...
How light and strong will it be from the glass fiber epoxy sheets , also is it worth according to the price difference...
joy4u is offline Find More Posts by joy4u
Old May 14, 2012, 02:17 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
1mm CF is thin...... i have found 1.5mm CF is better (IMO)
really CF is more stiff in comparison to G10 at the same thickness
But CG is more brittle and cracks when G10 will bend
Rusty's Frame plates (G10) are basically unbreakable.... but they are not super stiff...
Adidas4275 is offline Find More Posts by Adidas4275
Old May 14, 2012, 03:34 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Think of the analogy between one pound of lead versus one pound of feather. Is there any weight difference? No. So one piece of carbon the same size as one piece of G10 fiberglass probably are very similar in weight. However the carbon plate will be stiffer.
There are many types of carbon plates. The pretty ones with weave showing are called accent plates. Then you also have unidirectional plates (the weaves are all in one direction) and chopped fiber plates (like chopped fiberglass with the weave in random directions). You also find carbon fiber sandwiches where they use unidirectional plates sandwiching some other light materials in between. They use paper honey comb, end grain balsa and rohacell foam as the middle.
Carbon plate is over rated by the people that loves bling. Most of the time it is not necessary. Especially for the center plate.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Aug 16, 2012, 10:08 PM
HoverThings is online now
Find More Posts by HoverThings
DanPhillips
United States, NC, Wilmington
Joined Nov 2011
weight difference between G10 and CF
I have tried to do some research on the actual weight difference between G10 and Carbon Fiber. What I have found is the general feeling is that 1 Cu inch of G10 is about .070 LB where as CF is .55lb per Cu Inch.
That's about 25% take or lose some. Now in real life, if someone were using Carbon Fiber would they use the same thickness of sheet product - thus saving 25% over G10, or would they use a thinner sheet of carbon and save even more than the 25%.
IE: Quad frame made from G10 weights 5oz - would a comparable Carbon frame weigh only 25% less or maybe 40% less due to thinner material
HoverThings is online now Find More Posts by HoverThings
Old Aug 16, 2012, 10:14 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
this is just an opinion
1 thin layer of CF for the stiffness and a layer of G10 for impact resistance.. so you should end up a nice strong plate (Maybe)
jy0933 is offline Find More Posts by jy0933
Question Balsa sheeting foam core wings vs just glassing. erh7771 Scratchbuilt EDFs 74 Mar 14, 2016 10:40 PM
Discussion carbon fiber frame vs fiber glass frame? ChatXT Multirotor Talk 1 Feb 09, 2012 02:38 AM
New Product Carbon Fibre sheet composites Micro Helis 0 Oct 28, 2011 10:27 AM
For Sale Carbon fibre sheet welch Aircraft - Electric - Airplanes (FS/W) 0 Oct 04, 2011 02:39 AM
