Old May 13, 2012, 09:11 PM
NetCode is offline
Find More Posts by NetCode
Joined Jan 2007
Turnigy Park480 vs NTM Prop Drive Series 35-30
http://www.hobbyking.com/hobbyking/s...r_1020kv_.html
vs
http://www.hobbyking.com/hobbyking/s...0kv_380w_.html
Anyone know how these two motors compare and what would be the best for 3DHS "41 Edge 540 application? Anyone have any experience with the two?
Thank you!
NetCode is offline Find More Posts by NetCode
Old May 13, 2012, 10:15 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
The 81g Turnigy Park 480 is probably good for 250W, the 88g NTM might be okay for a bit more (?270W). Don't believe the ridiculous amp/watts limits posted by HobbyKing unless you want to use your motors as immersion heaters.
That plane is said to weigh about 2lb or a bit more... so you probably want around 300W (150W/lb) for fully aerobatic performance... either of those motors will be okay if you are willing to push 'em hard. I realize that WOT might be used sparingly, but personally I'd go for a 100g motor which could do 300W without turning a hair.
A 105g Dualsky XM3536-8 (~990Kv) with an 11x7 or 12x6 on 3s might do you well.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 13, 2012, 11:19 PM
NetCode is offline
Joined Jan 2007
Interesting.. are you partial to Dualsky?
Old May 14, 2012, 04:11 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
The Turnigy Park480 is realistically rated and has good efficiency (my test data here). It is very similar to the E-Flite Park 480.
If the NTM Prop Drive's dyno test is accurate then it is a poor performer. I would avoid it.
The Park480 should draw about 300W with a 12x6 prop. Though overloaded at that power level, full throttle is rarely used in 3D so it should be OK.
If you want more power and don't mind a bit of extra weight, a 100~120g motor would be preferable. The Scorpion 3014-1030 with 11x5.5 prop would be my choice, but it is rather expensive. Other alternatives include the KD 36-16M, Turnigy L3015A-1000, and Turnigy Aerodrive SK3 - 3536-1050kv (currently out of stock; hopefully not for long!).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old May 14, 2012, 09:59 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Old May 14, 2012, 10:03 AM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Not particularly, but I've tested several Dualskys and have yet to find a bad one. I did test this 3536-8 motor extensively and found it was pretty darned good.
http://www.rcgroups.com/forums/showt...hlight=dualski
Old May 14, 2012, 10:17 AM
creapyd is offline
Find More Posts by creapyd
Prefectionist
Joined Mar 2007
I'm using that park 480 with a 12x6 apc on an 3dhs 41" edge. it's 357 watts 30 amps peak. 6:00 minutes of 3d flying and it comes down cool.
I have it connected to a mystery brand 40 amp esc.
i did elongate the holes on the motor mount just a tad to fit the holes on the Edge 540.
creapyd is offline Find More Posts by creapyd
Old May 15, 2012, 05:24 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
That is one heck of a battery pack if it can manage 11.9v @ 30A.... in-flight you must have lower voltage and amp draw.... so Bruce's 300W estimate seems more realistic.
Old May 15, 2012, 07:37 PM
creapyd is offline
Prefectionist
Joined Mar 2007
I can post pictures if you need evidence. I was to lazy to type the numbers out to I just took pictures of the watts up meter connected to the plane.
The batteries are 2 year old Hobbyking zipply 20C 2200mah 3s fresh off the charge.
Old May 17, 2012, 05:20 PM
scottc39 is online now
Find More Posts by scottc39
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
http://www.hobbyking.com/hobbyking/s...dProduct=16234
if you can use a 10x6 prop max this motor is a killer in my leader 480 putting out over 500 watts with a 3 cell setup and the 10x6 prop
scottc39 is online now Find More Posts by scottc39
Old May 17, 2012, 05:40 PM
creapyd is offline
Prefectionist
Joined Mar 2007
1400 kvt is to high for a 3d airplane application. you need a big wide prop with shallow pitch to keep air flowing over the control surfaces.
Sold NTM Prop Drive Series 35-36A 1400Kv +60 Amp ESC and props and extras nige838 Aircraft - Electric - Power Systems (FS/W) 2 Apr 11, 2012 10:05 PM
Sold NTM Prop Drive 35-48 Series 900KV / 815W flyandi Aircraft - Electric - Power Systems (FS/W) 4 Apr 10, 2012 10:56 AM
Sold NTM Prop Drive Series 35-36A 1800Kv / 875w flyandi Aircraft - Electric - Power Systems (FS/W) 2 Apr 08, 2012 10:45 PM
Sold Turnigy NTM Prop Drive Series 35-30A 1400kv scottc39 Aircraft - Electric - Power Systems (FS/W) 6 Jan 02, 2012 07:12 AM
Sold NTM Prop Drive Series 35-48A 1100kv -= GYRO =- Aircraft - Electric - Power Systems (FS/W) 3 Dec 26, 2011 08:12 PM
