Old May 14, 2012, 02:48 PM
Qtop's Avatar
Denmark
Joined Apr 2011
I got two of these from ebay and no complains so far. Finishing is perfect and even better then my align. These helicopters rock ! I used some good electronics. Dont buy a rtf.
http://www.ebay.com/itm/ARF-Carbon-R...ht_4875wt_1396
Qtop is offline Find More Posts by Qtop
Old May 14, 2012, 07:41 PM
Australia, VIC
Joined Dec 2011
Motor
http://www.ebay.com/itm/Outrunner-Br...ht_5297wt_1163
I have this one in a flying 450 ATM
http://www.ebay.com/itm/KV3680-Brush...ht_3790wt_1163
And this one ..
Both run fine ...
I also have a bunch of Turnigy
The big red ones ... H2218 and the larger H2223 though the H2223 may be overkill for starting out
http://www.hobbyking.com/hobbyking/s...dProduct=22844
I also got this one , still not flow .. or used
I also have a cheap $8 shipped KV2700 2830 in a heli , and it seems to be doing ok for hovering , might be fitted with a 14T pinion ....
For a ESC , you want at least 40A , I got a 35A advertised one , and it must be more like 30A (or less) and after a few minutes hovering it tends to over heat ...
Its been replaced with a 40A and the heli runs fine now ..
Check those physical dimensions from the seller : [ ESC ] if there a little on the petite side , specs may be exaggerated
old4570 is offline Find More Posts by old4570
Old May 14, 2012, 10:51 PM
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Old4570. Do you have a link for the gyro? Really good price. That's for flybar setup correct? Maybe I should go flybar, then when I get better and more experienced convert to fbl. If the gyro is decent and for that price it would be worth it to go that route first and fbl later. Thanks.
Diesel6401 is offline Find More Posts by Diesel6401
Old May 15, 2012, 05:23 AM
Australia, VIC
Joined Dec 2011
Gyro
http://www.ebay.com/itm/F00002-FMT00...#ht_2379wt_905
FMT009 gyro
Old May 15, 2012, 05:59 AM
Australia, VIC
Joined Dec 2011
Aaah
Flybarless ?
HK sells one for around $50 = 3 axis gyro , I need to buy one , one of these days .
Check out youtube , a guy has converted a regular head to flybarless and flies it less 3 axis gyro , with weighted blades .
Dont be afraid of flybarless , just make sure you read some reviews on the one your interested in and what options it offers , some have modes or levels for stability , Noob - Medium - 3D , so you may need some sort of interface
Old May 15, 2012, 06:12 AM
Australia, VIC
Joined Dec 2011
Flybarless Mod
Flybarless 450 - Test 5 - Weighted vs. Unweighted blades (4 min 42 sec)
????? Is he running a 3 axis gyro ???
EXI 450 - Flybarless No Stabilization - First Test (3 min 36 sec)
no 3 axis gyro ...
A close look at my custom 450 FBL head (1 min 3 sec)
Looks like folks are going flybarless without the 3 axis gyro , and just weighted blades ..
flybarless (1 min 14 sec)
Old May 15, 2012, 08:55 AM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
Originally Posted by old4570 View Post
Flybarless ?
In a couple post up you mentioned a gyro for $12.90, was curious if you had a link for it.
Old May 15, 2012, 11:13 AM
WOS
United States, IN, Michigan City
Joined Nov 2003
They make quite a few of gyros that are cheap. Gy48V, HK401B, Eflight and a few others. Just dont expect it to hold well under extreme flying
WOS is offline Find More Posts by WOS
Old May 15, 2012, 11:15 AM
WOS
Joined Nov 2003
Here is one buy it now for under 10
http://www.ebay.com/itm/F00002-FMT00...ht_2313wt_1037
Someone else posted it above
Old May 15, 2012, 01:53 PM
Memento Mori
Diesel6401's Avatar
Joined Sep 2009
I couldn't extreme fly if I tried lol,more like extreme crashing.
