Old May 13, 2012, 10:27 PM
dwculp is offline
Find More Posts by dwculp
Joined May 2011
HK EPP-FPV embed servos in tail?
I am currently building an HK EPP-FPV and I am seriously considering embedding the rudder and elevator servos into the tail. This would get them off of the carbon fiber tube and out of the way during landing, it would also shorten the control rods by a considerable amount and reduce control rod flex to almost non existent.
However, I see two potential problems:
1. The servo extension wires would be very long, running from the tail of the plane all the way to the front. Would this be a problem?
2. Further weight in the tail of an airplane that is already tail heavy. Although the benefit is more FPV gear up front!!!
Any thoughts? Bad idea?
dwculp is offline Find More Posts by dwculp
Old May 13, 2012, 10:32 PM
quix-fz is offline
Find More Posts by quix-fz
Basel, Switzerland
Joined Mar 2008
good idea, i did that with mine. route the servo cables through the carbon tube for clean looks.
quix-fz is offline Find More Posts by quix-fz
Old May 13, 2012, 10:59 PM
vvV FANG Vvv is online now
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Harden
Joined Aug 2008
yep its all in the hk epp fpv thread. i did the same as above.
vvV FANG Vvv is online now Find More Posts by vvV FANG Vvv
Discussion HK Yak 55 3D/EPP plane FPV hazchem88 FPV Aircraft 9 Jul 23, 2012 03:27 PM
Build Log EPP FPV plane from HK eyeinsky1 Aerial Photography 23 Mar 21, 2012 04:12 PM
Discussion HK 450 tail servo - shudder / noise hurleybt Mini Helis 1 Mar 14, 2012 11:29 AM
Cool Hk epp fpv nblracer880 FPV Talk 0 Jan 20, 2012 01:21 AM
Discussion HK tail servo dragrcr Electric Heli Talk 0 Jan 09, 2010 12:07 PM
