Old May 13, 2012, 09:07 AM
OFFA 1 is offline
Find More Posts by OFFA 1
Joined Dec 2003
How do I convert CAD files to PDF?
I have a few designs that I've done in TurboCad. I can save them as .TCW, .DWG, .DXF or supposedly PDF. The Save as PDF only saves an 8.5 x 11 size.
I went so far as to buy Adobe Acrobat X Pro, but can't figure out how to use it properly.
I would like to be able to save my drawings as PDF in full size, and various tiled sizes.
I would also like to be able to convert PDF to a CAD format to make editing a drawing easier than manually tracing it.
Can someone please give me a few tips?
...........Moose...............
OFFA 1 is offline Find More Posts by OFFA 1
Old May 13, 2012, 09:25 AM
oct2633 is offline
Find More Posts by oct2633
Joined Jul 2005
Tiling Plans
I too have Adobe Acrobat X and want to learn how to use it to tile plans such that they will be full size when assembled. Help
oct2633 is offline Find More Posts by oct2633
Old May 13, 2012, 12:19 PM
rajazo is offline
Find More Posts by rajazo
rajazo's Avatar
Chile
Joined Jul 2010
stop suffering... download PDFill aplication it has a virtual printer module who is installed in the system printer like normal printer.... then define a custom size in the preference menu of the "printer" and voila
http://www.pdfill.com/index.html
about PDF to cad is not easy because not all PDF has vector information... then you need to traslate the PDF to raster image.... again PDFill install a PDFtool (free) with a PDF to image export.. you can define resolution and image tipe.. TIFF and JPG could be inported to Acad.
rajazo is offline Find More Posts by rajazo
Old May 13, 2012, 01:42 PM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
You should be able to choose not to scale or print 1:1 or some such option. You should be able to choose and define a custom page size as well. I don't work with TurboCad but every other CAD software I've used have offered these options. Worst case scenario you can send me the .dwg files and I would be happy to convert them for you.
Chad Veich is offline Find More Posts by Chad Veich
Old May 13, 2012, 02:26 PM
OFFA 1 is offline
Joined Dec 2003
Thanks Chad,
I can scale and/or tile fine within TurboCad, just can't get it to transfer the scale and tiling into a PDF.
Old May 13, 2012, 05:45 PM
spog is online now
Find More Posts by spog
Joined Mar 2006
Another virtual printer pdf freeware program that I use and works very well.
http://sourceforge.net/projects/pdfc...atest/download
spog is online now Find More Posts by spog
Old May 14, 2012, 10:30 AM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Two step process
"Converting" a CAD file to PDF is a virtual printing process, as rajazo mentioned. When you install Acrobat, the Acrobat reader or other PDF software, a PDF printer will be created on your computer. It will be listed in Windows along with any other printers you have defined. In your CAD program, select the PDF printer as the device when you plot or print (depending on the software". It will "print" your CAD file to a PDF file. Print to that PDF file in 1:1 scale, by the way.
To make tiled prints, call up the PDF file in the Acrobat reader. Select Prints, and then in the "page scaling" section, select "Tile all pages." Alternately you can select scale ratios if you wish.
potshot is offline Find More Posts by potshot
Help! Anyone able and willing to convert a DXF file to PDF? Lowflyer52 Foamies (Scratchbuilt) 5 Oct 02, 2009 02:43 PM
Discussion how do i post a sketchup file with out pdf justwanttofly Foamies (Scratchbuilt) 9 Jul 31, 2009 09:15 AM
Help! Need to convert BRODERBUND CAD drawing to DXF file SPEED-E-FLYER Life, The Universe, and Politics 1 Mar 12, 2007 12:36 PM
Discussion how do i tile a pdf file? rumplestilskin Foamies (Scratchbuilt) 6 Sep 03, 2006 11:47 AM
