Old May 14, 2012, 11:07 AM
Mykro is offline
Find More Posts by Mykro
RC Model Plane FPV Pilot..
Joined Feb 2009
Heklp..! Futaba 10c Launch preset
I sure could use a little help programming in a mix..
I'm looking to have setup on a switch an Elevator to Rudder preset mix..
Once I launch the plane I want to hit a switch so that I have something like 2% up Elevator and 2% right Rudder.. It would be really gradual!.. If I were to use the trim buttons it would be like using 4 clicks up elevator, to 4 clicks right rudder.. I'm stumped on programming it on a switch..
Michael
Mykro is offline Find More Posts by Mykro
Old May 14, 2012, 11:43 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Many radios when creating mixes will allow you to select what switch activates the mix.
Most of the time this switch selection is also on the same screen as the mix you are creating.
What you are looking for is not a Elevator to Rudder mix BUT a Elevator AND a Rudder mix, right?
You want some up elevator along with some rudder on a switch for when you launch?
If you have a flap menu and are not using flaps you could use the elevator compensation if you have it for the elevator and creat one mix for the rudder using the same switch.
OR
Create 2 mixes
freechip is offline Find More Posts by freechip
Old May 14, 2012, 11:52 AM
Mykro is offline
Joined Feb 2009
Usually when I do a mix the switch I assign to it just turns the mix on or off.. I still have to use the the sticks to move the servos.. For instance. I have a 50% - 50% mix Aileron to Rudder that I fly with.. When I move the right stick the Ailerons deflect along with the Rudder..
What I'm asking for is with the flick of a switch only (without the use of the stick)
the Elevator & Rudder deflect to the percentage I set..
Old May 14, 2012, 11:55 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Does your radio have mixing with OFFET option.
If it does then you would create a mix Elevator to Elevator and then use offset and select the right switch.
On my radio here is what it would look like
MIX # what ever
Elevator > Elevator
Rate 0%
Rate 10%
Offset 100%
Switch on what ever switch available that I want to use.
Repeat the same process for the Rud to Rud mix using the same switch.
Old May 14, 2012, 11:57 AM
Mykro is offline
Joined Feb 2009
You mean Elevator to Rudder right??
Old May 14, 2012, 12:02 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If you want the ELEVATOR to move up a little ALONG with the RUDDER going up for a launch purpose then I mean ELEVATOR TO ELEVATOR and a RUDDER TO RUDDER mix.
If you just want some rudder mixed in the elevator so that when you launch there is more rudder during launch then there would be during normal flight then it's the way you mean.
WHAT DO YOU WANT?
Old May 14, 2012, 12:03 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by Mykro View Post
... Once I launch the plane I want to hit a switch so that I have something like 2% up Elevator and 2% right Rudder.......
Thanks Michael
This line of your first post to me means you want or need two mixes.
One for the elevator and one for the rudder.
This sound like you want those 2% compensation on a switch with no stick input, then what I suggestion is what you need.
You can get away with only using one mix for the rudder to rudder if you have a flap system that allows for elevator compensation and your not using flaps.
Old May 14, 2012, 12:30 PM
Mykro is offline
Joined Feb 2009
MIX # what ever
Elevator > Elevator
Rate 0%
Rate 10%
Offset 100%
Ok.. I'm setting up the Elevator > Elevator just as you have it..
The only problem is I had zeroed out the default 50% in the offset earlier..
How do I change the offset using the dial selector..? It won't let me..
Old May 14, 2012, 03:31 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Sorry but as for programming specific on that tx I have no experience with that radio.
Old May 14, 2012, 04:37 PM
Mykro is offline
Joined Feb 2009
Thanks for your help..
Sold Futaba 2.4GHz TM-10 Module for the Futaba 10C System wefao Aircraft - General - Radio Equipment (FS/W) 1 May 09, 2012 11:03 PM
Discussion Preset sheet for Futaba 8fg jbsorocaba Radios 1 Sep 11, 2011 05:37 PM
Discussion Futaba 10CG launch preset got2soar Hand Launch 10 Mar 15, 2010 08:59 PM
Discussion DLG-Launch-preset with Futaba 9C Super Raphael Radios 6 Feb 07, 2007 10:50 AM
Adding Elevator Launch Preset to JR631 marctrudeau Hand Launch 1 Apr 10, 2003 09:48 AM
