Old May 13, 2012, 06:44 PM
Genetics101 is online now
Find More Posts by Genetics101
We were all NOOBS once!
Genetics101's Avatar
United States, WA, Seattle
Joined Sep 2011
Help!
Blue Beam antenna has been a complete disaster for me
All I've been hearing is how great these antennas are so I picked up a RX/TX set for the standard 70$ & to my sheer horror these things are a complete failure "FOR ME", respectfully I may be doing something wrong, I am using a directional patch 1.3 Ghz in diversity with these cloverleafs.... 3 lobe on the Quad & 4 lobe on one of the receivers, I even unplugged the patch & used my whip antenna & to no avail all I get is distortion after 20 ft, to scary to fly with... I've been doing this for some time now so I don't consider myself a "NOOB", as far as I'm concerned I haven't met anyone who knows everything (especially in the antenna dept) SO PLEASE- unless it makes you feel good about yourself enough of the NOOB remarks- jeesh... ANYWAY, I'm using all "range video" products & have even went as far as getting a new TX just to make sure..... What's going on? This sucks
Genetics101 is online now Find More Posts by Genetics101
Last edited by Genetics101; May 14, 2012 at 10:21 PM. Reason: Misunderstood title & folks are taking it wrong
Old May 13, 2012, 07:01 PM
Stacky is offline
Find More Posts by Stacky
Pants first, then shoes
Joined Jan 2011
They arent trash, 99.99% of people using them know how good they are. They are significantly better than the standard antenna.
You need to do some research and work your way through this thread to find out what you could improve instead of just calling something trash http://www.rcgroups.com/forums/showthread.php?t=1441664
Stacky is offline Find More Posts by Stacky
Old May 13, 2012, 08:40 PM
The Flying Farmer is offline
Find More Posts by The Flying Farmer
^Its what I do^ - FPVholic
The Flying Farmer's Avatar
United States, NY, Walker Valley
Joined Nov 2007
Please don't trash on great technology invented by a man just trying to further this hobby. Read more threads like mentioned, and then, after applying the suggestions, you still have problems, use the search feature. I'm 99.999% sure others have had and fixed the problem. Use a process of elimination. Then, if you still can't fix it, post your symptoms and detailed setup.
The Flying Farmer is offline Find More Posts by The Flying Farmer
Old May 13, 2012, 08:42 PM
Joined Nov 2007
Everyone is very helpful if you give them a chance.
Old May 13, 2012, 09:02 PM
jimmies is offline
Find More Posts by jimmies
Joined May 2012
yeah they really do suck
jimmies is offline Find More Posts by jimmies
Old May 13, 2012, 09:13 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Originally Posted by Genetics101 View Post
All I've been hearing is how great these antennas are so I picked up a RX/TX set for the standard 70$ & to my sheer horror these things are TRASH! respectfully I may be doing something wrong, I am using a directional patch 1.3 Ghz in diversity with these cloverleafs.... 3 lobe on the Quad & 4 lobe on one of the receivers, I even unplugged the patch & used my directional whip antenna & to no avail. I'm using all "range video" products & have even went as far as getting a new TX just to make sure..... What's going on? This sucks
where did you buy them from? Post some pics please.
Also, how did you make a directional whip antenna?
also, what problem are you experiencing? you haven't described what exactly is happening to you. Can you go 50 feet with instant fuzz out? are you getting constant lines/noise? Do you get no reception 5 feet away? do you get good reception high and far?
gundamnitpete is offline Find More Posts by gundamnitpete
Old May 13, 2012, 10:03 PM
ssquillace is offline
Find More Posts by ssquillace
The squidman
United States, FL, Jacksonville
Joined Dec 2011
Linear Polarized to a circular polarized vtx is not the best of ideas. You get dbi loss due to polarization differences. Also no multipath rejection as you would get with two CPA's. Best results are with dual CPA's. Ground station: 6-12 turn helical Plane: cloverleaf, is great combo.
ssquillace is offline Find More Posts by ssquillace
Old May 13, 2012, 10:08 PM View Post
Blueshy
A moderator felt this post violated the following rule: Personal Attack. It is temporarily hidden while Blueshy edits it. Show it to me anyway.