Thanks.
Old May 15, 2012, 02:55 PM
WOS
Joined Nov 2003
Thanks.
You and I both!
All I do is sport fly. I dont do anything extreme at all. Well except for extreming my pants when the 3GX on my trex 500 went nuts on me. When it started coming at me and I had no control I was about to run leaving a trail behind me! Some control came back to shoot it out in the streets away from everybody then lost it again. Believe the stories you read about the 3GX loosing it! I do now!
Old May 15, 2012, 02:59 PM
KoOl BrEeZe
Joined Feb 2012
Just my .02 Cents....Dont let a cheapie gyro be the death of Your $300 heli Take place. A gyro in my opinion is the heart of a fb heli. With so many now going fbl The price on gyros In classifieds have come down alot. You can now pick up a like new if not new align gp-780 for only $40. Or a spartan for $50...Spending that x-tra 20-30 $'s is very well worth it in my book. Last year I tried out the hk-401b. Only felt good about it in a hover. Sport flying it around was a bit of a mess. Again just my opinion here.
LiQuid*Xion is offline Find More Posts by LiQuid*Xion
Old May 15, 2012, 04:35 PM
Australia, VIC
Joined Dec 2011
yeah
For everyone that likes a gyro , there is some one who does not ..
FMT009 gyro [ I did post a link ]
So many variables involved ... (gyro)
Obviously , the more money you spend , hopefully you get a better product , but if implemented incorrectly ??? , then cost may not be a factor .
Interesting stuff this : So many twists and turns (gyro)
With so many gyro's , and servo + Tx combinations , and the variables involved , it can take quite a bit of fiddling to get the gyro to work , another variable being head and tail rotor speed ...
Funny stuff gyros , I have one , when the head speed slows down , the gyro holds better , one of the others , wants more head speed ...
The FMT009 so far seems , less sensitive ...
I have the E Sky Gyro , ZD720 , and FMT009 flying ATM
E Sky needs warming up and maybe faster head speed 2500+ , ZD720 seems to like slower head speed [ maybe around 2000 ] and the FMT009 seems less fussy ..
But thats just for me , and with my Gyro Servo Tx combinations and my woeful set up [ I say woeful as I still consider myself a noob ]
None of my Gyro tail servo combinations come close to being the same , and I havent got around to trying out different tail servo's yet (could be important) ..
Old May 15, 2012, 07:12 PM
WOS
Joined Nov 2003
and the gy401 and gp780 they work no matter what you do
Old May 15, 2012, 10:30 PM
Australia, VIC
Joined Dec 2011
gp780 , wow , I did a entire RTF for that price ...
same with the Futaba Gyro , Built a 450 with 7ch Computer radio for that price ...
Sorry ,I would never dream of paying more than $20 for a HHgyro ...
Same goes for the ESC , Motor , or a metal head ...
Im so budget ! ( could be read as cheap )
Just like I cant afford to drive Merc or BMW or Porche or Ferrari ...
Some of us need to search out affordable gear ( budget ) as in my budget can afford it ...
Discussion don't know where to put the camera on my t rex 450 mick3485 Video Piloting (FPV/RPV) 3 Apr 18, 2012 03:31 PM
For Sale T-Rex 450 clone Aoelian 450 SE RandyQman Aircraft - Electric - Helis (FS/W) 2 Apr 14, 2012 02:53 PM
For Sale T-Rex 450 clone Aoelian 450 SE RandyQman Aircraft - Electric - Helis (FS/W) 0 Mar 26, 2012 04:53 PM
Sold t-rex 450 Clone+Parts wishmaster420 Aircraft - Electric - Helis (FS/W) 2 Feb 29, 2012 04:16 PM
For Sale T-rex 450 clone RTF new assembled $184 tlrascal Aircraft - Electric - Helis (FS/W) 10 Feb 27, 2012 05:27 AM
