Old May 13, 2012, 09:42 AM
Nikolizer1 is offline
Find More Posts by Nikolizer1
Nitro Buster
Nikolizer1's Avatar
PA
Joined Aug 2007
Phoenix Models Edge 540 91-1.20 size
Hey all, I wanted to get every possible opinion I could out of this setup for the plane I'm getting. First off, I'm in college and close to a local field and miss flying. I got a few questions regarding the setup too. The bug for 3D is back in me
The plane requires a 90-1.20 two stroke. How would a saito 125 do on it?
I bought 5 Futaba S3305 servos. They do not mention on the website about running on a lipo battery, but would they work fine with a 7.4v lipo?
Does anyone currently fly this airplane? What are your ups and downs about it?
The reason i want to run the lipo battery is because it will indeffinitely raise the power of the servos. I bought the servos originally for a dynaflite decathlon, but changed my mind and did not feel like buying new servos again. The decathlon can sit on the shelf for a bit longer. I looked at the Thunder tiger 130 4c for it, but a friend mentioned the saito 125, which is about 4.5 oz lighter and also the receiver battery is 2.2 ounces lighter than a 6v nimh pack. Lighter flies better I always say!
Nikolizer1
Nikolizer1 is offline Find More Posts by Nikolizer1
Old May 13, 2012, 12:00 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
If you want a 3D machine then I would not get the phoenix edge. It is just way to heavy for good 3D flight.
I am sorry but those servos will not take 7.4 volts.
A really good airframe would be from 3DHS although there are others out there.
Just stay away from the lumber wangons, They'll snap on you.
kerwin50 is offline Find More Posts by kerwin50
Old May 21, 2012, 09:35 PM
Capt Crash is offline
Find More Posts by Capt Crash
Gravity is just a theory.
Capt Crash's Avatar
Nuevo Mexico
Joined Jul 2004
I'm flying this plane with a GMS 1.20, and it's a hoot. It's not the lightest, but it's no tank either. Mine came with heavy aluminum landing gear, but evidently they are now equipped with CF gear. With my heavy 1.20 it's got unlimited vertical with an APC 16x7 prop. Lots of space under the cowl means easy installation of whatever engine you choose. Some pilots are flying it with a DLE 20. The surfaces are huge, and with a good pilot at the sticks it will 3D. If you're on a budget, it's worth a try.
Capt Crash is offline Find More Posts by Capt Crash
Discussion New Phoenix Models Edge 540 .91-1.20 GP/EP ARF truevine77 3D Flying 29 Dec 09, 2015 05:19 PM
Sold NIB 1.20 size CMP/Will Hobby Edge 540 badkarma Aircraft - Fuel - Airplanes (FS/W) 8 Oct 02, 2012 05:08 PM
Discussion phoenix models edge 540 91 1.20 somewhat "review" out of stock 3D Flying 6 May 04, 2012 08:48 PM
Wanted Hangar 9 Edge 540 1.20 size cowl and canopy jp22878 Aircraft - Fuel - Airplanes (FS/W) 0 Sep 22, 2011 12:07 AM
