Espritmodel.com Heli Air
Old Jun 05, 2012, 02:21 PM
Canada, ON
Joined Jan 2009
Come on people too much thinking. Simple buffer works. I use this on my Vrx.
Martin Y is offline Find More Posts by Martin Y
Old Jun 05, 2012, 02:33 PM
rimshotcopter's Avatar
Joined Aug 2009
Thank you Martin.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jun 06, 2012, 09:57 AM
Joined Aug 2009
Martin, question please,
Can the MPSA06 Transistor be replace with any NPN transistor?
Thank you.
Old Jun 06, 2012, 10:00 AM
Joined Aug 2009
Here are a couple of In-process pictures of the Antenna tracking controller.
I added the I2C Compass because it was just here collecting dust. I plan to display the compass heading on the Serial Display along with the LAT/LAN readings received.
Old Jun 06, 2012, 10:17 AM
Canada, ON
Joined Jan 2009
Thank you.
Yes you can. Any low power signal will work. I just have a few hundred of them to use. A 2N3904 works well also.
Old Jun 06, 2012, 10:22 AM
Joined Aug 2009
Thank you..
Old Jun 06, 2012, 12:17 PM
jalves's Avatar
Portugal
Joined Mar 2004
Rims,
I am also adding a LCD to the OpenDiyAT.
Are you using a 2nd atmel to "feed" the LCD??
jalves is offline Find More Posts by jalves
Old Jun 06, 2012, 12:36 PM
Joined Aug 2009
Originally Posted by jalves View Post
Rims,
The LCD is an all-in-one that I purchased on Ebay, there is no vendor name or brand to it however there are many others including I2C versions. This one communicate at 9600 baud and I am using SoftwareSerial to create a second serial port using pins 7 & 8 but you can use any pins your like. An Example of SoftwareSerial is included in the Arduino IDE. I have not started integrating this with your code otherwise I would just post a copy.
Old Jun 06, 2012, 01:50 PM
Joined Sep 2010
What is the purpuse of displaying compass heading, is it for calibrating the antenna direction?
Jalves any news on "video telemetry"? (at least regarding hardware you are going to use)
msev is offline Find More Posts by msev
Old Jun 06, 2012, 01:52 PM
Joined Aug 2009
Right now, it serves no real purpose but to let me know what direction the antenna is pointed.
Old Jun 06, 2012, 02:55 PM
jalves's Avatar
Portugal
Joined Mar 2004
msev,
This will take time, I have to "study" the PAL signal, the Overlay captions and finally the encode and decode of the telemetry.
As you can see, it isn't a trivial task
Old Jun 06, 2012, 02:56 PM
Joined Aug 2009
msev,
Plus +1000 and Kudos for what you have accomplished so far!!!
Old Jun 06, 2012, 03:13 PM
Joined Sep 2010
Thank you for your work jalves!
Old Jun 06, 2012, 03:46 PM
jalves's Avatar
Portugal
Joined Mar 2004
Thanks guys,
you know, one little step each time
PS.
Don't forget I had help
Old Jun 07, 2012, 02:59 AM
Australia, VIC, Kurunjang
Joined Jan 2011
You Got it, I just modified a few servos for continuous rotation, need to locate a wheel or some means to transfer motion to the base.
Could you please share the info for the continuous servo mod.
Ron
RonSpooner is offline Find More Posts by RonSpooner
Help! LRS/UHF/XPS for Aurora 9, and 1.3ghz Antenna Tracker. Eagleeyes or Skylark? daign Video Piloting (FPV/RPV) 2 May 17, 2012 03:36 PM
Sold 360 Servo for (Antenna Tracker or PAN).....NEW crd FPV/RPV - Equipment and Vehicles (FS/W) 1 Apr 15, 2012 05:39 PM
Sold RVGS Antenna Tracker scrape FPV/RPV - Equipment and Vehicles (FS/W) 0 Mar 31, 2012 11:18 PM
Sold Antenna Pan/Tilt for Antenna Tracker w/ MG Servos imagebuff FPV/RPV - Equipment and Vehicles (FS/W) 1 Mar 20, 2012 02:26 AM
Sold Servo City Heavy Duty Pan / Tilt for antenna tracker w EZ Antenna Tracker thefokker FPV/RPV - Equipment and Vehicles (FS/W) 4 Sep 08, 2011 07:53 AM
