I am a dinosaur!Unable to contact my guru(granddaughter)I've opened a Vimeo account but can't find how to get the vid on here.Hope the link works Stuart |
Joined Jul 2009
Yeah Stuart,
Well ok ... at a loss for words ... I am now fumbling around for a few fitting words here to entice you to actually convert this thing into a flying machine. If you can get this thing to work in a flying working wing ... then you you will be elevated to god status in my town !! Really cool stuff I am impressed. Jens |
Phew!the first one won't play back on the iPad for some reason,it was sent in high res.The second is low res,poor quality but at least it plays.
The traverse covers 70* and takes about four minutes.I've got faster drive options on the way,another vid when they arrive. The thing has got lots of torque.On one traverse I held onto the discs to put some weight on the drive(I'd marked some reference points on the disc by this stage)It felt as if the whole thing was going to move across the bench ![]() When I returned to the start point the marks were still in line,so no slip.I need to try this again one disc at a time. Stuart |
Ooooooooooooh..... that's how is works ! I get it now. Thanks for the video.
First video works perfectly. It should be as simple as posting the video to Vimeo or YouTube then cut/paste the URL from that page right in the body of your RC Groups post. YouTube is apparently aware your your computers video playback speed and offers all videos in a variety of resolutions, so that everybody can play them. My videos are shot at 1080p, which is high, but can be played 320p on YouTube. That is agricultural. I see what you mean now. You could replace the servo with a small motor that spins at a high rpm and then it would be too fast. With a gear reduction via drive pulleys, it could be attractive. Also, there is no automatic stop, so as the pilot you'd have to judge from the ground when to stop the swing wing thing. Certainly do-able. Since we're still in prototype-ville, I've attached a sketch of a suggestion. If the linkages between the nut drive at the threaded rod and the wing was very robust, this approach would be a durable way to hold the wings. Kent Edit: I just noticed that I had posted some thing very similar to this previously. Not being pushy, just forgetful. |
After seeing the speed, and given the proposed platform, I'm starting to think about an exponential step up drive. Let me crunch some numbers real quick and you can let me know at what point sounds acceptable for speed. Oh, and I think maybe you should of typed the servo speed as 1.04 RPS, which would work out to 62.4 RPM, which sounds about right. ![]() Mark |
Kent,thanks,I think I've cracked the Vimeo thing.iPad doesn't seem to like HD for some reason.
Bought some linkages similar to your sketch,when I've done a bit more on this system I'm going to dismantle the slide element and try them.I thing the gear tooth idea may have to be simplified to triangular teeth,but Id like to give it a go. Mark,I'll put up a pic of the specs next post.If I recall correctly the existing pulley has 16t,I've got a 32t and 48t on the way,with belts to suit. Could a motor of the type in the post above be used as a drive? Rps ![]() Regards Stuart |
| Thread Tools | |
| Discussion Best electric plane in 16 mph wind? | Sailor03 | Electric Plane Talk | 42 | Nov 23, 2012 02:40 PM |
| Discussion Why do airplanes take off in to the wind? - news article | jduvall | Electric Plane Talk | 65 | Jun 15, 2012 07:29 AM |
| Discussion Make Sure Your Wind Turbine Is In The Wind | Big Foot 48 | Life, The Universe, and Politics | 0 | Apr 04, 2012 09:22 AM |
| Help! DJI Naza wind issue!!!! (help needed with throttle up issue in wind) | Arxangel | Multirotor Talk | 11 | Mar 07, 2012 01:47 AM |
| Sold ~closed~ | WINDSHEAR II | Aircraft - Fuel - Engines and Accessories (FS/W) | 2 | Oct 13, 2011 11:15 PM |
