Joined Jul 2012
In response to your post on Curvy Bird thread I agree that the t/e is the bigger difficulty, I came to the conclusion that the glove would best be 'split for the last couple of inches at the t/e to accomodate the swing portion and some local reshaping of both glove and wing airfoil to minimise the gap variation when wing swings. For the gap seal I tried some of the velour strip that is used on sliding windows/conservatory doors, as it's not too thick and only about 1'4" wide but it still needs quite a big model so that the glove is not out of proportion (and I could get it free from scrap windows!). The l/e is much easier to deal with with a radius on the swing bit centred on the pivot point which in my case was around 20% chord.
Hey! this has got the juices flowing again, maybe I'll have to reschedule my 'to do list' yet again. So many ideas--------so little time Trev |
New templates cut and roots hot-wired.I made the templates out of some more laminate as they were also used as jigs for drilling.The bit I have is too short to go right through so I had to drill from both sides,worked out remarkably well.Next is to use the templates again to drill a series of holes for the radial slots.
Stuart |
Trev I like the door strip idea,filed away.
When I glass these things I hope to do them both together using F clamps and some worktop offcuts.What's exercising the grey matter is how these small pieces will stand up to compression.Doesn't seem to be a problem with wings,maybe because of the beds.Though I seem to recall Richard pointing out the possibility of crushing thinner sections.I think a trial press with the scrap ones is needed. Stuart |
Joined Jul 2012
To prevent crushing, instead of using clamps where it would be virtually impossible to apply absolutely equal loads to all clamps, I think that I would set the glued assemblies on a firm flat surface, place a pressure plate above withseveral precise distance pieces( which are just a few thou less than the thickness of your assemblies) in between the two plates , and stick some weights on top. This way you would not crush or distort anything and the adhesive film should also be very uniform.
Trev |
Meanwhile,back at the bench......Slots drilled and cut.Some of these jobs would be a lot harder without the stand drill.
Roots pinned back in their blanks and set up to cut the box slots.I did them together this time,which has the advantage of fewer nail holes in the roots. Similar set up for the connecting arms,remembering to reverse one! And the final act for today,placed on the base board. Stuart |
Hi Herks.Don't get too close with that attention thing,you'll be spotting all my errors!
As the cutter I used cut a loose fit,I've been pondering how to fix the pivots accurately.What I did was put the tubes in place,apply a few drops of thick c/a and quickly fix the top plates.When this had set,I made a foam dam around the top and filled it with epoxy.When this set I turned them over,cut a slight well around the other end and also pushed a cocktail stick down to make channels around the tube.Seems to be ok,both roots turn freely. Trial glassing next! Stuart |
Some balsa packings cut,ready to epoxy the boxes and arms in place.
With hindsight I should have left the cutting of the slots until I'd glassed the surface,I now need to either blank them off or fill them with scrap to stop the resin getting in. First will be a trial on a scrap piece,so I'll experiment on that. Stuart |
All fixed apart from the lower arm which is the only part on that side.
I have a can of expanding foam,so I'm going to try cutting a slot,masking it off and smearing the inside with petroleum jelly.Quick squirt of foam to fill it.What could possibly go wrong! ![]() After a consultation with our man in the shed I'm going to try two layers of 270gm and one of the light cloth he supplied me with for the canopy.Im also going to pinhole the surface to get better adhesion Stuart |
Sorry, I'm not really up to speed with what's going on (a normall state of affairs...
) but is there a force trying to peel the skins off the foam? If there is, a better solution than the pinholes (this works if the pinholes go all the way through thus forming a tie between the skins) may be to bore some holes and push balsa dowel through. Epoxy sticks very well to end grain balsa therefore giving you the tie you may or may not need.Just thinking aloud... |
| Thread Tools | |
| Discussion Best electric plane in 16 mph wind? | Sailor03 | Electric Plane Talk | 42 | Nov 23, 2012 02:40 PM |
| Discussion Why do airplanes take off in to the wind? - news article | jduvall | Electric Plane Talk | 65 | Jun 15, 2012 07:29 AM |
| Discussion Make Sure Your Wind Turbine Is In The Wind | Big Foot 48 | Life, The Universe, and Politics | 0 | Apr 04, 2012 09:22 AM |
| Help! DJI Naza wind issue!!!! (help needed with throttle up issue in wind) | Arxangel | Multirotor Talk | 11 | Mar 07, 2012 01:47 AM |
| Sold ~closed~ | WINDSHEAR II | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Oct 13, 2011 11:15 PM |
