Old May 12, 2012, 06:47 PM
sircana is offline
Find More Posts by sircana
sircana's Avatar
Spain
Joined Jan 2009
New Product
Finally! SPW 5.8 and 900, and 5.8 Helical from Circular-Wireless
Ready to order!
HELICAL 5.8 12dBi
SKEW PLANAR WHEEL 5.8GHz
SKEW PLANAR WHEEL 900MHz
sircana is offline Find More Posts by sircana
Old May 13, 2012, 02:43 PM
sircana is offline
sircana's Avatar
Spain
Joined Jan 2009
Just two comments to some questions received:
The 900 MHz SPW is big, VERY big. 19cm diameter. The good news is that it is light (10 grams).
The 5.8 antennas are small, VERY small. As it is impossible to achieve a consistent accuracy, we test every single 5.8 antenna, and we reject those not achieving <-13dB Return Loss between 5645 and 5945 MHz (i.e. <95% transmitted power).
Old May 14, 2012, 07:21 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You beat me to it! My goggle mount 5.8GHz helical has not yet hit the stores.
By the way, you 5.8GHz will out sell all of your other frequencies combined. Ask me how I know
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old May 14, 2012, 10:54 AM
sircana is offline
sircana's Avatar
Spain
Joined Jan 2009
-Alex
I am sorry...
Yes, I already realised how big the demand is... It seems 5.8 is the future, and on the other hand, you REALLY need Circular Polarization at 5.8...
Old May 14, 2012, 03:36 PM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Ready to order?
where?
VRflyer is offline Find More Posts by VRflyer
Old May 14, 2012, 04:22 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
-Alex
Yes they do. I've got one of your 5.8CL's and a Hugo helical mounted on my goggles best antenna tracking in the world.
gundamnitpete is offline Find More Posts by gundamnitpete
Old May 14, 2012, 04:35 PM
Peril is offline
Find More Posts by Peril
Jets Suck (and blow)
Peril's Avatar
Australia, QLD, Deception Bay
Originally Posted by sircana View Post
Ready to order!
HELICAL 5.8 12dBi
OH Yeah, perfect for a 5.8G tracker.
Where can I buy these beauties from?
Peril is offline Find More Posts by Peril
Old May 14, 2012, 05:25 PM
sircana is offline
sircana's Avatar
Spain
Joined Jan 2009
Originally Posted by VRflyer View Post
Ready to order?
where?
Master, I would be really honored if you visit our shop:
www.circular-wireless.com
Old May 14, 2012, 05:26 PM
sircana is offline
sircana's Avatar
Spain
Joined Jan 2009
Thanks!
Old May 14, 2012, 10:02 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
I will come incognito
Old May 14, 2012, 10:08 PM
BushmanLA is online now
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Ready to order!
HELICAL 5.8 12dBi
My wife might appreciate that one....
BushmanLA is online now Find More Posts by BushmanLA
Old May 15, 2012, 07:22 AM
sircana is offline
sircana's Avatar
Spain
Joined Jan 2009
LOL
Do you want me to make a couple of earrings with them...?
Old May 18, 2012, 08:00 AM
sircana is offline
sircana's Avatar
Spain
Joined Jan 2009
A very busy week...
All orders sent, backlog up to date, and enough stock built to cope with the demand.
Big thank you all for trusting us and have patience with the shipments.
I look forward receiving some feedback once you will have the chance to test them.
P.S. You will notice we have slightly changed the 5.8 Helical design, removing the Hecker Transformer Balun. As we individually test them, we have decided to go with the parallel conductor impedance matching method. I will try to post some more details tonight.
Old May 18, 2012, 06:08 PM
sircana is offline
sircana's Avatar
Spain
Joined Jan 2009
Regarding the impedance matching method, we decided to use the Hecker Transformer (the copper triangle) for the 1.2 and 2.4 helicals, because even if it doesn't give the best matching, it is good enough, very consistent (all antennas have the same performance), and very solid.
We build the first prototypes of the 5.8 helicals with the same Hecker Transformer matching method, but finally we decided that they are small enough to make almost impossible to accidentally bend the conductor and lose the impedance matching, so we changed the Plexiglas design to guide the conductor in the right position, and we fine tune the conductor position manually while testing the antenna:
Old May 18, 2012, 07:35 PM
CryptoHawk is offline
Find More Posts by CryptoHawk
Joined May 2012
Sircana
Well done - very professional looking finish to your products - I'll be ordering shortly and running some pretty thorough tests (R&S and Agilent test gear in my shack). If the test results are anywhere near as good as the physical finish & presentation of you antennas your business is going to do well, sir.
Out of interest - it looks like you have removed pretty much as much excess polycarbonate as possible from the helix coil frames. The dielectric constant/relative permativity of polycarbonate can be pretty high above 1Ghz (depending on the exact polycarbonate composition of course) - did you find when designing the helical antennas that the polycarbonate had much (if any) effect on helix dimensions, in particular the 2.4 and 5.8 products?
CryptoHawk is offline Find More Posts by CryptoHawk
For Sale Foxtech 5.8 vtx/rx, cloverleaf, SPW, and helical jkarnacki FPV Equipment (FS/W) 20 May 30, 2012 06:39 AM
Sold For sale 8 turn Helical 5.8 ghz KondorFPV FPV Equipment (FS/W) 7 Apr 20, 2012 01:14 AM
Sold ImmersionRC 5.8 GHz DiversityDuo v2 vRx with 7 turn Helical and 5dbi Omni - $250 nk4787 FPV Equipment (FS/W) 3 Mar 27, 2012 12:06 PM
Sold 5.8 ghz SPW/CL CP Antenna Set cactus FPV Equipment (FS/W) 2 Nov 07, 2011 09:23 PM
Sold 5.8ghz rp-sma SPW, CL, 4 turn Helical whakahere FPV Equipment (FS/W) 9 Oct 29, 2011 10:55 AM
