Old May 13, 2012, 04:24 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Idea
Project Leaf in the Wind
When Richard posed his question re swept wings or planks,I thought why not both ie a swing wing.Not wanting to clutter a serious discussion with what is probably fantasy I thought I'd post a new thread.
First thoughts were the hinge;scissors type,which would mean a step to keep the wings in the same line,or separate hinges for each half.Bearings shouldn't be a problem,plain sliding surfaces or a light weight ball race.
How to move the wings;a scissors mechanism driven by a threaded shaft motor.Could this also move the cog to suit the wing configuration.
It was while considering the force required to do this that I thought about the wing tips used on planks and gliders.If these were movable,when"toed out" would they assist in moving the wing tips apart and therefore forward.
At this point I googled" swing wing flying wing" to see if this had already been tried,and of course it has.I hope this works www.google.com/patents/US4605183
If not do the search it's on the first page.
This idea seems to be to automatically adjust the sweep angle to find the best glide speed for the wing; does any body have any more info on it?
The pages wouldn't scroll down for me,if someone could gets the plan and specs I wouldn't mind having a tinker with this.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old May 13, 2012, 05:25 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
I object to having any discussion I started refered to as 'serious'....
I'm really not sure what the advantages of this approach would be. Unless of course supersonic flight is on your 'to-do' list.
If you want to look at something that [I think] has merit and satisfies the mad-inventor urge in all of us have a look at - http://en.wikipedia.org/wiki/Short_SB.4_Sherpa . Someday, I'll build something that works on that principle - why? Just because...
Richard
Shedofdread is offline Find More Posts by Shedofdread
Old May 13, 2012, 05:43 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Richard,It's another one of those" I wonder if"things.I find the best way to stop them cluttering up my skull is to subject you guys to them.Once they're
knocked back I can get on with something worthwhile.Who knows,one day.....
I've seen the Sherpa before;can't help equating it with a flying van
Regards Stuart
Old May 13, 2012, 06:57 PM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Variable sweep has been mentioned many times in the last 60 years as a potential way to get pitch trim without using trailing edge control surfaces for that job. I can't remember anybody actually building one though. It should work after all it's basically just weight shift. There could be a problem going fast though. Light, low profile, hinges can lack adequate stiffness.
--Norm
nmasters is online now Find More Posts by nmasters
Old May 13, 2012, 07:13 PM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Stuart
Stuart - there is a button at the top of that page (Download PDF)
You can save the entire patent application on your computer. Or you can get it right here. All the pictures and description are there - 21 pages
HerkS is offline Find More Posts by HerkS
Old May 14, 2012, 03:00 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Thanks for that Herks.I've tried searching a bit more,drawn a blank.I'll have to experiment with this when time allows.
Regards Stuart
Old May 30, 2012, 03:32 PM
macboffin is offline
Find More Posts by macboffin
North London ENGLAND
Joined Dec 2006
Norm, some info for you. Barnes Wallis designed "Swallow" and "Grey Goose" swing wings way back. Scaled prototypes of both were first flown in 1950 by radio control, the Swallow was powered by two jet engines, was about fifty feet span. Made about thirty flights, on last flight got out of control and crashed in a farmers field, killing a cow. Prior to failure of the rather primitive radio control system, (adapted from a type of system used to control Queen Bees, radio controlled version of the De Havilland Tiger Moth used as a gunnery target) flew very well with wide speed range and good manuovrability. More recently there have been small ducted fan and even turbine powered R/C model versions. There is a wealth of info on the Net about these designs.
macboffin is offline Find More Posts by macboffin
Old May 30, 2012, 03:48 PM
Joined Dec 2006
Regarding the force needed to move wings for and aft, the Bell X5 swing wing aircraft had manually operated wings, a single lever moved the wings, so obviously not a lot of effort needed, although I would imagine that the "Lancer" B1 and the F111 have powered swing arrangements!
Old May 30, 2012, 10:02 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
The IcarusV and Easy Riser UFM hang gliders used weight shift and drag rudders.
They were also Swept with dihedral and washout.
Weight Shift might be much easier to Build and fly with than Swing Wings
birdofplay is online now Find More Posts by birdofplay
Old May 30, 2012, 10:57 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
On a small and light model, maybe just twist the entire wing instead.
lincoln is offline Find More Posts by lincoln
Old Jun 01, 2012, 04:14 PM
Joined Dec 2006
Been done a lot from way-back.
Old Jun 01, 2012, 04:45 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Not much good with links,but demondriver started a swing wing build over on electric sailplanes.Seems to be stalled at the moment,but he's an experienced builder,maybe he'll make the thing work.
Stuart
Old Jun 05, 2012, 01:44 AM
Undercarter is offline
Find More Posts by Undercarter
Lapsus calami
Undercarter's Avatar
Joined Aug 2009
Just when you think you've got a handle on aviation history, something new pops up.
Here's a pic of Barnes Wallis's Wild Goose design. Is that Wallis bending over on the inside of the launch trolley? A manned version called the Heston JC.9 was commenced but cancelled before completion. The aircraft had no control surfaces, relying on sweeping its wings together or independently. Wallis called it the wing-controlled aerodyne.
I believe the second pic is a model of the Swallow airliner.
Sir Barnes Wallis website is worth a visit.
Undercarter is offline Find More Posts by Undercarter
Old Jun 05, 2012, 03:17 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Thanks for all these guys.That's what's so good about these forums;throw an idea out and info just pours in.
Designers like Wallis and the guys who came up with the kind of ideas on Luft46 for example had the know how but lacked the technology to put their theories into practice.
Regards Stuart
Old Jun 05, 2012, 07:39 AM
Lapsus calami
Joined Aug 2009
I'd say what put the kibosh on Wallis's designs was lack of funding and other support, rather than any technological issues. Duncan Sandys' Defence White Paper gutted the UK aircraft industry after 1957. According to the Barnes Wallis website, the variable geometry wing technology for the F-111 was based on Wallis's work, to the point that Vickers considered suing General Dynamics for breaching their patents.
Discussion Best electric plane in 16 mph wind? Sailor03 Electric Plane Talk 42 Nov 23, 2012 02:40 PM
Discussion Why do airplanes take off in to the wind? - news article jduvall Electric Plane Talk 65 Jun 15, 2012 07:29 AM
Discussion Make Sure Your Wind Turbine Is In The Wind Big Foot 48 Life, The Universe, and Politics 0 Apr 04, 2012 09:22 AM
Help! DJI Naza wind issue!!!! (help needed with throttle up issue in wind) Arxangel Multirotor Talk 11 Mar 07, 2012 01:47 AM
Sold ~closed~ WINDSHEAR II Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 13, 2011 11:15 PM
