Old Jun 07, 2012, 05:49 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
New video showing Alpha version performance doing 360degrees around the ground base link .
jalves is offline Find More Posts by jalves
Old Jun 07, 2012, 06:00 AM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
Looking really good jalves.
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Jun 07, 2012, 07:37 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Kudos!!!
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jun 07, 2012, 07:50 AM
Joined Aug 2009
Originally Posted by RonSpooner View Post
Could you please share the info for the continuous servo mod.
Ron
I followed the instruction here with the exception, I used 2.2k resistors verse the suggested 220 ohms. I did not try the 220 ohms first, so I don't know if the performance is better.
http://www.instructables.com/id/Modi...uous-Rotation/
Old Jun 07, 2012, 08:20 AM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Use the 2.2k the 220 wont make any difference. I'm useing high torque servo's on my tracker. Also using lazy susan bearings for the pan and tild to take the stress off the servo bearings.
Martin Y is online now Find More Posts by Martin Y
Old Jun 07, 2012, 08:33 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Martin,
Which tracker software are you using??
Old Jun 07, 2012, 09:17 AM
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Either The RVGS unit, OpenDiyAT or my diy one using an Arduino with X-bee's. I'm no programmer but can muddle around enough to make it work.
Old Jun 07, 2012, 11:16 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Martin,
Can you add the OpenDiyAT to your list?
Old Jun 07, 2012, 11:26 AM
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Done.
Old Jun 07, 2012, 12:11 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Martin,
Thanks, but that's not what I want, I want to ask you to test the OpenDiyAT along with your Hardware.
Did you test it in the rc field already?
Old Jun 07, 2012, 01:51 PM
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Originally Posted by jalves View Post
Martin,
Not yet, but will be soon.
Old Jun 07, 2012, 02:01 PM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
ok.
I will wait your report.
Old Jun 07, 2012, 06:48 PM
RonSpooner is offline
Find More Posts by RonSpooner
Australia, VIC, Kurunjang
Joined Jan 2011
Thanks I have modified servo now but I still need help to understand the schematic for the rx. I can't see how to wire the pan and tilt servos.
Any help would be appreciated
RonSpooner is offline Find More Posts by RonSpooner
Old Jun 07, 2012, 07:00 PM
Joined Aug 2009
In the source code, the servo pin is set to 9.
Code:
//Servos variables
int servoPin = 9;     // Control pin for servo motor
Old Jun 08, 2012, 03:56 AM
jalves is offline
jalves's Avatar
Portugal
Joined Mar 2004
Pan servo --> pin9
Tilt servo --> pin10
make a common ground and power the servos with a BEC.
EDIT: upgrade the Connections wiki page with new photo with servo connections
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign FPV Talk 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV Equipment (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV Equipment (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV Equipment (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV Equipment (FS/W) 4 Sep 08, 2011 07:53 AM
