Old Jul 14, 2012, 05:57 AM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
With this concept of Stuart's much of the weight will consist of the wings. So the weight will move aft with the sweep. CG change may be quite tolerable.
When the F-14 was designed two retracting trim surfaces were created just forward of the wings. When the wing swept aft, these triangular surfaces were to extend and help keep the aerodynamic forces forward to counter the effect of the wing's aerodynamics moving aft. The concept proved unnecessary and the mechanism was eventually disabled such that the surfaces just remained retracted.
HerkS is offline Find More Posts by HerkS
Old Jul 14, 2012, 06:06 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Mm-hadn't thought of that.I must decide on max.sweep so we can get an idea of what we're dealing with.Current stage is inserting thin carbon rods into the wings to minimise any unwanted dihedral.Would a bit of wing tip weight be advantageous?
Regards Stuart
Stuart A is offline Find More Posts by Stuart A
Old Jul 14, 2012, 08:11 AM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
"Mark I like this.In fact I think it's a genius idea."
Aw shucks Stuart, don't think I'd up and go saying anything like that, but thanks.
Mark
Quick61 is offline Find More Posts by Quick61
Old Jul 14, 2012, 09:58 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Hi guys,could do with a bit of advice before I start cutting out control surfaces.I have a 600 mm length,the wing dimensions are-
Tip to pivot centre 670
Width@pivot centre. 155
Width@tip 70
Width of surfaces. 30
Drag rudders-can I leave them fixed open(if so best angle for this)
As Herks suggested earlier I propose to split the surface into 3 components.The inner 2 providing reflex in plank configuration,drag rudders at neutral.
For full sweep use the outer two to mimic twist.
Comments and advice please
Regards Stuart
Old Jul 14, 2012, 10:08 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Mark
If this prototype flies I may have to name it Serenity, they both look as though they were built rather than designed.Just hope I don't get bits falling off
Stuart
Old Jul 14, 2012, 10:16 AM
HerkS is offline
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Width@tip 70
Regards Stuart
Stuart - I measured the static position of the drag rudder function on the Plank. The surfaces were ten degrees above and below the neutral position - so 20 degrees of split.
If you use drag rudders like the ones on the Plank, I believe that you can put them at the outer end of the wing panel and you can still trim them up or down together to achieve various amounts of effective twist on that part of the wing whilst still retaining their drag function.
Old Jul 14, 2012, 10:42 AM
Quick61 is offline
Quick61's Avatar
Joined Jan 2011
If you name it Serenity, you know you will HAVE to love it.
"You can learn all the math in the 'verse, but you take a boat in the air, and don't have love, she'll shake you off just as sure as the turnin of the worlds."
Mark
Old Jul 14, 2012, 10:43 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Thanks Herks.How long do you think they should be?
Regards Stuart
Old Jul 14, 2012, 11:05 AM
HerkS is offline
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Regards Stuart
Well, for what it's worth, the ones on the Plank are just about exactly one-third of the panel length. Not exactly scientific eh????
Old Jul 14, 2012, 12:05 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
1/3 it is.Science-who needs it
Stuart
Old Jul 14, 2012, 02:33 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
The current state of affairs.I've set the maximum sweep at 50*,used the plan of the VII for this.Drilled a hole along the centre line,used this to mark a curve to the wings plank position and slotted it out.Captive nut from below and the wing is held tight.I'll mark some points on the pivot brace and wing after Ive shaped and sanded.
The wing has had the control surface cut away;these will be replaced with balsa to aid stiffness.To this end I've also added a 1.5mm carbon rod behind the step and a second along the hinge line.
Stuart
Old Jul 14, 2012, 05:49 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
In the continued spirit of spending nowt(miserly Yorkshire tyke me)I made some horns and slotted plates.For some reason I have a bag of the small joints,1.5mm carbon off cuts will connect them.The plates will probably be lower and angled down at the front once I am sure of the geometry
Stuart
Old Jul 15, 2012, 06:14 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Spare hour or so this a/m,so inner surfaces cut and horns fitted.Tab and slot,just to be safe.The slotted plates are fitted to the wing in a similar fashion.I haven't glued these yet,taping the hinge will be easier.
Still pondering the drag rudders,I would like to be able to try closing them when the wing is swept.
The radially curved slot is for the sweep adjustment,the lines are reference points I used when drilling it out.
Weather and time permitting this thing should be in the air(or in pieces!)by this time next week.The field I intend to use never seems to get cut so nice long grass.It has a good slope and tall trees around so pretty still air on a calmish day.Downside to that is it doesn't dry very quickly,and we've had MORE than our fair share of rain this month.
Stuart
Old Jul 15, 2012, 07:18 AM
kleinaberfein is offline
Find More Posts by kleinaberfein
Closed Account
Joined Jul 2009
Stuart !! that is some very nice work there. Clever and well thought out to say the least.
Jens
kleinaberfein is offline Find More Posts by kleinaberfein
Old Jul 15, 2012, 07:54 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Jens
Thanks Jens.From you that's a real
compliment.I can only do this small"fiddly"stuff in good daylight these days.
Regards Stuart
Discussion Best electric plane in 16 mph wind? Sailor03 Electric Plane Talk 42 Nov 23, 2012 02:40 PM
Discussion Why do airplanes take off in to the wind? - news article jduvall Electric Plane Talk 65 Jun 15, 2012 07:29 AM
Discussion Make Sure Your Wind Turbine Is In The Wind Big Foot 48 Life, The Universe, and Politics 0 Apr 04, 2012 09:22 AM
Help! DJI Naza wind issue!!!! (help needed with throttle up issue in wind) Arxangel Multirotor Talk 11 Mar 07, 2012 01:47 AM
Sold ~closed~ WINDSHEAR II Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 13, 2011 11:15 PM