Old May 13, 2012, 11:06 PM
vvV FANG Vvv is online now
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Eurongilly
Joined Aug 2008
yah ^
And ssquillace posted the answer!
Not a case of bad product just a case of a very newb mistake on your part!
vvV FANG Vvv is online now Find More Posts by vvV FANG Vvv
Old May 14, 2012, 12:23 AM
BCSaltchucker is online now
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
sounds like he has diversity, with a 4 lobe blue beam on one of the Rx, so he should get good circularity.
But the OP has not explained what his problem is. Is he getting fuzzy reception under 500m? Or is he trying to go 3km before losing clear video? What his is reception with only the whip antennas?
Can the OP please post a pic of his plane with the exact locations of all the wiring, flight electronics and video electronics. Also a schematic he for video used would be helpful. I would bet half the tea in China the problem is bad wiring design/layout/filtering.
Using the Bluebeams on 1.3 myself, I have noticed they get hangar rash easily. But I just inspect them regularly and resolder any separated contacts as needed.
BCSaltchucker is online now Find More Posts by BCSaltchucker
Old May 14, 2012, 12:36 AM
Joined Sep 2011
Thankyou for your kind response dear sir & I very much appreciate your ability to see through my posting.. I meant no disrespect to the create of these antenna & could of used a better choice of words for those who are so defensive... After all I did clarify in my posting """"RESPECTFULLY"""".... Thais again & good day to you
Old May 14, 2012, 12:41 AM
Team White Llama!
if you get fuzz after 20 feet, there is likely an antenna disconnection problem. you need to post some pictures.
have these antennas been damaged in any way? where did you buy them?
Old May 14, 2012, 12:58 AM
Joined Sep 2011
I got them from hobby wireless out of Canada & I am suspect of a badly produced set of antenna. The dimensions are correct but the bends are sloppy & unequal. I wrote an E-mail to them about quality control & what they could do for me but after a week they won't respond. I can't post pics due to the fact that I use an iPad for all my computer doings & it won't allow pics.
Old May 14, 2012, 01:04 AM
quix-fz is offline
Find More Posts by quix-fz
Basel, Switzerland
Joined Mar 2008
you should be able to upload pics to flicker with its app or something like that. it'll be difficult to help without photos
quix-fz is offline Find More Posts by quix-fz
Old May 14, 2012, 01:10 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Sloppy bends won't reduce your range to 20ft. You have some other problem. I've crashed on,
mangled, and bent my various CP antennas (Bluebeam and others) many times, and then bent
em back into rough shape, and I can still regularly fly 2+ miles on 600mW 1.3Ghz with nothing
but a SPW on the Rx and CL on the Tx. Angles being off a little here or there won't cut
your range to nothing.
Check your SMA connectors and make sure your center pin isn't pushed back, and no longer
making contact. Get out a multi-meter and check continuity between center pin of SMA
connector, and the rest of the antenna including ground of the SMA connector. It's a closed loop
antenna, so should have connectivity between every point. Unfortunately, if the
antenna is shorted out between center pin and ground, there's not much you can do to test it,
but it's possible and it would cut your range to nothing. Try replacing each individual
CP antenna in turn with a known working linear antenna and see when your range comes back.
And while yes it is not optimal to mix linear and CP antennas (lose constant 3dB), I do it often
(Vee on one plane and SPW on Rx) and still get out well over a mile without issue. That's not
the issue here.
It's possible you have some issue totally unrelated to the CP antennas themselves. What
range do you get using nothing but linear antennas?
ian
Daemon is online now Find More Posts by Daemon
Help! Blue beam antenna's seem like trash Genetics101 Multirotor Talk 4 May 15, 2012 10:07 PM
Discussion Bent blue beam? Ori Paamoni Multirotor Talk 3 Apr 24, 2012 10:07 PM
Question patch antenna beam Art Newland FPV Talk 4 May 03, 2011 06:45 PM
Discussion Antenna beam width question. Quixksilver FPV Talk 7 Dec 17, 2009 06:47 PM
Discussion How to increase antenna's beam degrees ? zaguruinzasky FPV Talk 3 Mar 12, 2007 03:09 PM
